Replacing aluminum fork w/ composite, switching from theaded to threadless
Bikes: '84 Paramount, '89 Schwinn 754, '13 Specialized RockHopper, Trek Domane 4.3
Liked 10 Times
This may be an obvious question but want to make sure I know what I'm getting into before I do this.) We have an older Trek 2100 that I'm wanting to replace the stock aluminum fork with a Reynolds composite 1 1/8 threadless fork. I assume I will have to change out the headset. I've already got stems, spacers, cap & pretty much everything else I'd need. I've never changed out headset before. I assume I'll probably need to take it to a LBS to have them change out the headset as I don't have a press. What else do I need to be aware of for this?
OM boy
Bikes: a bunch
Quoted: 510 Post(s)
Liked 639 Times
you might wanna check that headtube/fork/size.
a model name which used for a lot of years
early stuff was 1" threaded, later years were 1 1/8 threadless (with crapon fork)...
if it's 1" you'll need a 1" headset and 1" fork
when you have the right stuff, yes, go to a good LBS and have them install the cups and race.
could be done with simple tools - but better to not screw it up - watch them do it...
OM boy
Bikes: a bunch
Quoted: 510 Post(s)
Liked 639 Times
vast majority of threadless stems are 1 1/8, an adaptor sleeve is used to work with 1" steerer.
Sleeves are commonly available at most any lbs or online - some are overpriced, all are the same.
Liked 10 Times
I actually might just shelve the idea of replacing the fork for now as I'd rather invest the $$ in other upgrades on other bikes or replace the 2100 all together. My wife has been talking about wanting a new bike so we may go that route and Christmas is around the corner. Since I'm looking into the idea, I may replace the steel fork on my old Paramount. Its already using a threadless stem adapter. Plus I've replaced/upgraded about everything else on it so it would really make more sense to do that one between the two.
bike whisperer
Quoted: 1526 Post(s)
Liked 718 Times
Unless you're a hot-rodder like me, you're probably best off leaving older bikes mostly original... a set of modern wheels and brifters/RD is plenty of upgrade for a nice old bike. Dual-pivot front brake is a good idea.
If you want a bike with threadless and external BB and fat bars and all that cool stuff, you're best off buying a modern bike IMO.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Liked 10 Times
The bike is a borderline hot rod. Its an older Paramount PDG Series 3. Previous owner ripped off the stock 7 speed RX100 and put on 8 speed Dura Ace. I replaced the down tube shifters with brifters, put on the theadless stem & adapter and recently replaced the stock Araya rims with some 24 spoke Bontragers. The rims don't affect the way it rides or handles (at least not that I can tell) but look way cooler. Also put on a new Selle Itallia saddle. It has stock rX100 dual pivot brakes on it. If I can find matching dual pivot DA's cheap enough I'll replace them to match the drive train but not really on the replace list. See attached for shot of Paramount.
Bikes: 2012 Cannondale Synapse 3 2010 Cannondale F5 1972 Raleigh Super Course 1981 Univega Gran Turismo 1985 Specialized Sequoia 1991 Klein Quantum
Quoted: 14 Post(s)
I did the same thing with a 1998 Raleigh 600. The carbon fork made a huge difference in ride quality. My hands and shoulders felt much better after a long ride so it wasn't definitely worth the money to complete the upgrade. I did use 1 1/8" stem with a shim. It worked fine and was pretty inexpensive.
Quoted: 6556 Post(s)
Liked 58 Times
I used to have one of the original Trek 2000s, glued aluminum frames. I always thought the frame was great, but the aluminum fork sucked, especially in appearance. A nice 1" carbon fork would be a big improvement for your frame. I suggest you look at the Columbus Minimal Road Fork at wiggle.com. Decent price and very light weight. That combination is not easy to find in a 1" carbon fork these days.
