Do you put patched tubes back in your saddlebag?
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4335 Post(s)
Liked 2,977 Times
I have a drawer with new tubes in boxes, never been used.
I have a hook in the ceiling with tubes that have been used but never patched.
I have another hook in the ceiling with tubes that have been patched and tested.
I have another hook in the ceiling with tubes that need to be patched.
I have another hook in the ceiling with tubes that have been patched and are awaiting testing.
I have another hook in the ceiling with an old wheel and tire that I use for the testing.
I only put unpatched ones in the saddle bag... probably over-cautious.
I have another hook in the ceiling with sew-ups... for a different thread.
Quoted: 836 Post(s)
Liked 1,058 Times
It puzzles me how many folks will not use a patched tube. Most people in my cycling group throw the punctures away. I began collecting and patching them. I couldn't give them away. Nobody wanted a patched tube. I finally had to give a box full to the cycling charity even though I've kept a lifetime supply. Very little group riding this year for me so I guess they are all going to the landfill. Seems wasteful....
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,203 Times
If someone is going to have a problem with patches, they probably won’t be Rema. Rema uses chemistry to make the bond between the patch and the tube. Other patch systems use physics to make the bond. Chemistry trumps physics.
Stuart Black
Stuart Black
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
I would think a big difference confirming seal and no leak, between eg. the 80 or so PSI you would be testing within a tire/wheel, vs outside a tire/wheel where probably 10psi would be pushing it?
Likes For Sy Reene:
Quoted: 1062 Post(s)
Liked 665 Times
Physics is buying a patch kit that works.
j/k of course. I have 5 chemists in my family, including my spouse and both of my parents, so somebody has to stick up for physics, but we try not to get too tribol about it.
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
I'd reinstall my patched tube back in the tire and return the new tube to spare status.
This way you can prove your patching prowess while still retaining a new spare tube.
Once patching prowess has been established, yep I'd keep the patched as the spare in future.
Barry
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times
In many decades of carrying patched tubes in a saddle bag, I've only had one problem where I creased the patch and it cracked, perhaps after nearly a year in the pack. One more voice here to keep the patch as flat as possible. And another voice for quality patches, unlike that one I used.
Also protect the spare from loose tools in the saddle bag. I store mine in the toe of an old sock.
In my experience they all work the same, with the same sort of "glue" and patches. I never came across a set that had "rubber cement" or any glue that wasn't functionally identical to the "glue" in the Rema sets.
Likes For Racing Dan:
Liked 4,203 Times
Failures with the Rema can happen but they are usually due to user error. Failures with rubber cement is due to bond failure.
Stuart Black
Stuart Black
I have a hard time believing this? For almost 4 decades I've been patching tubes, using the exact same technique, using all sorts of generic sets and never had issues. All of them had a tube of glue that worked just the same as the glue in the Rema sets. - the stuff that needs to dry before applying the patch, AKA vulcanizing fluid/solution. Maybe you are just reading the generic blurb on amazon?
I once had a tube failure with the patched tube in my saddle bag so I now put the patch tube back in the wheel at home, plus I know it's good if it lasts overnight. I've since figured out why the patch failed (cheap glue), but continued this process.
If the patched tube has been tested in a wheel for awhile, I'd be OK to keep it in the saddle bag.
Likes For katsup:
SE Wis
Quoted: 2741 Post(s)
Liked 3,388 Times
Liked 4,203 Times
Both can be messed up but rubber cement tends to fail even if you do every thing right.
Stuart Black
Stuart Black
No. I’m not “reading the generic blurb on Amazon”. I’ve read the MSDSs for the materials. I’ve read papers on cold vulcanization and the chemistry of that cold vulcanization. I’ve also read things about how rubber cement works. Yes, rubber cement is applied in the same way that vulcanizing fluid for Rema patches is. Yes, they both have to be allowed to dry completely. And, yes, rubber cement makes a fairly strong bond that forms instantly but the similarities stop there. The vulcanizing fluid continues doing chemistry which the rubber cement doesn’t. But you aren’t going to see that chemistry happening because it is happening at a molecular level. You will see the difference in the quality of the patch job, however.
Patches just doesn't fail in my experience. I just counted 18 patches on 8 tubes I have lying around and an unknown number on the tubes already in my wheels. All perfectly fine and Im guessing only a few (if any) Rema jobs. Some are many years old, Im betting at least a decade, or even two. IME, it amounts to FUD claiming only Rema will do because of special sauce chemistry and every one else supposedly using inferior "rubber cement".
Btw, if anyone cares.
You can glue small punctures with superglue, no problem. Just make sure the glue enters into the hole by stretching it a bit, and make sure to not glue the "other side" of the tube to the "side" with the hole.
