Transferring groupsets from one bike to another
Hey folks,
My wife has a 2015 trek Neko SLX with disc brakes. Its a 9 spd triple ring. I purchased her a 2015 Trek Verve 1 WSD. (purple), which is a 7 spd. She wants me to transfer the groupset from the Neko to the Verve because she likes the "step thru" design better. She also loves the color purple. This transfer would include wheels due to the disc brake setup. The Verve has rim brakes. The Neko is a 700c x 38, whereas the Verve is a 700c x 35. would this be doable. Looking forward to feedback
Quoted: 18353 Post(s)
Liked 4,502 Times
Assuming cable actuated brakes, you can probably transfer the shifters, derailleurs, and cranks between bikes. What kind of bottom bracket do the bikes use?
You may be able to swap forks and front disc brakes between the bikes.
However, unless both bike have disc brake mounts on the rear, don't bother with the swap.
Wheels? Does either bike have a freewheel, or do both have, say 8/9/10 speed cassettes? If both have cassettes, you can do the swap (beware of 7 speed freehubs). If you have a freewheel in the mix, then you can purchase 9 speed freewheels, but it does add further complications.
Anyway, some will work, some won't. Personally I'd leave the disc brakes alone, and just go for the cranks, derailleurs, & shifters.
Really Old Senior Member
What are you going to mount the disc brake calipers to on the Verve?
You may be better off leaving the Neko intact.
New rear wheel, 9 speed cassette, shifters & chain for the Verve.
The Verve has a Free Wheel hub, whereas the Neko has a Free Hub (cassette) hub.
SE Wis
Quoted: 2741 Post(s)
Liked 3,388 Times
Looks like the NEKO is hydraulic disk and the Verve is V brakes. The verve likely does not have provisions for mounting disc calipers.
If the shifters and brakes are separate units you'd need to keep the verve brake handles. I can't tell from the pictures if the NEKO rims have rim brake surfaces. If not you're talking wheels as well due to the freewheel/freehub incompatibility.
https://archive.trekbikes.com/us/en/...ko_slx/details
https://archive.trekbikes.com/us/en/..._1_wsd/details
Liked 4,502 Times
Ouch, I didn't realize we were talking about 9 speed hydraulic.
I think you're opening a can of worms you don't want to let loose, unless you're sure the Verve can receive the parts.
You're probably much better off deciding if you wish to do upgrades (double/triple, cassette/speeds in rear, etc), and then just sourcing parts and doing the upgrade.
Likes For CliffordK:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Yeah, you might be able to use some of the parts from the NEKO on the Verve, llike the shifters, DRs and wheels (but not the brakes) The same parts, particularly the wheels from the Verve won't fit on the NEKO. The end result will be a bike that's OK but not quite where you want it, and a pile of parts that don't quite make another bike.
Probably better to just to just do upgrades as the preferred bike will accept
Likes For Ironfish653:
Well folks,
I will heed the advice you have given me, and leave the Neko intact. I will upgrade the Verve as I go.
Thanks for all of the feedback. That was what I needed.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
As above, it would not be a simple swap, esp. wrt. brakes, as the Verve has no disc mounts, and the Neko rims are disc specific and have no braking surface.
Anyhoo, having slightly lower end derailleurs and shifters is not something that really effects ride quality or enjoyment, so upgrading the Verve is likely not worth the effort. The only improvement I would expect to have a decent return on effort would be to replace the rear 'freewheel' wheel with a more modern 'freehub' wheel, which will likely roll slightly better and be more durable. It may be difficult to find a 7 speed freehub wheel but an 8 speed (same spacing as modern 8, 9, 10, etc, hubs) can be used with a 7 speed cassette and a spacer.
Also, bikes usually come from the factory with the heaviest and slowest tires known to bikedom, so replacing tires with lighter/more-supple-casing/faster/better could have a noticeable impact on ride quality. I like to wait until my rear tire is pretty worn, then buy myself new tires as a reward for riding so much that I wore out a tire. So I don't think of tires as an 'upgrade' but as a 'wear item' that eventually needs replacement.
Likes For Wilfred Laurier:
Thanks for that information...I may be picking your brain some more before this is over.
Well folks,
after going home and looking at the Neko. Boy! do I feel stupid! I could have easily answered the question of whether or not I could transfer wheels and group set. I now know that everyone of you probably were or are thinking, "what an idiot!"...Lol! I would have to agree!
IF she likes the 9 speed vs 7, that can be upgraded.
The main bugaboo is the rear hub has to be changed to a different type.
That's not that big of a deal if you are a wheel builder, AND your nipples/spokes haven't corroded together.
Likely, the spokes will still be the correct length.
You can discuss the price of that with your LBS. It might be more reasonable during the slow season.
Basically about $100 for the shifters, chain & cassette.
The DER's will probably work, but might also need to be upgraded to 9 speed. Try it first.
Likes For Bill Kapaun:
Liked 4,502 Times
One can purchase 9 speed freewheels if you hunt for them. They aren't as durable as a new cassette hub/wheel. But, if one is careful with the bike, it should be OK. One may need to do some spacing adjustment and dishing of the wheel.
