Lack of comfort.
Quoted: 722 Post(s)
Liked 353 Times
Lack of comfort.
my cx bike is beating the heck out of me..can fit up to 35-37
running 32 now but simply a bear. no relief. my roady is far more comfy.
Bikes: Indeed!
Quoted: 1504 Post(s)
Liked 3,442 Times
Could it have to do with riding them on different terrains? Is your cx bike just as uncomfortable on the road? What's your weight and tire pressure?
Brent
Brent
Sunshine
Quoted: 10899 Post(s)
Liked 7,390 Times
Run 37s if they fit...that 5mm is a lot in terms of % more volume.
...or maybe the frame is unforgiving and not an ideal design for how you ride?
Quoted: 722 Post(s)
Liked 353 Times
tried 80psi on 32.
not sure how low is safe.
even on the dirt it is just a bear.
fast fun but beats the shat out if me.
Non omnino gravis
80psi off-road sounds extreme--- I run 70psi on-road in a 30mm tire, and I weigh 97kg. Off-road in a 35mm tire, I'm running high 50s.
So the high pressure is probably part of it. Construction of the tire is also a possible factor. If the road bike is carbon and the CX bike is aluminum, that would be significant as well.
Tire pressure and tire construction make lots of difference, wider tire at lower pressure will not necessary be more comfortable.
I was actually very pleasantly surprised to find out that on my bike Continental GP5000 32 mm at 60/62 PSI (front/rear) feel significantly more comfortable than Clement X'Plor MSO 36 mm (some strange 30 TPI non-TL version that came with Jamis Renegade) at 40/42 PSI. This is for ~190-200 lb rider + bike weight.
Quoted: 722 Post(s)
Liked 353 Times
70 PSI for 35 mm tires (which are probably even wider in real life - did you measure their real width on your rims?) for off-road riding seems very high to me. Unless you are very heavy. 80 psi on 32 mm is also very high. I know that at my weight it is teeth shattering high even on bad pavement (I used to run exactly this pressure for some time).
If you're concerned about underinflation, err wide with the tires. It makes no sense to err svelte with equipment if that runs against optimal setup.
On my bike with 35s, at my ~200lb bike+rider weight, I use about 60PSI rear and 50PSI front even on good pavement.
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
This may sound like a dumb question but have you checked the sidewall of your tires to see what the pressure range is for them? I run my 37mm x 700 on my Topstone at 45lbs front and 48lbs rear. Just a thought to look at and see if there is a recommended range.
Frank.
Frank.
Quoted: 722 Post(s)
Liked 353 Times
i seemed to have goofed 75psi is max...on the tires.
may explain the poor riding experience.
60 -65 psi will be the next try.
thanks guys.
Randomhead
Liked 3,664 Times
If you are worried about comfort on gravel those tires are too small for you. I went to 38mm and run them at about 30psi. It's more of a stability concern than comfort, but it can't hurt
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I do go a bit less on my front tire if you want more comfort. If going through water shows a thinner contact patch on my front tire, I figure its over inflated...
Likes For chas58:
Quoted: 722 Post(s)
Liked 353 Times
you know about the tire presssure chart? 60psi on 32mm looks like a good baseline for you. Personally I think this chart is a little low for what I want on the road, but works well for gravel. Or do what the CX guys do - lower pressure until you hit a rim, then bring it back up a little bit. ;-)
thanks..
I am potato.
Quoted: 1764 Post(s)
Liked 1,577 Times
Car dependency is a tax.
Very advanced pressure calculator (after registration): https://info.silca.cc/silca-professi...ure-calculator
