Hed Chris King 24/28 vs Mavic Cosmic Pro Carbon SL UST for Mt Diablo
Bikes: Moots Vamoots RSL 2018, Passoni Titanio 2020
Quoted: 111 Post(s)
Liked 33 Times
Hed Belgium Plus Chris King 24/28 vs Mavic Cosmic Pro Carbon SL UST for Mt Diablo
Context: My LBS is building me a Vamoots RSL Sram Red eTap.
Main usecase: up and down Mt Diablo (NorCal)
Price difference: not most important but the deal I get on Mavic is better. After tax the difference is 400$ or so (Mavic is slightly more expensive)
Concerns: My paranoia is skeptical of carbon even though I’m not dragging brakes. What if you get stuck behind a car? Alloy is fine with it. On one side I can go with something time tried on the other with the bling factor.
I can’t find ANY tests (real tests not advertisement) with this Mavic model
these 2 are my choices after looking around
help me decide
SOS
help me decide
SOS
Quoted: 1067 Post(s)
Liked 259 Times
If you are riding up and down Mt Diablo a lot (several times a week), wet and dry, and not much else I would get the Heds. If you are riding all over the place and up and down Mt Diablo less frequently get the Mavics.
Farmer tan
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I have no experience with your carbon option, but I have the Chris King/Hed wheels (disc version, with 28/28). They are outstanding wheels, and Chris King really stands behind their builds. (I broke a spoke when my wife's bike fell on it, and they re-built and shipped the wheel for me, free, even out of the warranty period). I would not hesitate to buy from them again. The hubs and rims are both of outstanding quality, and very good value.
Farmer tan
There's a Univ of Kentucky PhD who published research a number if years ago showing the tape vs. glue result, what's the best glue process, how heat affects bond strength, etc. You can find the PDFs using Google.
I won't be dragging the brakes.
Bikes: 2018 Fuji Cross // 2014 Scott Addict 10
Quoted: 25 Post(s)
Isn't the Diablo climb super boring? (No tree cover and basically up and then just back down). You should get over to Mt. Tam more often .
Bikes: 2015 Spec Roubaix Expert, 2016 Spec Diverge Expert X1, 2018 Allez Sprint eTap
Quoted: 63 Post(s)
Geoff
Quoted: 18883 Post(s)
Liked 10,646 Times
Carbon brake tracks are thicker w/ tubular rims because they don't need to build hooks for the bead which can greatly reduce the risk of a blowout. Or so I hear. Haven't ever heard of the heat affecting glue.
Quoted: 111 Post(s)
Liked 33 Times
Liked 259 Times
Tubulars melting glue. Blowing out clinchers. Melting carbon rims. I have never ridden Mt Diablo but in the weekend the roadside must be littered with broken wheels/ bikes, and riders.
I suggest you change the spec of the bike you have ordered to disc brakes and fit 203mm vented rotors with 4 piston callipers.
Quoted: 111 Post(s)
Liked 33 Times
Tubulars melting glue. Blowing out clinchers. Melting carbon rims. I have never ridden Mt Diablo butin the weekend the roadside must be littered with broken wheels/ bikes, and riders.
Liked 10,646 Times
The worst kinds of anxieties - the hardest ones to shake - are the ones that start with a grain of truth. No one ever goes hiking and worries about being mauled by a cow. Everybody is worried about bears. People ride bikes up and down mountains all the time, but people do blow tires out occasionally and whatnot.
Farmer tan
If you do a lot of riding, it's something to consider.
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
Why not tubeless clinchers?
Quoted: 111 Post(s)
Liked 33 Times
Liked 10,646 Times
@Boerd
I saw a snake yesterday morning, in the dock at a floating cabin. Probably looking for frogs. I "ran into" a rattler on a ride a few years ago, the road went gravel and sort of vanished in this wet grassland, I was doing ok on 28 mm tires until it got too muddy to roll. Stepped off the bike, started pushing, just as it dries up, I heard a rattle. It's amazing how you can react before you have any idea what you're reacting to, I leapt back away from it immediately. It wasn't interested in biting though, just working on its tan and being left alone.
Couple weeks ago I took my gravel bike up a gated double track road and a yearling bear ambled across the road ~25 feet in front of me. It looked happy and lumbering until it saw me, then obviously startled and ran from me.
Liked 10,646 Times
I'm riding tubeless clinchers, nominal 28 mm on wide rims that stretch them out to 33 mm. So I'm running them at low pressure, like 60 psi, a little higher if I'm not going to leave the pavement. My last tire went 1,200 miles without a flat, until a cut literally destroyed the tire. I've ridden over plenty of broken glass. At low pressure, the sealant protects you from small punctures.
But I think we're talking about skinny 23 or 25 mm tires here. At higher pressure, the sealant is going to get pushed out until the tire is too soft to ride.
There's some drawback to tubeless, like a really limited selection of (mostly more expensive) tires, which are a ***** to seat. The skinnier your tires get, the less you get back in exchange.
Quoted: 111 Post(s)
Liked 33 Times
That IS an option. At 90 PSI the boiling temperature for water is around 160C which is around 320F - that is pretty high. This means the solution inside will do just fine up to the most extreme, and at that point you're in trouble anyway. The water / latex based liquid will also increase volume a lot less than the air it displaces - another good thing.
If I get the Mavics I think I'll run them tubeless.
As @Seattle Forrest pointed out you trade tire selection and possible tire quality - no more Conti 4000 II s in that case.
Liked 10,646 Times
If you go tubeless, get Pro Ones, or IRC RBCC. (Tires.)
Quoted: 111 Post(s)
Liked 33 Times
While those tires seem very good, I heard horror stories about the degree of difficulty to mount them on this specific Mavic wheel. I might be tempted to stick with Mavic Yksion Pro as they now make them in France (no more Taiwan) and the compound got very good reviews. The only drawback I heard of is short lifespan - they wear out easily. I'm willing to replace them at a higher frequency (and obviously higher cost).
Liked 10,646 Times
Yeah, they're a pain. But that guarantees a tight seal, no air leaking out during aggressive corners, etc.
I have the Pro Carbon UST. The brake track is one of the best parts about the wheel. The braking is very strong and predicable. I would wager they brake as good as alloy in both wet and dry conditions.
