Why was Chromoly phased out?
#101
Quoted: 6963 Post(s)
Liked 10,961 Times
Regardless, it’s pretty clear that Chro-Moly has not been “phased out.” I can walk into my LBS and verify that.
Likes For Koyote:
#102
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
CroMo is now the distant 3rd in the material of choice, and probably not far ahead of Ti in the higher end market.
#103
Liked 10,961 Times
#105
Quoted: 1324 Post(s)
Liked 927 Times
This is the main sticking point to the “dropouts can be replaced” comment. If the frame is of brazed construction it might be replaceable. Replacement on a brazed frame would depend on how much the owner is willing to spend. Not all brazed frames are worth the cost.
If the frame is welded ...which is how the vast number of frames of either steel or aluminum are made...replacing the dropout isn’t usually an option. You can’t really just heat it to remove the dropout like you can with brazing. You would need to cut the dropout out, drill out or cut out the dropout tab in the frame tubes, clean up the ends, and then weld in a new piece. It would also be something that is going to require significant frame alignment. Most welded frames of any material just aren’t worth the expense if it can even be done.
Cheers
#106
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
It hasn’t been “phased out,” but the OP is correct to at the very least say it’s been “phased back”. In the early-mid 90s, if I walked into a random bike shop, almost every bike would have been built of some form of steel alloy. What bikes of other materials that were available, would have been in display cases, or the shop window with a crazy price tag on them, and with no more guarantee of them being the future of cycling than Softride frames or spinaci bars or spinergy wheels.
#107
Likes For frogman:
#109
So why pick heavy steel over light aluminum? I agree that people probably won’t have a frame fixed on tour so picking steel because it is “repairable” is more of a romantic notion than a reality.
You do know that the same schools that teach welding teach people how to weld aluminum as well, don’t you? MIG and TIG welding were invented for aluminum. Aluminum can be brazed as well. There are a multitude of techniques that can be used for both materials.
The need to heat treat depends on several factors. Tube joining requires heat treatment because of the heat applied. Crack repair is quick and affects a smaller area. Repairs on broken both steel and aluminum frames should be considered temporary.
I’m not sure what your point is but I agree that none of it really matters. Both materials can work well for touring bikes but one is looked down upon mostly because of ignorance.
The reason for the few aluminum touring bikes being offered is because of that romantic village smithy repair scenario. Bicycle tourists don’t want to buy aluminum because they think the material is inferior so aluminum touring bikes don’t get made. Because they don’t get made, people don’t buy them and steel bikes keep getting made. Gravel biking and adventure bikes are changing that but touring bicyclists are a curmudgeonly bunch.
Oh, please! Just because someone rides one of the few aluminum touring bikes that do get made doesn’t mean that they aren’t “real” bicycle tourist. Cannondale made touring bikes for nearly 30 years that have been ridden all over the world in the same places as steel touring bikes have. I have 10,000 miles of tradition loaded touring on two Cannondale touring bikes (one about 8000 miles). I have another aluminum road bike that has 25,000 miles on it. They are tough bikes.
Go take a tour along the large river routes in Europe and you'll see what I mean. Lots of folks riding smallish distances from town to town and staying in B&B's for the night. I know I didn't write those people weren't actual bike tourists because I checked. It's its own type of touring which is very common in Europe. It's not better nor worse. It is what it is. But the bikes used for that aren't world crossing calibre most times because of the low end suspension forks, typically straight bars (though the butterfly bar is common. Not a fan of that but it works), no option for front bags etc etc.
Don’t make out steel to be more than it is. Aluminum may not be impervious but neither is steel. Riding a bike into a mountain (or a wall or a car) is usually going to result in damage to the bike. I have a pretzeled frame in my garage (and a very ugly scar on my knee) from an encounter with a car nearly 40 years ago. The frame material wouldn’t have made any difference in terms of how the bike did,,,or didn’t...survive the crash.
