Truely Yellow Tires, Please...
Bikes: 2012 BMC FS02, 2012 Aventon Mataro (Custom), 2014 Scattante XRL Team (Custom), 1999 GT GTB.
I just bought some Michelin Lithion 2's in "yellow"... Besides being the worst time I have ever had installing a tire, they are definitely burnt orange. For reference, Fizik's yellow bar tape is true yellow. Or even the Mavic symbol on the Aksium Race's. I was curious if anyone else has/seen truly yellow tires? I was just snooping around and Maxxis' Detonators "yellow" seems to be orange as well. Thank you folks. 700c x 23.
Ryan M.
Ryan M.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
I really liked the original Lithions, which are as yellow as it gets. Right now I have the 2's in blue and like them even more. Mounting them has never been a problem.
Thanks for the input. Not sure what it was. One went on fine. Other popped a tube, took it off, re applied, couldn't get it closed up, switched sides and after 2 tries finally got it on. The tire itself looks like it's going to last, just the bright yellow vs. orange-muted-yellow looks a little ridiculous. No problem going back to black if i can't find any. Cheers!
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
Maybe you got a bad batch.
I put the whole wheel with the tube mounted slightly inflated "inside" the tire with the beads outside. Then I use levers to mount one bead, then do the other side. There are a lot of bikes at my house with different wheelsets and it always works.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
so wrong about the lithion yellow. it is banana yellow. the vittorio rubino pro yellow is also bright yellow.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Bikes: 1986 Raleigh Competition (Restored to Original), 1986 Cannonade SR400 (Updated to Dura Ace 7800)
That's strange... I have the Lithion 2 tires and they are definitely yellow.
Has Brakes
Banana yellow is what I'm avoiding it seems then. In comparison, it looks "orange." I'll check into Vittorio Rubino if it's brighter. Thanks! What's the point on spending a ton on a bike and have it mismatched and look like crap.
Quoted: 686 Post(s)
Liked 5 Times
Yeah, I still don't get it.
I've yet to see many bikes posted in there with colored tires (minus the jackass thread).
edit: Spoke too soon, someone just posted a bike with yellow tires.
