To Build A Better Brompton - Titanium custom Build [Advice Appreciated]
First post. New account.
I recently have fallen into the world of cycling a little over a year ago and I owe it all to The Brompton. It reignited a love for bicycles I didn't have since I was a kid and that's what brings me here! When I moved to the city for work I sold my car and Needed a way to get around and the Brompton ended up being perfect for what I needed. Since then I have gotten myself a 2016 Salsa Colossal Ti Gravel Bike for more long distance leisure rides but the Brompton still remains my favorite for being the folding bike that people don't give me problems with when I bring it into places. Still it's not perfect (no bike is no matter how much we try convince ourselves at great expense), Now that I'm dealing with the cold and the rain and frost disk brakes are becoming more of a priority. Some hills I simply don't handle well despite riding for some time now so I'm looking for a greater shifting range and a. I want to go greater distances so I am looking ata 20 inch wheelset upgrade too. Finally to compensate for the weight gained with such parts I'm aiming for an all titanium frameset.
To sum up my build plans:
- Titanium frameset with fork and rear triangle for 20 inch wheelset. I want to lighten my load for the hills a little as well as not have to worry about rust.
- DIsk Brakes (Mechanical over hydraulic unless other Brompton folks have a strong case to go for hydraulic)
- Rohloff hub for handling hills up and down. Looking for thumb shifters All the ones in my research seem to be no longer in business.
- 20" wheelset I want to have greater rolling resistance and not have much fear of the terrain. I also believe this will cause less issues with the hub.
- Chain, no belt - I was first looking into a belt drive but it's looking like more trouble than it is worth to go for that. I am aware of kinetics offerings on this, but there still seems to be a lot of headache in this place especially for titanium.
- Where and when to carbon - I keep hearing about flex concerns and need more information on this. Brompton's t-line seemed to have chosen a carbon for for a reason enough to change the stem for it too. Not to mention on other parts outside the frame (crank, handlebar, stem, etc)
Quoted: 63 Post(s)
Liked 28 Times
I’d be tempted to get a Helix. It’s got 24” wheels, it’s titanium and has much more flexibility than a brompton in terms of drivetrain options. I don’t know that it will work with a Rohloff but it does work with an Alfine 11 and I saw someone built one with the Kindernay hub.
Quoted: 801 Post(s)
Liked 249 Times
The Helix is heavier than the T-line and folds bigger, its not comparable at all.
About the Rohloff, the standard shifter is the best, its lightweight, simple, reliable and allow to shift several gear in one turn.
For the 20: wheels, due to its folding geometry, on a Brompton increasing the wheel diameter automatically increases the folded length and height (which is not he case with the Birdy).
Now that there is the T-line, the titanium clones just cannot compete, they cannot provide the same riding performances with the same weight.
Palmer
Quoted: 1671 Post(s)
Liked 1,827 Times
I made a Venn diagram of what you want vs. what the trifold market is currently offering.
Anyway, here's some food for thought:
An alloy-framed Alps with discs and Shimano Alfine 11:
Here's a Leggero full-titanium:
An all-carbon Chedech:
And an unidentified AliExpress/Alibaba ti trifold with 20s and discs:
Likes For tcs:
Quoted: 801 Post(s)
Liked 249 Times
The problem is probably the external gearbox of the Rohloff with disc brake, located on the left side of the bike (while other IGH have their gear control on the right side). Some people manage to have disc brake on the hub with the Rohloff internal gearbox.
Kindernay has an hydraulic gear command instead of cable(s) which is stupid, its only heavier, requires maintenance and prone to leakage while it provides no advantages vs. cables (there is no wear like with brake pads).
iti biking
Have you considered Vello’s titanium framed folders as a starting point? A reasonably tight fold for 20” wheels and a frame built for disc brakes. Apparently the steel frame is a pretty stiff ride so the ti option should mellow that out a bit.
Likes For Reddleman:
Palmer
Liked 1,827 Times
Palmer
Liked 1,827 Times
I'm pretty sure the place is closed down. I sent an email and tried making a phone call a while ago. Even still my folding expectations aren't quite met here.