I‘ve also crashed aluminum bikes more times than I can number without damaging the frames. Frame damage is more dependent on the speed and angle of impact than the material.
I’ve ridden and heard many creaky steel bikes. Creaks aren’t do to the material, they are due to the parts in the frame. Creaky bottom brackets are due to loose bottom bracket not the frame material.
Millions of mountain bike riders have a thing or two to say about the “weakness” of aluminum. Steel isn’t as hard to break as you seem to think. I’ve broken both...multiple and equal times. I’ve had a steel mountain bike that broke at the steer tube at fork crown, cracked at the chainstay bridge, broke at the dropout, and finally cracked a second time outside of the weld repair at the chainstay bridge (so much for steel welds holding up over time). I had another steel mountain bike that broke at the rear dropout. I didn’t even attempt to get that one welded since Specialized replaced it no questions asked.
Finally, if aluminum is as weak as you seem to think it is, do you tour on steel rimmed wheels with steel hubs? Do you tour with steel handlebars, steel cranks, all steel pedals, and steel brakes? If you fear the weakness of aluminum, why not? I’ve broken aluminum versions of almost all of them but I don’t fear that they will break on me to the point where I would trade them for steel versions.
But typically the bars / stems I use are cheap and heavy and made of thick tubes so they're not that big of a worry for me. Also bars/stems get replaced way more often than the frame so that's also one reason why I don't worry about them. They also get inspected more often than the frame since I swap bar tape at least once a year. And typically I'll swap a bar every five or so years especially in mountain bikes. Partly because of service life but also partly because I like trying out new things. Not in frames though, frames are expensive.
Cranks are made of pretty thick stuff. Some aren't even hollow. A slab of aluminum doesn't really worry me that much.
For pedals the ones I've used for touring have had significant portions of steel parts I think... But pedals get broken often enough that fatigue life never gets to be an issue. But the axles in my pedals tend to be steel and that's the weight bearing part.
Steel hubs is an interesting idea actually. I've been doing some preliminary drawings of an aluminum hub shell with replaceable steel parts for the most wear prone points such as spoke flanges. Also it'd be neat feature to have a pressfit cavities for either cartridge bearings OR ball bearing races. User's choice. That'd be a pretty cool touring hub. But anyways hub failures do happen even if they are infrequent. That can be mitigated by using a well designed but with enough material and enough spokes with responsible spoke tensions.
For rims the part that is most prone to suffer fatigue damage is at the spoke drillings and that has sometimes been mitigated by using steel eyelets. Nowadays for examble DT Swiss is moving away from eyelets and towards using nipple washers to increase the spoke stress surface area.
That's also one thing I've been musing about. Would it be possible to build an aluminum and steel hybrid rim where the spoke bed is reinforced with a steel strip and would that be way too heavy to be viable. If it were viable, it could potentially significantly increase spoke tension tolerances = more durable wheels.
But in the end with aluminum it comes down to material thickness. The more you have to mitigate stress the more durable said part is going to be. But the end result is also always more stiffness which in some places is desirable (rims, cranks, handlebars, stems, hubs etc.) but in some places not necessarily as much (fork blades). More material also means more weight which is why I dislike the idea of ultralight aluminum parts. If I want something to be light I'll buy carbon fiber. But I haven't really gotten to a point where I'd want any of my bikes to be lighter even though none of them are light.
And to close, all of the parts you mentioned are easy and quick to replace. The frame on the other hand is a bit of a faff if it breaks. Doesn't take just one special tool, it takes all the special tools. And no one one tour carries all of those.
#110
Quoted: 3352 Post(s)
Liked 1,056 Times
IMO steel is real and 100% better than the high priced plastic bikes bike stores are selling today. At the Air and Space Museum there are steel bikes make by the Wright brothers that are 120 years old. I bet that in 120 years any of the plastic bike built today if still around, will be so fragile that a good thump would cause them to shatter.
