Wheel don't spin freely after installing new brake pad help!
Quoted: 7 Post(s)
I have the Shimano XTR braking system...decide to install brand new brake pad yesterday and now my wheel don't spin freely anymore without rubbing against the pads....The pads are a lot thicker (obviously) so that narrows the gap between the disc.....is there a way to adjust this or is it normally to put on a ton of KM on the new pads?
52psi
Quoted: 790 Post(s)
Liked 800 Times
Before you installed the new pads, did you push the pistons back? This helps self adjust with the new thickness
Quoted: 7 Post(s)