Quoted: 1104 Post(s)
Liked 1,824 Times
Replaced a flat during a ride with a new tube from my saddlebag. Brought the flat home and found the hole. Patched it. Is it safe to put it back in the saddlebag for next time or does folding it ruin the patch or cause it to tear or or anything?
I would obviously roll up the tube so the patch wasn’t on a bend but...
Thoughts?
and to be clear sure I could take out the tube I replaced with yesterday and the put the patched tube back in the tire and roll up the spare tube again and put it back in my bag but man I just don’t feel like it!
Thoughts?
The reason being is there's no better way to insure a patch will hold than to re-install it in the tire and bring it up to pressure. The bonus is that you have a demonstrable way to see if it's holding air, ie check it prior to each ride. If time is of the essence I will install a new tube (after finding the reason for the puncture) and continue. Once I'm home I'll patch the punctured tube and switch it with the new one I installed on the road, then put the new tube back in my saddlebag. That way I know for sure that both are good.
Quoted: 83 Post(s)
Liked 64 Times
I patch tubes at home and always put the patched tube in a saddlebag. It's not uncommon to give it to another rider who's stranded. It's no big deal to give away an old tube and I always have a patch kit in my bag for those real unlucky days. I've never had a patch fail and most of my tubes have multiple patches.
Liked 4,203 Times
I’m not sowing any more fear, uncertainty or doubt about off brand patches then they deserve. My conclusion about Rema’s products aren’t based on anything information that the Rema has produced. I had to search far, wide, and for a long time to find the information I have found. It’s buried in material safety data sheets (MSDS), patents, and scholarly articles. I’ve had to do a whole lot of research to learn what I have about how the cold vulcanization process works and how Rema uses it. Based on what I have learned, I’m the one making the claims, not Rema. I tell people what I have learned to help them be confident in a patching job so that there isn’t even a question like the one raised above. Just look at the responses above as to how many people don’t trust their patch jobs
Rema doesn’t go shouting that their system is better than others. Their website is understated to the point of being boring. Slime’s website, for example, is flashier and makes more claims than Rema does. Rema isn’t the one tooting their horn. People who use the product...from bicyclists to automobile tire repair shops...are the ones tooting the Rema horn.
Stuart Black
Stuart Black
Quoted: 6177 Post(s)
Liked 4,795 Times
I suppose another factor might be how often one flats. I'll go well over a year sometimes two years. Not sure what my personal best is for time between flats. But many times when I might have patched a tube on the road, I found my cement too dried up in the previously unopened little tube.
Also as I don't flat very often, I certainly don't get a chance to keep my skill with patching up to par. Though I know for those that do it regularly it's simple and foolproof.
For me it's not foolproof. And that is why I prefer to make a $4.00 new tube my first choice. Though I have occasionally put a patched tube back in my tire, I still find too many uses for old tubes around the house and workshop.
$4.00 dollars once every few years isn't going to break the bank for me.
Likes For Iride01:
This conversation weird.
My current $2 kit, from an auto parts store, that Ive been using for more than a year has a tube that says "rubber solution". I glued one more patch to a random tube, to make absolutely certain Im not blowing smoke up your backside. It too instantly fused to the tube, as expected. As noted I've never seen such a patch job fail later. Cant imagine what ppl are afraid of or what they do to make it not work.
YMMV ... :-)
YMMV ... :-)
Liked 4,203 Times
YMMV ... :-)
YMMV ... :-)
As a rule, I don’t reinflate tubes after patching...at least not for quite a while after...because the patch will pull away from the adhesive due to the different properties of the rubber used for the tube and patch. But after a Rema patched tube has time to react, I have no issues with inflating a Rema patched tube outside of the tire to as large as it will go, days, weeks, months, or years down the line. The patch holds because it is fused to the rubber of the tube through new rubber bonds. A rubber cement patch will often pull off under that kind of strain and is more likely to do so with age.
I know you aren’t trying to blow smoke up my backside but realize that I’m not doing that to you either. I’ve had probably more experience with patching tubes than most anyone else...ten years at a co-op with thousands of tube patchings. I knew what worked before I got to the shop and my experiences there have simply confirmed what I already knew. I have no issue with putting a repaired tube in a tire. I have no issue with putting a tube that has been patched up to 30 times in a tire. Most of my tubes last at least that long and it’s not the patches that kill the tube. It’s usually the stem that gives up the ghost.
Stuart Black
Stuart Black
It's MY mountain
Liked 2,977 Times
According to the patch proponents in this thread, there is essentially no difference in value between a properly patched tube and a new one.
I.e. it's exactly the same deal to give away a new tube as an old one.
I've given away a few tubes, but most of the ones that see time in my saddle bag go in my own tires.
Likes For AmelieGagnon:
