Frames and Framebuilding (1986) Frame Flex Testing and The Tarantula
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 436 Post(s)
Liked 3,471 Times
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
Likes For SpeedofLite:
Quoted: 1829 Post(s)
Liked 3,374 Times
Good to remember that there has long been a recognition that some flex can be a good thing, or at least a benign thing.
I can't help but wonder what became of the Tarantula. They certainly spent a fair bit of money on it! I don't remember how long they published stiffness numbers in their bike reviews, but it doesn't seem like it was very long. A few years, maybe?? Anyone still have any of these reviews?
Steve in Peoria
Steve in Peoria
Expired Member
Quoted: 3665 Post(s)
Liked 5,416 Times
I'd like to suggest that you begin a thread in the Bloggers section. Each time you want to post a copy of an old article you can add to the thread. Folks could find them more easily and it could serve as a resource going forward.
Likes For shelbyfv:
Bikes: 1st Track bike: 1978 Speedwell titanium 1st Road bike: 2001 Independent Fabrication Crown Jewel
Quoted: 97 Post(s)
Liked 116 Times
Interesting read but what struck me most was the bad math! The author suggests that the difference between 1.8 % and 3% is just 1.2%
Say what? 3% is almost DOUBLE 1.8%
Quoted: 436 Post(s)
Liked 3,471 Times
Biological scientists typically talk about absolute vs relative difference. In this case, an absolute difference being 1.2% as the author wrote, and a relative difference (as you point out) being 66.7%.
Finance types use basis points, at least in part, to eliminate confusion. They might say the difference was 120 basis points when talking about a disparity between two figures expressed as percentages.
Liked 3,374 Times
to say "just 1.2%" suggests that frame stiffness might have values over the whole range from 0% to 100%. If they were made out of actual wet spaghetti, this might be true.
To express the stiffness in context of the range of what they had measured would have been more meaningful.
Steve in Peoria
My modern BMC road machine flexes noticeably on the trainer. It is enough to sometimes lightly kiss a chain link to the front derailleur and on a couple occasions with high wattage sprint efforts - a ghost half shift.
I'd prefer a stiff bike if it were to stay put but then there is the whole comfort factor to contend with.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
One curiosity that I remember from that period of testing was that the Centurion Carbon and the Specialized Epic Carbon road frames were the most- and least- (respectively) flexible frames that they had yet tested, at that relatively late point of their testing period.
The Centurion Carbon frame had carbon-wrapped, standard-diameter aluminum main tubes, while the Epic had oversized carbon main tubes that were fitted into lugs with both internal and external lug support.
And I've owned and ridden both extensively, both ride well but I prefer the Centurion for rides having rougher surfaces.
My Centurion Carbon also has a Look fork on it, which is likely stiffer than the aluminum original.
Quoted: 3464 Post(s)
Liked 2,829 Times
I'm curious now, how do engineers usually express it? Did Redcay have an engineering background?
I don't care for Hype.
I am curious. For frames below say, 58CM, does frame flex out on the road ever even get noticed outside of maybe, loaded touring and bike-packing bikes?
Because, maybe on a trainer, I can tell there is flex, on the road, I can almost never, ever tell there is flex, unless on my SS touring bike with a heavy, heavy case of Coor's Banquet on it after a long ride beforehand.
Thanks for sharing this! The article references a table of deflections based on bikes they've tested in the Tarantula - any chance you could post that as well?
Quoted: 834 Post(s)
Liked 2,125 Times
Excellent point. At the risk of an unnecessary tangent, I notice you list a '78 Speedwell Ti track bike in your profile. (We must be a rare pair to own both a Speedwell Ti and an '85 De Rosa.) My '73 Speedwell Titalite is fun to look at, and soaks up the road, but it's an overcooked noodle. It doesn't instill confidence, especially on rough, twisting descents--not like the stiff, SL-tubed De Rosa. How does your Speedwell manage on the track? Sprinter or more of a pursuit bike?
Quoted: 436 Post(s)
Liked 3,471 Times
https://www.bikeforums.net/classic-v...ite-bikes.html
This Road Test article shows columns of Tarantula data for all of the featured bikes as well as for two "generic" steel bikes, one made of Tange No.2 and one made of Reynolds 753.
Quoted: 834 Post(s)
Liked 2,125 Times
Likes For gaucho777:
Quoted: 97 Post(s)
Liked 116 Times
