Dual freewheel???
Bikes: Pure Cycles SS 48:16. w/ some mods
Quoted: 8 Post(s)
Liked 6 Times
Dual freewheel???
Hey Guys & Gals! Is it possible to put a 16t freewheel gear on one side and 14t freewheel on the other? This would allow me to flip the gears. I would have two chains for each freewheel set.
White Industries sells a freewheel that has 2 cogs on it called the DOS ENO freewheel. There are two options, either 17/19 or 20,22. If you calculate the gear ratio range that you want you can get a front chainring to get as close to if you had 16/14 since gear ratios are proportionate to tooth count of chainring and cog. To calculate your gear ratio divide front chain ring with rear cog.
Quoted: 8 Post(s)
Liked 6 Times
Thanks cs007! I currently have a flipflop wheelset with 16t freewheel & 15t fixed cog. Want to change the 15t fixed to a 14t freewheel
Quoted: 8 Post(s)
Liked 6 Times
Thanks IAmSam! Pure Cycles guy suggested a certain 14t freewheel that I purchased but haven’t taken the time to try. It looks like a tight fit. Just had the thought of putting it on the fixed side. Gonna pull the wheel off tomorrow and see if the threads are correct and fit it will actually fit. Will let you guys know what happens.
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
Likes For 50voltphantom:
16t is the smallest freewheel you can fit on a standard hub track fixed gear hub. A bmx flip flop hub has standard threads on one side. The other side is threaded for metric freewheels which range from 13t-15t. Your 14t freewheel will not fit on your fixed hub. In theory you could install a longer axle on a bmx flip flop hub and space it to fit a 120mm spaced frame, but this seems more trouble than it’s worth. Just work out the gear ratio you need using a 16t or larger freewheel.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 999 Times
look into a Dingle speed, a 17-21 2 speed freewheel with 2 chain-rings 5 teeth apart.
here is one of mine
here is one of mine
Not lost wanderer.
Quoted: 886 Post(s)
Liked 999 Times
here is one of mine
IMG_20180518_172449673 by Bwilli88, on Flickr
IMG_20180519_145832267 by Bwilli88, on Flickr
here is one of mine
Quoted: 8 Post(s)
Liked 6 Times
Hey! Thanks guys! For the comments and suggestions. Had to delay my bike work for a few days...90 yr old father-in-law has returned home from back surgery rehab. Will try to pick this up come Tuesday. H
