First cycling shoes
First cycling shoes
Old 08-30-11, 07:16 PM
thatguy512
thatguy512's Avatar
Bikes: Dawes Lightning 2300
First cycling shoes
Hey i got my first pair of cycling shoes.Lake cx165
Im trying to put my spd cleats on(2 bolt design) and after i take the insole out theres a part covering the 2 holes on the outside of the shoe i cant pull out.Do i have to cut it out to put the plate in the inside of the shoe?I thought i should just be able to pull it out
thatguy512 is offline
Old 08-30-11, 07:32 PM
llamont
llamont's Avatar
Bikes: Trek 5900 and Specialized Hardrock Disc
Hello:
Have you tried taking out the insole before trying to remove the mounting plate?
llamont is offline
Old 08-30-11, 07:34 PM
thatguy512
thatguy512's Avatar
Originally Posted by llamont
Hello:
yup i said i took out the insole then theres another piece glued into the shoe and the square covering the mounting plate is like it has to be cut
Old 08-30-11, 08:20 PM
thatguy512
thatguy512's Avatar
omg i screwed up and didnt tighten the bolts enough on my shoe and now the cleats are stuck in the pedals.How do i get them out?
Old 08-30-11, 08:44 PM
1nterceptor
LET'S ROLL
1nterceptor's Avatar
Bikes: 2014 BMC Gran Fondo, 2013 Brompton S6L-X
Quoted: 306 Post(s)
Liked 44 Times in 33 Posts
Are the pedals attached to the bike? If they're not, I think it will be easier to remove them
if they're on the bike. If you have the most common SPD cleats, there are 3 ways to release
them from the pedals. Heel out, heel in and heel up. Try all three. If you're still having
problems with the mounting, try posting some photos so it will be easier for members to see
the exact problem(s).
1nterceptor is offline
Old 08-30-11, 10:06 PM
thatguy512
thatguy512's Avatar
I got them off with a screwdriver and praying i wouldnt take off a finger haha.I learned the hard way that i should get help before i do this stuff
My mounting plate got messed up in a way that it strips screws when you use them so i had to flip it over and pray the screws hold.
TallRider
Bicycle Mechanics
4
01-09-17 09:23 AM
spectastic
General Cycling Discussion
3
03-18-13 04:54 PM
WalksOn2Wheels
Commuting
16
01-31-13 07:17 PM
SactoDoug
Road Cycling
59
10-17-10 06:20 AM
KCanini
Road Cycling
19
09-06-10 08:58 AM
