Kick Stand-Schwinn Varsity
Old 05-29-08, 02:22 PM
Bebopman
How do I get the damn thing off?
It's added weight...I'm not gonna use it...I want it off.
if anyone has an idea that would be awesome
Bebopman is offline
Old 05-29-08, 02:30 PM
duffer1960
Bikes: Fred cycles
Quoted: 34 Post(s)
Liked 18 Times in 16 Posts
Googled...
https://www.bunchobikes.com/repair2.htm
https://aebike.com/page.cfm?action=de...=30&SKU=TL7293
duffer1960 is offline
Old 05-29-08, 02:31 PM
bab2000
Bikes: riders:Schwinn Continental ('80), Specialized Crossroads Sport ('07), Schwinn Super Sport (73), Schwinn Superior (76), Projects: Schwinn Sprint ('74), Trek 800 & Schwinn Continental ('71)
This link should provide you the guidance you seek.
bab2000 is offline
Old 05-29-08, 03:29 PM
Bebopman
next problem....
I cant get the crank off so my chainring gets in the way.
So that solution won't work until i can get enough clearance with the tools.
Bebopman is offline
Old 05-29-08, 03:30 PM
BikeManDan
BikeManDan's Avatar
You have a Varsity....and you're concerned about the weight of a kickstand?!
BikeManDan is offline
Old 05-29-08, 03:36 PM
duffer1960
Bikes: Fred cycles
Quoted: 34 Post(s)
It'll be easy to get the crank off. Will need a thin-enough wrench to remove the left pedal, and a big adjustable wrench and a screwdriver for the left bottom bracket locknut and cone. All have left hand threads. Just pull the whole thing minus the pedal out the right side.
Old 05-29-08, 04:22 PM
mswantak
Glutton for Punishment
Quoted: 5 Post(s)
Liked 8 Times in 7 Posts
Really - that's just silly.
mswantak is offline
Old 05-29-08, 06:46 PM
reverborama
Broom Wagon Fodder
reverborama's Avatar
Bikes: Fuji Supreme; Kona Wo; Nashbar road frame custom build; Schwinn Varsity; Nishiki International; Schwinn Premis, Falcon Merckx, American Flyer muscle bike, Motobecane Mulekick
Quoted: 52 Post(s)
Liked 64 Times in 30 Posts
Those things weigh more than a pound.
I didn't have a big enough channel lock so I took a finishing nail, bent it around the kickstand, and used a C-Clamp to press it in and release the stand. Quite easy as a matter of fact.
reverborama is offline
Old 05-29-08, 08:50 PM
mswantak
Quoted: 5 Post(s)
It's even easier than that if you're married. I push the spring-loaded washer in with a flat-bladed screwdriver and have the wife pull the pin out.
mswantak is offline
Old 05-29-08, 11:52 PM
Bebopman
The pin is the key I'm guessing? I get the pin out I get the kick stand out
Do i need to get something to push into the other end of the kick stand(the end that has a triangular hole that just puzzles me?)
Bebopman is offline
Old 05-30-08, 12:07 AM
mswantak
Quoted: 5 Post(s)
No -- there's a coil spring just behind the collar on the kickstand side. Just compress the spring by whatever means you have at hand by about 1/4", and the pin will pull right out. Like I said, I lay the bike on its side and shove the collar down with a screwdriver. You'll need a third hand since this will usually take all your weight on the screwdriver. You can buy a special tool for the job, but what fun is that?
mswantak is offline
Old 05-30-08, 12:50 AM
Bebopman
I see. That makes more sense.
This will be a fun job...ha
Bebopman is offline
Old 05-30-08, 11:21 AM
guygadois
guygadois's Avatar
Bikes: yikes, too many
Quoted: 43 Post(s)
Liked 7 Times in 4 Posts
I think it is easier if you just have a girlfriend. A wife wouldn't be so willing help.
Bikes: N + 1
guygadois is offline
Old 05-30-08, 11:36 AM
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
Of course you could go to Park Tool and get the correct tool and then its a 30 second job. Roger
File Type: jpg
rhenning is offline
Old 05-30-08, 12:11 PM
bab2000
That works out to about $1 a second.
Hack saw is another option
bab2000 is offline
Old 05-30-08, 02:59 PM
rhenning
Quoted: 380 Post(s)
It will cheap compared to the hospital visit when the screw driver slips off and stabs him in the hand. The plus side is I bought mine like that in the early 1990s for $12 and have used it hundreds of times. Tools like that don't wear out. Roger
rhenning is offline
