What is the best Heart Rate Monitor?
Old 01-30-13, 08:52 AM
peterbotwin
I am thinking about buying a heart rate monitor and I'm wondering what everyone else recommends. I want chest heart rate monitor (to connect it with my iphone). What HRM do you recommend and why?
Thanks!
peterbotwin is offline
Old 01-31-13, 05:27 AM
CuriousCurator
I haven't had personal experience with this, but look into Wahoo Fitness BlueHR.
https://www.dcrainmaker.com/2012/01/w...tooth-low.html
It uses Bluetooth LE instead of ANT+. That means it'll work with iPhone 4S/5 (and whatever other phones with Bluetooth 4.0 capability) without requiring an ANT+ dongle. However, it also means that it doesn't work with ANT+ only devices, which is what the majority of Garmin/Polar devices are.
If you insist on using just the iPhone, I think going Bluetooth is the way to go. Otherwise go ANT+ and spend some money on a Garmin/Polar. You should be able to get them used for cheap. Garmin in particular just came up with the new Edge series, so those with upgradeitis may be looking to sell their current device. I myself use a used Forerunner 305 which I bought for $100 with the heart rate strap.
CuriousCurator is offline
Old 02-01-13, 07:16 PM
chinkroadrunner
chinkroadrunner's Avatar
Bikes: 2014 Spec Roubaix SL4 Expert
I have the Wahoo Blue HR and use the Cyclemeter app. It is nice not needing a dongle. iPhone must be 4S or 5, will not work with earlier models. I also got the Wahoo Speed and Cadence sensor that works well. I recommend both.
chinkroadrunner is offline
TimothyH
14
07-19-19 07:54 AM
69chevy
Road Cycling
21
09-23-16 12:49 PM
41mi_a_day
12
05-21-15 01:23 PM
Kojack021
Road Cycling
40
05-25-14 08:27 AM
knoxtnhorn
Road Cycling
2
01-08-14 08:25 AM
