Go Back  Bike Forums > Bike Forums > Fitting Your Bike
How to stop sliding forward on the saddle
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 09-08-14, 12:07 PM
philbob57
Quoted: 716 Post(s)
Liked 613 Times in 377 Posts
When I ride, I slide forward on the saddle. I start by perching my sit bones on the wide area of the saddle (old style Fizik Aliante) and rolling forward onto my pubic rami(?) to reach the handlebars. As I ride, I pretty quickly slide forward to a point where I feel as if I’m riding on the saddle’s nose, which leads to perineal numbness. I push myself back, and the cycle starts again.
This occurs with an Avocet Touring I, a Specialized Toupe, and the Aliante. I rode the Avocet without any problems for years, but when I got back to cycling last year after a 10 year layoff, I started to have this problem.
My saddle height seems good – no knee pain, slight bend in the knee with heel on the pedal at 6 o’clock.
My handlebars obscure the front hub when I’m on the drops. The stem, which is both long and deep, is about 2 cm higher than my saddle. I used to ride the drops and the hoods, but now I ride the bend in the bars. I turned 70 six weeks ago, so I don’t expect to get back to the drops much in the future.
Since this happens with 3 very different saddles, I suspect it’s my setup.
My first thought was that my saddle was too far back, but I feel like I slide forward earlier if I place the saddle in a more forward position. I wonder if my stem is too long or too high, but it’s not easy to experiment with a shorter stem. Also, the stem has been in so long that I can’t loosen it to lower it.
Any thoughts on what to change first?
Thanks.
philbob57 is offline
Old 09-08-14, 12:15 PM
Al Criner
Bikes: 2009 Surly Cross Check Frankenbike
Try tipping the saddle nose up slightly.
Al Criner is offline
Old 09-08-14, 01:20 PM
chasm54
You're 70, and got back to cycling after a ten year layoff. Are you riding the same setup you had back in the day? If so, I suspect that you've lost (maybe temporarily) a bit of flexibility in your lower back and are struggling to manage the reach that used to be oK for you. So you'll tend to sit slightly more upright and since your hands can't come back, your backside slides forward.
That's just a guess. But if it's right you might try a shorter stem and see if that helps. A bike shop might help with loosening the existing stem for you.
chasm54 is offline
Old 09-09-14, 07:03 AM
Kopsis
Kopsis's Avatar
Quoted: 83 Post(s)
The fact that your preferred hand position is now higher and farther back than it used to be says that you're riding with a more open hip angle, so you probably need to nose-up the saddle slightly to compensate. Don't go crazy -- bump it up by only half a degree and then ride for a week. Repeat until either the problem goes away, or you start experiencing too much perineal pressure.
Kopsis is offline
Old 09-09-14, 02:25 PM
philbob57
Quoted: 716 Post(s)
All I can say is, 'THANKS!' Obviously, I completely forgot about the ability to change the angle of the saddle, and there's no saying if or when I'd have remembered without your suggestions.
I just got back from my first ride after tipping the saddle nose up a little bit, and my butt pretty much stayed where I put it. 2ndary effects include: 1) I stretched out more; 2) did some riding on the hoods; and 3) felt more stable throughout the whole ride, even though the 2nd half of it was into the teeth of an 11 mph wind.
Lots of changes to setup over the past year, especially in the saddle area. I weigh a lot more than I used to, and I'm a wee bit shorter.
Old 10-04-14, 11:39 PM
LDier
When I got into road biking a few years ago I got a Brooks B17 saddle. At first I kept sliding down on the saddle. Then I tilted the saddle up a little too much and it kinda hurt down there ( if you know what I mean). I just kept changing the tilt of the saddle until I just stopped sliding down on it. The new Brooks B17 is kinda slippery and shiny so it's easy to slide down on it. I do like the Brooks very much on my road bikes. But they take some break-in time. For bikes ridden with more upright torso posture, like hybrids, I use wider softer saddles.
LDier is offline
Old 10-05-14, 07:19 PM
roadbuzz
Just ride.
roadbuzz's Avatar
Sometimes lowering the saddle a bit can help.
roadbuzz is offline
johngwheeler
Road Cycling
26
07-29-17 09:14 PM
curttard
Road Cycling
33
07-20-17 08:52 PM
Noonievut
Fitting Your Bike
9
11-02-14 04:42 AM
kingsqueak
Fitting Your Bike
20
07-31-13 02:34 PM
lphilpot
Fifty Plus (50+)
10
03-02-12 05:28 PM
