My FSIR Spin 5
My FSIR Spin 5
Old 01-20-24, 12:07 AM
Ron Damon
Quoted: 463 Post(s)
Liked 567 Times in 356 Posts
Change log
  • Reinstalled Schwalbe Marathon Supreme 42-406 tires
Wanna squeeze some last milage out of this discontinued classic touring tire, veterans and flawless performers from my tour in Taiwan, first tour of South Korea and a couple of tours of Bali.
  • Reinstalled Ergon GP3 grips
Ditto.
  • Reinstalled WTB Pure saddle
Cuz Black is the new White
Front, 30psi
Rear, 40psi
Tengkulak
Sukawati
Payangan
Ron Damon is offline
Old 02-17-24, 05:19 AM
Ron Damon
Quoted: 463 Post(s)
The Flag, Sukarno and Pig
Likes For Ron Damon:
Old 02-17-24, 07:14 PM
Ron Damon
Quoted: 463 Post(s)
Lowest RD position
​​​​​~4.5cm with 42-406 tire
Old 02-18-24, 04:22 AM
Jipe
Quoted: 802 Post(s)
Liked 249 Times in 213 Posts
This 10s Shimano Deore derailleur is also mounted on several Tern bikes with ETRTO406 wheels.
Jipe is offline
Old 02-18-24, 05:28 AM
Duragrouch
Quoted: 758 Post(s)
Liked 421 Times in 337 Posts
Please pardon my ignorance on newer systems; There appears to be an additional pivot point just aft of the rear derailleur mount (versus older traditional RDs); Is that a "clutch" that I've heard of on newer RDs, especially for large 1X cassettes?
Also, I sure don't grasp why so many 1X cassettes, are all silver color plating, but the largest cog is black. Is this like semi-auto pistols with a black slide over a chromed frame? I don't see the aesthetic appeal, and I can't think of a functional one.
Duragrouch is online now
Old 02-18-24, 05:45 AM
Ron Damon
Quoted: 463 Post(s)
The pivot aft of the RD mount is not the clutch, but rather the pivot around which the B screw rotates the RD to adjust the height of the top/guide pulley.
The clutch, here in the off position, is indicated by the red arrow.
On some cogsets, like this Shimano CS-HG500 part, the inner-most, dark grey cogs are made of aluminum rather than steel to reduce weight. This part weighs about 430g while the all-steel CS-M4100 part weighs north of 500g.
11-42T, one alloy cog
11-46T, two alloy cogs
Old 02-18-24, 07:01 AM
Duragrouch
Quoted: 758 Post(s)
(above) Excellent explanations, thank you!
The clutch location, makes sense from what I've read. I had thought it somehow was a different geometry or pulled the derailleur back when needed to help on 1Xs, but that's the function of the B-screw.
Aluminum low cog, makes complete sense. More difficult to plate I think, although nickel or chrome plating would be of more benefit in wear than on steel, though not as critical for corrosion as with steel, if using a proper aluminum alloy. It may be hard-anodized, aluminum oxide is hard.
Old 02-18-24, 07:32 AM
Schwinnsta
Schwinnasaur
Schwinnsta's Avatar
Quoted: 459 Post(s)
Liked 184 Times in 122 Posts
(above) Aluminum low cog, makes complete sense. More difficult to plate I think, although nickel or chrome plating would be of more benefit in wear than on steel, though not as critical for corrosion as with steel, if using a proper aluminum alloy. It may be hard-anodized, aluminum oxide is hard.
Seems counterintuitive to me. Alloy for larger cogs and steel for small is more intuitive.
Schwinnsta is offline
Old 02-18-24, 11:58 PM
Duragrouch
Quoted: 758 Post(s)
Yes, that's what I mean. By "low" (gear) cog, I meant the largest diameter cog. Big/low, small/high; Always a slight communication challenge when talking rear cogs.
Old 02-27-24, 04:48 PM
Ron Damon
Quoted: 463 Post(s)
Spoke broke
Broke spoke on non drive side at 12 o'clock
If you wish to theorize, hypothesize or otherwise fantasize about the cause of the spoke breakage, there's a thread for that already, here.
Old 02-28-24, 10:15 AM
GeezyRider
GeezyRider's Avatar
Bikes: There is always room for one more.
Quoted: 185 Post(s)
Liked 391 Times in 226 Posts
No need to theorize. It definitely happened because your derailleur was too close to the ground.
Don
GeezyRider is offline
Likes For GeezyRider:
Old 02-29-24, 02:37 AM
Duragrouch
Quoted: 758 Post(s)
Well it wouldn't have broke if the spoke had been on the bottom, tension is reduced there.
My work is done here.
Likes For Duragrouch:
Old 03-01-24, 09:56 PM
Ron Damon
Quoted: 463 Post(s)
Back in business
  • Broken spoke & rim tape replaced
  • Spoke tension checked & wheel trued
  • Spare spokes in drive and non drive side sizes purchased
Parts & Service: $13
Old 03-12-24, 05:14 AM
Ron Damon
Quoted: 463 Post(s)
Old 03-16-24, 06:53 AM
Ron Damon
Quoted: 463 Post(s)
Change log
  • Installed a new Schwalbe Marathon Supreme 42-406 tire in the rear.
  • Installed new brake pads in the rear
Old 03-16-24, 07:50 PM
Ron Damon
Quoted: 463 Post(s)
And it's not even 10AM.
Old 04-13-24, 06:56 AM
Ron Damon
Quoted: 463 Post(s)
