How long typically do bike tires hold enough air?
Old 03-01-20, 08:37 PM
Badzilla
Badzilla's Avatar
Quoted: 16 Post(s)
I have BMX 20" x 2.xx tubes/tires.
They are pumped up a little every five days or so, to almost 60 psi.
I suppose maybe lower versus higher pressure makes some difference?
Does Schrader versus Presta valves make any difference?
I just want a general idea.
Thanks.
Badzilla is offline
Old 03-01-20, 09:08 PM
duckhuntr
Quoted: 5 Post(s)
Liked 4 Times in 3 Posts
Fat low pressure tires require more air every three or four days. Roadie high pressure tires require more air almost every day. The valve type doesn't matter.
duckhuntr is offline
Old 03-02-20, 02:10 PM
livedarklions
Cyclesomatic
livedarklions's Avatar
Bikes: 1994 Specialized Allez Pro; Motobecane Fantom CX; Giant OCR A1
Quoted: 3570 Post(s)
Liked 2,278 Times in 1,309 Posts
Low pressure tires like you've got lose air more slowly than high pressure for the simple reason that air under pressure diffuses through the pores in the tires faster.
You mention it's a BMX--are you doing any jumps on it or anything where the tire pressure might be more critical than normal riding?
livedarklions is offline
Old 03-02-20, 02:58 PM
Ogsarg
Quoted: 375 Post(s)
Liked 360 Times in 161 Posts
If you're putting 60psi in a 2 inch tire, you could probably go months and not need to refill. It'll drop a fair amount at first and then lose air very slowly. I run 40 and 35 in 1.75" tires and can go 4 weeks easily without pumping them up. They lose about 5-7PSI in that time.
Ogsarg is offline
Old 03-02-20, 03:11 PM
ramzilla
ramzilla's Avatar
Quoted: 549 Post(s)
Liked 139 Times in 117 Posts
My rule of thumb for all tire sizes: one week.
ramzilla is offline
Likes For ramzilla:
Old 03-02-20, 10:07 PM
Gconan
Bikes: Norco search xr
Quoted: 163 Post(s)
Liked 102 Times in 61 Posts
I check before every ride. Or at least when I remember to.
Gconan is online now
Likes For Gconan:
Old 03-02-20, 11:34 PM
Sapperc
Bikes: Specialized Roubaix SL4 Comp, Trek 930, Nishiki International
Quoted: 62 Post(s)
Liked 19 Times in 11 Posts
Like other maintenance issues there really is no typical. Depends on your inner tubes and how demanding you are of your bike. Best practice is to check the pressure prior to every outing. Or at least every day if you use your bike for multiple short rides during the day. As you experiment with tire pressure you will probably discover that your bike will perform best with different pressures for various riding conditions. Good luck!
Sapperc is offline
Old 03-03-20, 12:13 AM
Dave Mayer
Quoted: 703 Post(s)
Liked 75 Times in 49 Posts
My bike shop owner pal once explained to me why certain of their customers came in every 3 months for new tubes. It was because that was how long it took for the tire pressure to drop to the point where the tires suffered pinch flats, which required both tubes to be replaced.
My pal once got bold enough to ask one such repeat customer why they didn't just buy a pump and regularly inflate their tires. The incredulous response by the customer was they could just come in to the shop to get the tubes replaced, and tires re-inflated. It's a living, I guess.
If someone ever thinks that working in a bike shop is an adventure filled with working on cutting-edge tech and servicing high-performance customers.... well it isn't. Most of the work is tedious repetitive stupid crap like this.
I've also wondered why I regularly find 30-year old bikes in garage sales which were only ridden 3-months from shop floor to hanging in the rafters. Same reason: tires became deflated, then pinch flats, and owners used this as the excuse to finish with the bike phase thing once and forever.
Dave Mayer is offline
Likes For Dave Mayer:
Old 03-03-20, 12:40 AM
beach_cycle
beach_cycle's Avatar
Bikes: 2018 Meridian 26" Single Speed Trike; 2019 Monterey 26" Seven Speed Trike
Quoted: 14 Post(s)
Liked 14 Times in 10 Posts
A week, under normal riding conditions. With the BMX, you'll probably want lower pressure for riding in the sand, and higher for hard dirt/paved roads. In that case, replacing air is required before every ride. If you can judge air pressure by touch, that makes a quick pre-ride check easy, but you should always check PSI before every ride... assuming your tires are rated 40 - 60 PSI, in a week you'll probably only drop from 60 to 50+/-, and that is a good point to top off. Otherwise, they'll stay in the safe zone for weeks with harder pedal power required and smoother shock absorption. That is a judgement call for the rider, but either way, check PSI before every ride, and every now and again a slow overnight leak will be found.
beach_cycle is offline
Old 03-03-20, 09:25 AM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1104 Post(s)
Liked 185 Times in 134 Posts
Yeah, the only thing "typical" about air loss is that it'll happen. In my experience, high-pressure latex tubes can lose 20 psi over the course of a single ride. Lightweight butyl tubes will lose air more slowly, and heavy butyl touring tubes even more slowly. Also, heavier tires seem to help hold air longer. My road bikes need more air about every other day.