I've also considered SILVEROCK's Carbon front fork and rear triangle but the options only are offered in 16" size. The Ti bike builders I talked with did concern me about apprehensions using ti forks especially when using disk brakes on a smaller wheel size. I'm convinced Brompton thought the same.
Quoted: 63 Post(s)
Liked 28 Times
Likes For silverx:
Quoted: 801 Post(s)
Liked 249 Times
Palmer
Liked 1,827 Times
Ha! That guy doesn't even know how brakes work (he gets the physics wrong.)
The first Curls were fitted with two-finger brake levers and long-wearing pads. Oops! They fixed those issues some years back, as can owners of the early Curls.
The main concern I have is given the wet weather and snow I deal with disk brakes seem to be a necessity unless v brakes are more capable of handling the elements better than I have been lead to understand on the whole. If v brakes are enough that solves a few problems for me but I'm cautious nonetheless.
Palmer
Liked 1,827 Times
Hey, I'm there with you. I've ridden caliper-braked bikes for over a half-century, never a problem, and considered discs just some new whizbang gimmick to sell something new to somebody. Then during COVID boredom, I built up a bike with discs. Word. Now I'm with those who say 'no new bikes for me unless they have disc brakes'.
It's not just power. Bicycle brakes can be too powerful (re: stoppie, or initiating a skid in wet weather or snow). I like the finely controllable modulation on my discs.
Likes For tcs:
Quoted: 801 Post(s)
Liked 249 Times
I fully agree with you wrt. the finely controllable modulation of discs but not all of them: I only had this with the several hydraulic disc brakes I have/had (Shimano Deore, XT, Magura Louise, MT4, MT5, Avid Code and SRAM Guide but those two last one are very bad on some other points), not with the mechanical disc I have (TRP Spyre) or have had (Avid BB7).
Likes For Jipe:
Quoted: 63 Post(s)
Liked 28 Times
Not to derail the thread but curious what cassette your are using with AXS on your Helix? The largest cassette that’s compatible according to the Helix site would be 9x42 with chainring no larger than 36 teeth. It doesn’t seem to be possible to put on one of super wide range cassette.
Quoted: 63 Post(s)
Liked 28 Times
Have you checked out the Eerdermetaal Brompton mods with 20” wheels? Seems like he’s not taking new orders at this time but if you want 20” wheels like that could be an option? Or
Kinetics in Glasgow. I do wonder how the addition of 20” wheels would grow the size of the bike? At that point I feel like it might match up closer in size to the Helix. I agree the Helix bike is still getting going and doesn’t seem fully on their feet yet as a company. They did recently make available rolling wheels to make
it easier to roll when folded. I’ll be curious to see the folding rack when that’s finished and hopefully fenders.
https://www.eerdermetaal.nl/brompton...collectie.html
Likes For univega.duder:
Quoted: 4806 Post(s)
Liked 3,933 Times
The Eerdermetaal I am not so enthusiastic over. Not a fan of wide tires. I've checked out kinetics and was initially going for their 20 inch kit with the rohloff and calling it a day. The problem is I grew up in the salt belt and where steel will rust and is heavy than alternatives and it's hard to convince my brain otherwise. My gravel bike that I use for a speedier ride is ti save for the carbon fork so I'm now more convinced than ever.
Not much to add here on the bike except to say I'm in your corner. I love going down the path to a solution that will do just what I want it to. Yes, usually more work, more money spent, but when I've gotten it right, truly fun! I set up a broken frame I picked up for $20 as a fix gear. So much fun I had from the BB forward copied, a totally custom arrangement for the dropouts and stays, then that built out of titanium by a local builder. 12 years and 20,000 miles later, my favorite bike.
From helix upgrade guide show simple calculator to prevent chain hit frame
Example if following helix website, 10-30t supposed use 48t
But i try use 50t still ok (maybe this max size for 30t cassette)
If u want use bigger chainring must use small cassette
Likes For silverx:
hi there. i have seen a lot of TITANIUM COLOR bike frames out there, painted alloy frames, not actual titanium material frames.
for exaample the FNHON GUST and STORM models of folding bikes, they come in this awesome TITANIUM COLOR.
does anyone know what colors (varnish) to mix to get this look?
i have looked everywhere on the net and youtube and cant seem to find a tutorial.
i thank you in advance!