#111
Seriously, though, I have no dog in this fight. Folks should ride what they like, whether steel, Ti, carbon, or anything else.
Likes For TobFromme:
#112
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Plastic is not an accurate description of a Carbon Fiber frame. I'd expect the resin matrix used to bind the Carbon Fibers will likely be degraded by UV exposure over the decades.
#113
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
is that you’re more likely to find a machine shop or welder who can work with steel in the event of a breakage, whereas if you break an aluminium frame in the middle of nowhere, you’ll be hitching a ride to the nearest airport to find a welder who deals with aluminium.
This again needs a little qualification, however, because once again it is simplistic and assumptive. A rough-welded repair to a steel frame is never to be as strong as the original build, and a heavy-handed welder is as likely to blow a new hole in your steel frame as fix an existing one. In reality, a frame structurally compromised in an accident will either need replacing or attended to by a professional framebuilder, regardless of frame material. A local welder might well fix things up enough to get you to the next city, but they’re unlikely to restore your bike to its former glory.
...and can be fixed in a pinch by any mechanic with a blowtorch.
The logic goes that you’re more likely to find someone who can fix damage to your frame en route if it’s made of steel, rather than aluminium. That’s true to some degree but a lot depends on the skill of the welder and the severity of the problem.
In Cambodia, we were able to find a welder who could fix small cracks in our steel frames. The cracks were then repaired a second time in Australia. At the same time, we had some of the drop-outs and mounting points for luggage racks repaired as well. They had corroded away.
It was nice to be able to repair our much-loved bicycles. It’s also possible to argue that we might not have faced these problems in the first place, if we had chosen an aluminium frame. The cause of the cracks was a small welding error when the bikes were initially built, while the corrosion was caused by paint rubbing off our steel frames, allowing rust to set in.
the fact remains that chromoly frames are easier to repair than aluminum frames. You have a multitude of repair techniques available but the more common ones are mig welding, tig welding and brazing. Now a welder with a modern degree in welding in the western world will likely to be able to repair almost any part of a bicycle frame even at its thinnest part by mig or tig welding it. Welding is a craft and there are schools to learn it. It's not something at all obscure. Brazing can be done by sleeving or just if it's just a crack filleting.
If you break an aluminum frame there aren't many shops which are able to weld the frame AND heat treat it. Because that's what aluminum frames typically require after welding: heat treatment.
Availability. Also weight is relative as you well know. Steel is three times heavier but also three times stronger than aluminum which in turn means you can make a steel frame three times thinner than the aluminum frame. But it really comes down to design choices and factors. I chose steel because it's reliable and I've had good experiences with steel frames. I've had bad experiences with aluminum frames so I try to avoid it as a frame material for bikes that get ridden in challenging conditions.
Chicken meet egg. Egg meet chicken. Steel bikes are available because people are afraid of the (supposed) delicate nature of aluminum so they don’t buy aluminum touring bikes. No demand means that aluminum touring bikes don’t get made.
As for strength, yes, steel is three times stronger than aluminum. It’s also 3 times heavier. However, aluminum frames don’t use 3 times as much material to make up for that strength difference. Manufacturers use larger tube diameters which allows the frames to be made with less material overall and still be as strong.
As for challenging conditions, no touring bike undergoes anything remotely as challenging as what a mountain bike is put through. If new steel road bikes are rare, new steel mountain are almost nonexistent. They probably exist but you won’t find them at your local trailhead.
Again, egg meet chicken. Chicken meet egg. People don’t want aluminum touring bikes because they are afraid of the material...i.e. ignorant of what the material is, how it performs, how it can be repaired, etc. If there are no aluminum touring bikes, people can’t buy them and the myths of steel and aluminum continue to be spread.
I really don't understand where you get that notion of the mythical bicycle tourist. I've never met a single bicycle tourists who fits that description. People in europe tend to tour on whatever bikes they get their hands on and enthusiasts tourists may buy a specific touring/trekking bike. If it's an anglosphere touring bike it'll usually be steel and if it's a continental europe trekking bike it'll usually be an aluminum hybrid with a low end suspension fork.
