convert shimano 10 spd wheel to 9?
Ran over one of my bikes destroying the frame. Since N+1 is the proper number of bikes, I found a great deal on an ultegra equipped 11 spd to go with my lightspeed 9 spd w/ Chorus. .
The back wheel is still usable; the 10 spd cassette creates problems.
Can I put a 9 speed shimano compatible cassette on the 10 speed freehub to make it work on the campy der.? Without having to adjust the limit screws every time I change a the wheel?
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 187 Post(s)
Liked 178 Times
IIRC the difference between 9 and 10 speed cassettes is that 10 sp adds a thin spacer. The freehub body is the same 8,9,and 10 speed Shimano.
Sir Mark, Knight of Sufferlandria
Bikes: Cannondale SR's and ST's from the '80's
Quoted: 340 Post(s)
Liked 46 Times
I believe that the cog spacing between Campy and Shimano is different.
I have heard of conversion cassettes to use on Shimano freehubs that are spaced for Campy,
one made by American Classic.
https://www.bikeforums.net/bicycle-me...speed-hub.html
but have no experience looking for nor using them.
You may have to do some research.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
The Dura Ace 7801 is an example...
Today, I believe my jurisdiction ends here...
Quoted: 187 Post(s)
Liked 178 Times
Fair enough so the exception disproves my general answer...... OP what hub do you have that you wish to attach a campy/ shimano compatible cassette to?
Quoted: 273 Post(s)
Liked 10 Times
If it's a MAVIC he's in luck...
Really Old Senior Member
Unlikely your Campy RDER and unspecified shifter will move the RDER the proper amount.
Scroll down just a bit-
Sheldon Brown's Bicycle Frame and Cassette Spacing Crib Sheet
zacster
Bicycle Mechanics
43
03-26-19 12:00 PM
Lewis_Moon
Bicycle Mechanics
19
08-24-12 09:28 AM
fiataccompli
Bicycle Mechanics
10
11-11-11 09:53 AM