BlazingPedals is offline
Old 03-03-20, 09:48 AM
Flip Flop Rider
Flip Flop Rider's Avatar
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 551 Post(s)
Liked 183 Times in 107 Posts
check after 1 week
Flip Flop Rider is offline
Old 03-03-20, 09:55 AM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 1022 Post(s)
Liked 512 Times in 266 Posts
As has been discussed before, In cold weather tires tend to hold inflation longer. In hot weather they seem to loose pressure faster. At least that's been my experience.
I bike commute most days, but my fenderless 700x28 12-speed may sit for a month untouched in the winter. I usually run the tires at 90psi, and aftersitting for a month they may be as low as 65psi., but sometimes only down to 80 after a month.
BobbyG is offline
Old 03-03-20, 10:26 AM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2768 Post(s)
Liked 675 Times in 470 Posts
+1. I pinch my tires before every ride. It's not a very precise check, but it's enough to alert me if the tires are squishier enough than usual to warrant pumping (and the pump has a gauge.)
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 03-03-20, 05:51 PM
Pridedog
Gone Biking!
Pridedog's Avatar
Bikes: Lynskey, Redline Conquest Disc, Bike Friday, Cannnondale T2 Tandem.
Quoted: 17 Post(s)
Liked 12 Times in 9 Posts
+1 I have followed this rule of thumb 7 days per tire for over 220,000 miles. Do the tires lose some air over 7 days, yes, does it negatively affect their performance, not in my experience. Road bike tires, 85 psi rear and 70 psi front. Has served me well. IMOP people get too anal over their tire pessure.
Pridedog is offline
Likes For Pridedog:
Old 03-03-20, 06:10 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1896 Post(s)
Liked 459 Times in 316 Posts
When it goes from feeling like an orange to feeling like a banana
Genesis 49:16-17
Darth Lefty is online now
Old 03-03-20, 08:01 PM
wolfchild
wolfchild's Avatar
Quoted: 1718 Post(s)
Liked 364 Times in 204 Posts
I usually pump my tires up once every 2-3 weeks.
wolfchild is offline
Old 03-03-20, 09:15 PM
Badzilla
Badzilla's Avatar
Quoted: 16 Post(s)
That's what I wanted to know, so I can better tell when there might be a problem (like when using substandard parts).
Thanks to the replies.
Badzilla is offline
Old 03-04-20, 04:03 AM
subgrade
Bikes: Focus Crater Lake
Quoted: 278 Post(s)
Liked 188 Times in 116 Posts
I suspect that if you do the pinch check regularly it might be as good or better a method than a cheapish gauge. I know how my tire must feel when pinched for it to have the optimum ride, but I've forgotten what pressure reading that corresponds to, since it's been a while I used a pump with a gauge.
subgrade is offline
Old 03-04-20, 04:08 AM
Kabuki12
Kabuki12's Avatar
Bikes: 1973 Windsor Profesional,1976 Kabuki diamond formula with full Campy, 1977 Raleigh Competition GS , 1971 Stella original Campy equip. 1978 Raleigh Super Grand Prix, 1972 Italvega Gran Rally ,1972 Super Mondia Special,Medici Pro Strada
Quoted: 199 Post(s)
Liked 216 Times in 149 Posts
On my vintage racers I check the tire pressure every week when I ride. I have several bikes in rotation and it may be 2-3 weeks since the last time I rode a certain bike. If I ride on particular bike more often I still check the pressure and give it a pump. Joe. Joesvintageroadbikes.wordpress
Kabuki12 is offline
Old 03-05-20, 09:52 AM
rumrunn6
Quoted: 3718 Post(s)
Liked 832 Times in 582 Posts
related: aren't some tube materials better at holding air?
latex tubes leak air more quickly than a butyl tube. but most tubes are butyl I think
rumrunn6 is offline
Old 03-05-20, 10:25 AM
Rides4Beer
Bikes: Defy | Revolt
Quoted: 516 Post(s)
Liked 407 Times in 223 Posts
As always, it depends. I run tubeless on the gravel bike and latex tubes on the road bike, both require checking/pumping every ride. It's just become part of my routine.
Rides4Beer is offline
