Thomson X2 w/Risers
Bikes: Canyon, Bowman & Colnago
Quoted: 132 Post(s)
Liked 39 Times
Thomson X2 w/Risers
I understand the Thomson X2 stem was designed to be lighter for road use (as opposed to the X4), thus the 2-bolt system and, presumably, thinner construction.
Would this translate into NOT using this stem with risers (600 to >700mm)?
Does anyone use this stem with (wide) risers? Any horror stories, like the stem breaking, failing, etc, under the extra torque exerted from using risers, as opposed to road drops?
I'm just curious since Thomson tech support told me it should be fine but since there would be more torque, from the wide risers, the life of the stem would be reduced, since it was designed to be used with road bars.
Thanks.
Thanks.
Bikes: stinner cx, paramount track
Quoted: 262 Post(s)
Liked 9 Times
it doesnt matter what kind of bar you have, but riding an x2 offroad has a higher chance of slipping than an x4 does.
overtorquing the bolts is the only way ive ever seen a faceplate crack.
Quoted: 89 Post(s)
Liked 15 Times
+1 on the overtorquing --> cracked faceplate. I did this but Thomson was kind enough to send me a new one.
One of those little Ritchey 5nm torque wrenches is not a bad idea probably not super accurate but keeps you form being a gorilla.
Your cog is slipping.
The 3mm hex bolts Thomson uses now helps prevent apes from over-torquing them because the wrench will twist first.
My wife uses an X2 with narrow-ish Nitto risers every now and then - but she's 5'3", 110 lbs. I probably wouldn't do it, especially if the bars are really wide.
Bikes: Newish steel.
Quoted: 117 Post(s)
You'll probably even be able to get a few bucks back by swapping for an X4.
FWIW my X2 slipped with road bars on pavement. My X4s have been bulletproof. Don't see myself buying another X2.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I had to go a little higher than the 5.1nm torque spec on my X2. The face plate bolts would back out and come loose.
My torque wrench has 2nm increments. When set half way between 4nm and 6nm the face plate bolts would back out over time and eventually loosen up. Greased the bolts and inside threads, increased the setting on the torque wrench little by little and they seem to stay put at about 6nm.
-Tim-
-Tim-
-Tim-
-Tim-
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
Out of curiosity, is this a fairly common thing or does it just depend on the faceplate/bolt used? I have one stem where this is an issue, but no others. I used a bit of Park Tool Polylube green grease when I installed it, and they will back out. Will be putting some blue Loc-tite on them shortly.
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
On x2s: fiber grip and loctite
P sure the torque listed by Thomson is dry. Two tiny pinch bolts, wide faceplate, probably enough flex going on to back out nano meters under load, grease won't help that.
Quoted: 262 Post(s)
Liked 9 Times
dont forget that overtorquing your x2 bolts can cause damage to your bars too. not just the faceplate.
- Soli Deo Gloria -
Liked 736 Times
https://www.bikethomson.com/wp-conte...0/StemInst.pdf
-Tim-
Quoted: 1332 Post(s)
Liked 398 Times
Always found it interesting that Thomson's "road" stem is two-bolt, while pretty much every other company's road bike stems are four-bolt.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Thomson says to grease the bolts and inside threads.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Thomson X2s are not MASH approved for long/ MTB risers. I have a good feeling the X2 faceplate can't handle the forces exerted on it from a wider riser in the long run.
If you check out the MASH crew's mashing rigs they all have short and stubby MTB/ FGFS stems.
Retrogression being a top tier Cinelli dealer has nothing to do with anything.
Just like they probably aren't concerned with what Angie & I are having for dinner tonight or which Black Sabbath record is my favorite, I don't really need to care about what length stem the MASH crew "approves" of this week.
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Clark W. Griswold
Quoted: 4361 Post(s)
Liked 4,002 Times
I wish Thomson would actually make X4s with more rise and such. So many people use them on the road it just makes sense. There are those who wish to get super aero or want to be a touch more upright and it would be nice. The X2s do look nice but two bolts just don't do it especially on those teeny tiny 3mms.
I see you over there
Been using wide risers for several months now on my thomson x2 with no issues at all. I ride this bike everyday.
Fixie Infamous
Quoted: 54 Post(s)
The consequences probably won't show themselves slowly over time, but more likely all at once really fast into the concrete.