See above for an explanation of where the myths come from.
I kinda get the feeling you're projecting a bit here. The part about them "not being real bicycle tourists" is your words, not mine.
No. The part about “not being real bicycle tourists” comes from you. You said
...those are called trekking bikes and aren't exactly your world crossing calibre. They're more in the region of going along the Donau with two panniers and stopping at a bed and breakfast every night.
I’ve got loads of scars on my legs and arms from “slipping along in a bit of a grind fashion” on both pavement and rocks. I crash with regularity and have never damaged a frame because I fell over to the side. It highly unlikely you could break a frame that way in any case, since the impact is oblique and thus of lower energy. I’ve also seen a lot of scraped up bikes from fall over crashes and none of them were damaged to the point of disposal.
User error. And I doubt the damage was enough to make the frame unusable.
Creaky bottom brackets are exceedingly rare. Most times the creak originates from somewhere else entirerely (pedal threads, headset, fork, seat tube, wheel dropout interface etc). With aluminum bikes I usually always get a creak from the seat tube. Another common one is dropouts especially with a new bike. My favorite though was trying to combine a steel rear rack with an aluminum frame bike. In the end had to take the rack off because it just would not work well with the flexing of the rear triangle. That's also one thing I dislike aluminum frames for. They tend to either be exceedingly stiff (usually a good thing) or noodly flexy. I've had both and while I prefer the stiff ones the cost is also usually right up there with steel frames.
All of the things you list can occur on steel bikes and are mechanical issues that should be addressed. They aren’t inherent to the frame material.
I suppose that if you get to use the mythical bicycle tourist approach I'll use the "mountain biker" who always buys a full suspension bike to replace the beginner hardtail. So now that all the properly ridden mountain bikes are full suspension they don't experience enought stress to actually break. Idiotic I know, but I just had to give you an example of how it looks when you write about the "bicycle tourist" and romantic ideas of village smithies.
The number of hardtails in use is about equal to the number of full suspension bikes. Neither class experiences large numbers of frame failures, even when put though far more strenuous conditions than touring bikes are.
And your analogy has nothing to do with the idea that steel is easily fixed.
Frame failure of any kind of material is rare. Yes, it happens but it doesn’t happen nearly as much as people think. I have more miles on aluminum than I do on steel. I’m not afraid that any of my aluminum frames of any kind will fail. If they do fail, they won’t do it catastrophically. If they do fail in the field, I’m sure that I can find someone to repair it to get me to the next town or the end of the tour. If I had steel, that’s all I’d expect as well.
Stuart Black
Stuart Black
#114
My 2 cents on frames
^^^^^ This.
Light weight metal framed bikes are expensive.
The rise of automated TIG welding made it easier (cheaper) to mass produce aluminum frames.
A cheap aluminum bike will be lighter than a similarly cheap steel bike, and in most cases, a lighter bike would be preferred, that’s why in the modern bike market, the majority of it is various grades of Aluminum bikes, with steel occupying the only the high-end, and the very cheapest.
My rides include Columbus SLX triple butted1987 Ciocc designer84 micro/cf complete dura ace group. its perfect and for sale, a 2009 Trek Alum super light FX7150 hybrid, a Schwinn impossible to find, 2008 carbon Peloton Pro road bike, ultegra group, a Panosonic DX2000 steel road bike all Shimano 600, and a 2014 Colnogo CX1 carbon, ultegra group road bike. That being said, and in light of the frame thread here, the best frame construction for me is the carbon fiber pair. Each of their geometries are unique, but the ride is smooth and whatever power i still have, goes right to the rear wheel.
For what its worth, rolls eyes.
#115
My bikes became Vintage
I'm not very educated on the subject but I've noticed that I rarely, if ever, see Chromoly frames offered on new bikes these days. Is there a specific reason that it isn't used anymore?
