Has anyone taken a chromed frame and removed just enough...
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
.....paint to present chrome panels on tubes?
Specifically, the headtube and downtube.
Bike is all original and not bad paint. Just a few paint scrapes.
I'll get closer pics of the areas in question on the Bottecchia, in a day.
Main concerns with removing paint are:
A sharp definition line on the edge of the paint.
Finish on the newly exposed chrome. (again, 72/73 Bottecchia GdItalia)
Will I like it's 'uniqueness'?
I'm leaning in one direction on this, but still asking for opinions.
Especially visual inspirations.
I don't have a chrome bike - and this is not the one to go full chrome, IMHO.
Is going chrome panels a poor substitute???
(sorta like a Speedo at the chrome nudist colony).
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 375 Post(s)
Liked 1,083 Times
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I haven't tried it but I kinda share the temptation. Or, don't strip the paint for panels, but rather bands or fine lines. Imagine box lining that's actually chrome... could be cool.
Procrastinateur supreme
My '72 Atala has nicely chromed lugs, seat cluster and frame/fork ends, and paint on the rest. It seems that was what Italian factories in that era. The paint flakes and doesn't adhere very well - it appears that there's nickel plating on most of the frame underneath the chrome and up the tubes. I never cared enough to do anything other than patch with laquer. I ride it.
I know that chrome is very hard, not so sure about nickel. But I imagine that it would be hard to get a good paint shore line with either without some aggressive sandblasting.
52psi
Quoted: 790 Post(s)
Liked 802 Times
For the sake of everybody's curiosity, I say do it.
Quoted: 2588 Post(s)
Liked 4,824 Times
Chances are the chrome underneath the paint is not going to look very good, for the reasons noted in post #2. Anyway, that bike looks great just the way it is!
I vote no. Find something crappy and cheap at the Swap Meet to satisfy your curiosity
DD
DD
Not so Simple, Do you understand how electroplating works?
frame prep for chroming involves polishing the base metal..
when a bike frame building company plans to have the rest of the frame painted the lugs are the only thing polished
the rest left as is or sand blasted to help the paint stick..
Electro plating is done by immersing the whole frame in an acidic solution mixed with Chromium* salts in solution,
and an electrical charge is applied taking chrome from an anode, and depositing it on the part , being the cathode in the circuit.
so first you have to strip it, entirely , you have any chrome on it, if its not polished there , the Plating company can remove the chrome ,
it becomes the anode and the chome is removed and deposited on a different cathode..
then you polish it and start over , apply new chrome, fresh paint.
reading material : https://en.wikipedia.org/wiki/Electroplating
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
I used some paint stripper on a few strategic areas, but although there was chrome underneath, it had been media blasted.
Disraeli Gears
Because chrome left exposed to view requires extra polishing (because the "smooth" high finish is the substrate, not provided by the chroming process) what's been chromed but then painted will almost certainly look rougher. Also, paint needs some "tooth" for adhesion. So revealing chromed areas that were painted is a crapshoot, likely not to look as good as what was intended to be exposed. And painting chromed areas that were exposed requires blasting or other abrasion to provide adequate tooth for good paint adhesion. I'm not saying nobody's done this, but these are considerations.
Chroming done right is a 3-step process: first copper, then nickel, then chrome. To rechrome means removing the existing chrome, and then re-plating. The motorcycle obsessionists are familiar with this, as are the platers.
Veteran, Pacifist
Liked 4,836 Times
Thanks all.
I just need to do some paint matching. Or accept some patina in a paint worn place.
I don't think I'd like the 'unique-ness' on my classic. Don't want to try to polish rough chrome.
