Enve G Series Gravel Handlebar?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Does anyone have this?
https://www.enve.com/en/products/g-s...vel-handlebar/
I'm trying to get a sense for how vertical the brake/shift levers would be mounted on this.
Also, any general user feedback?
Quoted: 713 Post(s)
Liked 796 Times
I don't have them and can't say how the levers actually mount, but I like my levers to be angled on flared drop bars. The are much more comfortable when they are angled and they allow easy access to the brake levers from the drops, where my hands usually are when I need to brake.
Non omnino gravis
Likes For DrIsotope:
Occam's Rotor
Liked 2,331 Times
Quoted: 713 Post(s)
Liked 796 Times
If you only ride smooth gravel roads, you would be fine with regular drop bars. Flared bars give you a wider bar in the drops for better control in rough terrain. The angle of the flare allows your elbows to be in a better position to absorb impacts from roots, rocks, etc. The angled levers also put your wrists in a more comfortable position when riding on the hoods.
I regularly ride MTB trails on my gravel bike and the flared bars prevent the wrist pain that I used to get with regular road drop bars.
Quoted: 1872 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Chases Dogs for Sport
In my experience, at about 140 miles in a gravel race -- with conventional bars -- my hands begin to go very numb. With flared bars (Cowchippers), the problem never arises. Flared bars are less aero, but more ergonomic. It's all about the ergos.
Quoted: 412 Post(s)
Liked 668 Times
I have SRAM Force 1 on the bike and the levers feel perfectly normal....
Likes For Caliwild:
Occam's Rotor
Liked 2,331 Times
I just started thinking about these again, today, coincidently.
(This was because I went into a sizable rut.)
Quoted: 426 Post(s)
Liked 274 Times
Quoted: 713 Post(s)
Liked 796 Times
After several shoulder dislocations (wrestling ) my right should has a screw in it to prevent it from rotating. I can't make my shoulder rotate enough to make my elbows go parallel while riding on the top hats or drop bars ( same reason I can't do forearm plank ). I would love handles bars shaped like this. Do them make them cheaper out of Aluminum ?
Likes For dsaul:
Quoted: 426 Post(s)
Liked 274 Times
I use the FSA Adventure bars on all of my bikes. They have a 12 degree flare and only cost about $40 https://shop.fullspeedahead.com/en/a...handlebar-4531
Likes For sean.hwy:
Occam's Rotor
Liked 2,331 Times
Likes For Cyclist0108:
Gravel Rocks
Another Carbon Gravel specific bar which is profiled that is similar is the Pro Discover Gravel Carbon Handlebar. Di2 routing, similar flare but it is designed to keep the levers more vertical, ergo tops, lighter than Cowchipper Carbon, has back sweep also (neither Enve or Cow Chipper has this) and similar flare to the Enve and Cow Chipper. Shimano reps told me it has 150mm of clampable area (which I have a hard time visualizing with the back sweep and profile) and it's also designed to work perfectly with the GRX groupset including the sublevers.
For me, there are advantages of all 3 of these but would choose the Discover over Enve due to the wider clamping and the back sweep if money wasn't a consideration, and the Salsa cow chipper carbon would be last due to no back sweep or profiled top. I run Di2 but the interior routing isn't that important to me so wouldn't be a deal breaker or maker. Any of these can be found on sale at 20% off if you shop around. I'm acutally considering getting the Discover bars though. I have Ritchey Evo Max on my gravel bike now and they feel great, but would like something with more flare for more technical gravel like DK.