I'm asking because I have a 1999 Specialized Crossroads with a Chromoly frame and I'm curious why the material isn't used much anymore.
#116
Bikes: '87 Paramount & '02 Scapin EOS3
Quoted: 16 Post(s)
Liked 13 Times
Nothing rides as good as lugged steel. Your butt will tell you after a 100mi day. Followed by tig'd steel. It is not used as much in these days of bling & marketing crap as folks need the latest BS that they can pay more for rather than the classiest & best.
#117
Quoted: 195 Post(s)
Liked 207 Times
I've ridden nearly every touring bike of any material in every configuration, (I'm still recovering from a transcontinental jaunt on a recumbent), and have yet to find a best material. My current favorite is a reworked Klein Performance. A close second is a redesigned Nishiki Olympic 12. Totally different bikes but both very competent at fully loaded long distance touring. Put fifty pounds of gear on a bike and you'd be hard pressed to tell what it's made of. Since I need a tall frame, triple butted tubing is unacceptable because of the flexibility but straight gauge cromo works as does super stiff oversized aluminum. With fat tires and lots of gear "ride quality" becomes a meaningless expression. Carbon can be made with whatever ride qualities you prefer but the expense seems unnecessary when so many other possibilities exist. I think the Nishiki cost about $250 with all the upgrades and has just finished a transcontinental tour. Another tourist asked if it was titanium and when told it was '79 Japanese steel, scoffed and stated he tried a steel bike once and got off immediately because it was so heavy.🤭. He was a credit card tourist so maybe he had a point but for me the point was irrelevant. Stripped to the basics I think a full water bottle would easily make up the difference. Just ride, baby!
#118
Steel is Real, as the saying goes
In engineering terms, it's about fitness for use. I would not use it for a race ready road frame simply due to weight. I have ridden aluminum for years. The weight is better than steel but the frame will be stiff relative to anything else. That's fine for racing. For a 100 mile or longer ride, weight comes into play but isn't the deciding factor. Frames that are laid up use (epoxy) resins that are baked. Over time those frames dark harden and contribute to other issues but the ride can be as, or even more vertically compliant than steel. Titanium gives a great ride, great weight, great maintenance and can, like steel, be reworked. Carbon can be repaired, but at a cost and can hide damage until there is a catastrophic failure. Double butted or triple butted CroMoly tubing (where the body of a tube is thinned) is a way to improve vertical compliance (how it absorbs shock headed to the rider) and reduce weight relatively. This summer (amidst all the parts shortages) I decided to do a build with a pull (unused part from a new bike) of a double butted CroMoly frame. Every decision was made with a loaded mixed surface tour in mind and adjustments for how I wanted to ride. I had to find a fork from a different manufacturer that had relatively the same geometry as the fork that the manufacturer would have used if they had it available. It is the same fork used on a well known TREK frame with an composite steer tube on carbon legs and I knew it would be well fit for use. I knew from experience that I would improve vertical compliance this way. I shorted my crank arms to 165 because I was also using a 27.5" wheel with 2.5 inch tires on a bike with the capacity of 29+" and a 3" tire. and this would drop the bottom bracket. I wanted to avoid crank strike. I chose Magura hydraulic disc brakes and since I have just done a test ride in the rain I can tell you it's true that they still stop the bike effectively with little finger pressure. I also went with a 1X Eagle GX SRAM group set. I love it. There are times where I wish I had a tooth or two in between but I have found that I can actually compensate with how I utilize my feet through the stroke. I have a set of bags (including a custom frame bag) all from one manufacturer and have been building up the weight while stretching the distance while I learn how to ride a loaded bike. So, back to the original question: In this application (loaded touring) butted CroMoly is a material of choice. The more I load the bike, the more comfortable the ride becomes. I have been on washboard, ruts, tarmac, crushed gravel, wet and dry surfaces, very poor and rutty roads and steep rough downhills. I made a lot of good design choices around this frame and geometry and this is the most comfortable bike I've ridden on the rough (without full suspension) and equally comfortable on more traditional surfaces. I gave the option to take off my semi smooth tires and run tubeless at 2.5" to 3" and lower pressures which would give me even more compliance. The only other material that I would choose for this application (fully loaded multi surface) would be Titanium and that choice would drive me out of the market price wise or make it impossible to have the quality components that I chose. The next time I build up a real road or gravel/cx bike it will be on a cheap import no name carbon frame, or titanium. I would not ride steel or aluminum for that application. The ride is a far more complex decision than the material you are riding and steel is still very much in use and totally appropriate.... just the opinions of a retiree who has ridden over 40,000 miles in the last 40 years. Good riding!
