Do I need a different rear derailleur?
Old 11-20-19, 03:51 PM
ddeand
ddeand's Avatar
Quoted: 151 Post(s)
Liked 26 Times in 14 Posts
I have a CX bike from around 2005 that came with a Shimano 105 long cage rear derailleur and 105 9-speed brifters - it worked pretty well for me. The front derailleur is also a 105, and the crankset is a a Campy Centaur 46/34 setup. I recently stumbled across a free pair of Shimano Ultegra 10-speed brifters (6600 series) in much better condition than the 105s, so I swapped them in and started to dial in the shifting. I also swapped a 10-speed Shimano cassette (13-30t) onto the bike. The 9-speed cassette was also a 13-30t. I'm finding the bike difficult to get set - it's close, but not perfect. While I never would ride it like this, I can't get the shifting to cross-chain on the two different extremes (large chainring/large cog or small chainring/small cog). I can get all the other combos, though. I guess my question is if this is normal or should I get an Ultegra 10-speed rear derailleur? Also, if I do get a 10-speed Derailleur, do I need a long cage if I stay with 30t cog? After reading the thread about rear derailleur design and function, I'm wondering if a different RD might be best. And is the Centaur crankset a decent math for this setup? If not, what would be a good crankset that will still allow for 46/34 chainrings? Thanks for any advice and opinions.
Some days, it's not even worth gnawing through the restraints.
ddeand is online now
Old 11-20-19, 04:23 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 783 Post(s)
Liked 83 Times in 63 Posts
10 speed shifters don't pull the same amount of cable as 9 speed shifters.
Match a 10 speed cassette to 10 speed shifters, or 9 speed cassette to 9 speed shifters.
Bill Kapaun is online now
Old 11-20-19, 04:32 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 800 Post(s)
Liked 124 Times in 105 Posts
Never Fix A Running Piece. Why waste your time and effort trying to get the cross-chained combinations to work? Just don't use those combinations, that you say you would never use anyway. If the other combinations work just go and ride.
dsbrantjr is online now
Old 11-20-19, 04:42 PM
ddeand
ddeand's Avatar
Quoted: 151 Post(s)
Yeah, thatís what I did - 10-speed cassette to 10-speed shifters (and 10-speed chain). It seems the 9-speed derailleur would cover the same range on both the 9-speed and 10-speed cassettes, but I could be mistaken on that.
Old 11-20-19, 04:50 PM
davidad
Quoted: 349 Post(s)
Liked 25 Times in 23 Posts
1. Shimano
6, 7, 8 and 9 speeds
Rear shift ratio is 1.7, that is for 1 mm of cable pull/release, RD is moved left/right by 1.7 mm. Shimano calls this 2:1 ratio for marketing reasons.
All these RDs are compatible and any 6 to 9 speed RD will work perfectly with either 6, 7, 8 or 9 speed shifter. Regardless whether it’s a MTB, or road shifter, or RD. They are also compatible with Shimano 10 speed road shifters, except the Tiagra 4700 series.
Shimano Dura Ace from 1984 to 1996 period (6 to 8 speeds)
Rear shift ratio is 1.9. They are compatible only with Shimano Dura Ace shifters from the same period (that is for 6, 7 and 8 speeds).
10 speed ROAD RD
Rear shift ratio is 1.7, so it’s compatible with all the 6 to 9 speed shifters, as well as road 10 speed shifters. Same rear shift ratio. MTB 10 (and 11 speed) shifters won’t work well.
Exception is Shimano Tiagra 4700 10 speed road RD – it has the same shift ratio as Shimano road 11 speed RDs, so it will work only with Tiagra 4700 shifters and Shimano 11 speed road shifters.
Another exception is the new “gravel” group (with hydraulic brakes): Shimano GRX. Caple pull wise it’s the same as Tiagra 4700.
davidad is offline
Old 11-20-19, 05:29 PM
tomtomtom123
Quoted: 169 Post(s)
Liked 42 Times in 26 Posts
So F1 x R1 and F2 x R10 work fine, but F1 x R10 and F2 x R1 do not work?
Did you also switch to a 10 speed chain or are you still using a 9 speed chain? I wonder if using the wider 9 speed chain causes too much gap that it prevents the chain from riding the ramps when shifting at the extreme cross angles. Maybe try using a 10 speed chain.
You made sure to check the L and H limit screws, B-screw, and that you can physically press the RD with your hand to be centered to the largest cog on the inside, and that when on the smallest cog, the RD is about 1mm offset to the outside of the center of the cog?
The cable housing is clean?
https://bike.bikegremlin.com/1220/1-...compatibility/
https://bike.bikegremlin.com/1232/bi...compatibility/
tomtomtom123 is offline
Old 11-20-19, 07:17 PM
shelbyfv
shelbyfv's Avatar
Quoted: 1295 Post(s)
Liked 324 Times in 208 Posts
Folks, he said he's using 10 speed cassette, chain and brifters.... OP, if your 9 speed 105 RD clears the 30T cog, in theory it should work with your 10 speed stuff. However, they were only rated for 27T. If you decide to try a 10 speed RD, look for one of the later ones rated for your 30T. Early ones were 28T, IIRC.
shelbyfv is offline
