Most comfort on a gravel bike?
Hi. I'm looking to get a really comfortable gravel bike that I can take through rocky terrain with the least impact going through me as possible. How do people achieve this?
ignominious poltroon
Quoted: 2245 Post(s)
Liked 3,449 Times
With full suspension mountain bikes.
For gravel bikes, the best bet is wide tires at low pressure. There are also some suspension stems and seat posts, like Redshift, and some forks, like Lauf and gravel-specific shock forks.
Likes For Polaris OBark:
Likes For dsaul:
Quoted: 1821 Post(s)
Liked 1,697 Times
My Canyon Grizl came equipped with 700 x 45 tires which are pretty big for a gravel bike. On unpaved roads and mild single track it rides like a charm, but on more difficult terrain you can really feel the bumps. This bike also comes in a version with a suspension fork that I would have chosen if I didn't already have a full suspension mountain bike
Quoted: 1088 Post(s)
Liked 1,028 Times
There are newer design carbon "suspension" seatposts that are designed to not really move like spring posts but instead have more flex to them, they will help with some, otherwise my gravel bike comfortably runs 29x2.1 tires, it does help a lot with the bumps.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1953 Post(s)
Liked 1,475 Times
Many newer gravel bikes allow really wide (> 2") 650b tires, which would be more comfortable through rocky or very rough terrain.
Quoted: 286 Post(s)
Liked 262 Times
I’ve had 5 or so gravel bikes last 10 years. Got a mountain bike recently. For me, it’s way more fun on slightly technical terrain (where I live) and I feel better after (my body) and find myself smiling more. YMMV
Quoted: 3245 Post(s)
Liked 2,093 Times
After you go the widest tubeless tire route, you deal with handling issues on drop bars. Flat and wide mt. bike bars are better for control. The biggest issue I get on my gravel is hanging on to the drop bars.
Polaris's answer of a full suspension has merit.
Quoted: 1402 Post(s)
Liked 1,893 Times
agree with many comments above - including wide tires and related etc ... most times wider tires with sufficient volume can be sufficient
I’m not a fan of suspension unless you really need it ... can be PITA (of course that has not stopped me from having bikes with suspension ... grin)
however - given that - there are some ‘gravel’ bikes that feature front and / or rear suspension (sorta/kinda) ... including
Specialized ... Specialized has the ‘future shock’ or something (?) ... funky head tube / headset mounted sorta / kinda suspension thing (?)
Cannondale has a Topstone with a lefty short travel fork - and a Topstone model also with the rear ‘kingpin’ suspension (?) ... before that Cannondale had the Slate with the lefty suspension fork (disclaimer: I have a Slate)
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
Yes, a MTB will be better/faster on that kind of terrain, and that can be a ton of fun (part of my regular cycling diet). However, I also get a lot of enjoyment from the challenge of riding my gravel bike on a lot of those same trails, and having to be more purposeful with control of the machine.
Likes For Eric F:
Party Pace!!!
Steel is real my dude....for me a steel grav grav bike will always be more comfortable than a comparable aluminum bike.
Likes For 4130NewJersey:
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Salsa Fargo steel frame is my Gravel bike. I have 2 separate wheel sets, both 29”. One set has 2” for more pavement and light gravel rides, the other 2.8” for rougher off-road stuff, . Run them tubeless and lower pressure.
I also put a Redshift stem and seat post suspension on my Fargo. Most comfortable bike I own. I ride it pretty much everywhere on every type of surface.
got the climbing bug
Bikes: one for everything
Quoted: 633 Post(s)
Liked 915 Times
wide carbon wheels, 50c tire and carbon seatpost that flexes. I use the Roval Terra w/ setback. Feels so good.
Rule #10 // It never gets easier, you just go faster.
Liked 1,475 Times
Good call on the flexing seatpost. Other candidates include the Syntace P6 HiFlex (on my gravel bike), Cannondale Save (on my road bike), and Canyon VCLS (may be the flexiest of them all). 50c tire rides nice but is heavy.
Likes For SoSmellyAir:
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Yep, steel FTW. I have a 650B gravel rig and a 700c, both steel. Nothing beats a lively, compliant steel frame. Then put the biggest tires you can fit, tubeless, low pressure (I run as low as 18-19 psi on my 650B for gnarly rocky SoCal singletrack). The rest as stated above is in your arms and legs. And possibly above all, learn how to pick really good lines!
Quoted: 426 Post(s)
Liked 274 Times
If you can afford N + 1 bikes get a full suspension MTB bike. By the time you put huge heavy tires and low psi you are going so slow you don't need the aero drop bars might as well just be on a flat bar MTB bike.
If you really want a huge gravel bike get a poseidon. They accommodate huge tires and gearing.
https://www.poseidonbike.com/
from their site
Wheels
12mm Thru-Axle 32h Tubeless Compatible Rims Laced to Sealed Cartridge Hubs. Internal Rim Width: 26mm. We Recommend 30mm Tubeless Tape. Hub Spacing: 100mm front, 142mm rear. Minimum tire recommendation 650b x 42, Max tire recommendation 27.5 x 2.6. Max tire size can range based on the tread of the tire.
2.6 inches is a lot on a gravel bike.
My friend seems to like his.
from their site
Wheels
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 275 Post(s)
Liked 244 Times
in short XC Mtb stuff on a Gravel frame.
longer version 650b wheel with 50-584 or 52-584 XC tyres rather than gravel. The XCs are more supple and have better/lower rolling resistance as far as I'm concerned. The larger tyres deal with biggest stuffs and then the vibrations need to be dampened like on a cobble bike (Paris Roubaix thingy):
1. redshift stem works well
2. double handle bar tape or thick silicone tap
3. Canyon/ergo Seatpost or Swork CGR Seatpost
4. good saddle which is a personal thing.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
me too
from their site
Wheels
from their site
Wheels
A Topstone Lefty with 650b wheels and wide tires will do the trick..
and I can unequivocally say that my new Topstone Lefty Carbon 1 is the most comfortable gravel bike I have ever ridden...period!