#119
Other materials (titanium, aluminum, and carbon fiber) became more popular. Why? Good question.
#120
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Seriously, have you ever tried to hang a refrigerator magnet from an aluminum or carbon fiber frame?
Steel is better.
Steel is better.
Likes For livedarklions:
#121
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Once TIG replaced brazing as the primary construction method for bike frames, it didn’t take much for aluminum to supplant CrMo in the mid-range, and eventually most of the bike market. Mid-grade aluminum frames could be made for the same cost as mid-grade steel, but at a lighter weight. Most of the time, most bike buyers would pick a lighter bike, at the same price point.
That’s why, until you hit a certain price point; call it ‘Enthusiast’ as opposed to ‘Consumer’ the vast majority of mass produced bikes will be aluminum.
#122
Touring bikes are still made from steel because steel is tough. Stuff happens on tour. Steel gets nicked notched dented pinched scraped gouged and mostly it doesn’t care.
Aluminum rims break and they break all the time. Americans mostly tour on underweight rims. If you never broke a rim on tour, good for you. The good basic touring rims at the moment are made by Ryde (often sold as Weinmann in US) and weigh 700 grams and up. Hardcore world tourists do still use steel rims for the reliability and because they can get them in faraway places. Many posts on these forums by those using steel rims.
In what universe are steel dropouts readily replaceable? In the world of not so long ago. Say sixty years ago. Any better bike shop could do the job and any shop could refer to the mechanic in town that did. Dropout replacement was considered a normal repair. Sadly this is no longer true.
Things break. People break things. Steel survives pretty well. If you tend to break things you know who you are. Lots and lots of people fit in the category. Those people will continue to ride steel.
Then there is the ride. Most here have never even been on good steel. How many have been on a Reynolds Super Resilient fork blade? A Kaisei Toei Special? A Reynolds Diadrant? The vocabulary and possibility of steel is very large. Still mostly unexplored. Other materials are used because fashion and marketing and only afterwards do reasons emerge. Engineering and science are always driven by exterior factors.
#123
Quoted: 344 Post(s)
Liked 297 Times
Kids bike/$99 Big Box bike - cheap steel
Higher end Big Box Bike/low end bike shop bike - Aluminium, some CrMo
Mid-range mass-produced enthusiast bike - Aluminium with carbon fork, some carbon frame options, brand name CrMo (eg Reynolds 520) available from some manufacturers
High end bike, suitable for competition - Almost all carbon, some Ti, high grade CrMo or other proprietary steel alloy (True Temper, Columbus, Reynolds 6xx/7xx), some Al frames with high spec groups (eg, CAAD10 or Spesh Allez with Di2)
Custom one-off manufacturing - Mostly steel, a lot of Ti, virtually nil in Al or CF.
Likes For Leinster:
#125
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
A bike lasting 120 years has nothing to do with the discussion. Also, those bikes aren't ridden, to be clear.
Seriously- why is that a factor in what material you choose for a bike frame? Nobody has walked into a shop and asked to buy whatever bike will last longer than a century because its of no consequence to anyone(but you).
