Fancy New Rim Tape
Fancy New Rim Tape
Had bad rim tape, replaced with “tubeless” rim tape, gave it two layers for peace of mind.
Says 11m length on the roll, so this is cheaper than Velox cloth.
TCS Rim Tape 24mm wide by 11m long
Anyone else using this stuff (with tubes) ?
Quoted: 3514 Post(s)
Liked 2,927 Times
Nope. I only use Velox. One layer only. Cheaper and lighter…
Likes For smd4:
Likes For masi61:
Quoted: 968 Post(s)
Liked 1,631 Times
Thanks for the heads up. Good to get a post on a product find that for some is proven... Thanks
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Nope. Tubeless tape is by far the best way to go. I haven't used Velox in years. TL tape is thinner IMO is lighter not that it matters. I think Velox should just give up and go out of business...or start making TL tape.
Liked 2,927 Times
Next you’ll be telling me there’s something better than toe straps and downtube shifters.
Likes For smd4:
Quoted: 2338 Post(s)
Liked 2,827 Times
complete agreement for tubes, velox is gold standard
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...I don't know what that stuff is, but it would need to be pretty good and pretty cheap to beat standard rolls of kapton tape.
Likes For 3alarmer:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Stan’s, Kapton (Capton, whatever, spelling on this stuff is all over the place) far superior to 99% of rim tape alternatives for clincher tubes.
I’d still still use Velox for pesky applications like single wall rims (I’m talking to you, Wolber Concave) but that’s about it.
And you can mount tires much more easily with thin rim tape. Physics.
Quoted: 1104 Post(s)
Liked 1,825 Times
Scotch 8898, a little over 4 bucks a roll, I use two wraps for tubed tires. I'm as traditional as they get when it comes to road bikes; these days, Velox tape is a sorry excuse for what it used to be. It slips and exposes spoke holes in no time. Not to mention that it takes up a lot of room and makes tire mounting a b*tch.
3M Scotch 8898 Filament Strapping Tape 42300, 18 mm x 55 m, Blue | RSHughes.com
Liked 2,927 Times
Liked 1,825 Times
It all depends on the tires and rims whether or not mounting a tire will be problematic. I use modern rims on most of my fleet that are tubeless ready, that single thing seems to make mounting a tire without a bead jack near impossible. As far as width, you gotta think outside the box. On my period correct bikes with narrower rims, I apply the tape and then use a razor knife to trim it to the correct width. As it is with collecting bicycles, "too much" is better than "not enough".
Liked 2,927 Times
I enjoy working on my bike. I actually like doing routine maintenance and cleaning. But I don't need to do extra work, and with this issue, there is absolutely no need for me to "think outside the box." The Velox works fine, I can get it in the correct width, and for me, $4 or $5 bucks a roll is cheap (I once again find it amusing that people are cheaping-out on a $10 dollar item for their $10,000 bike). No need (for me) to fix something that isn't broken. If other people want to use packing tape, or several layers of Scotch tape, or painter's tape, or whatever, great!
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
Tubeless tape is better. Period. I used Velox for years, but tubeless tape stays in place, won't absorb water, lighter, better in every way.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I'm a confirmed retrogrouch. I used Velox for more decades than I care to admit. But I agree, after over a year's trial on two bikes in the family, that two wraps of tubeless tape is working very well on our high pressure road clinchers. And my wife can mount her tires more easily.
Quoted: 4236 Post(s)
Liked 2,949 Times
That's my standard as well. If I ever try going to tubeless, I might switch, but the Kapton is so cheap and easy. Double wrapping with it is thinner than Velox and cheaper too. Hell, it's cheap enough that I might grab that to tape the cables down to my bars tonight before wrapping them instead of trying to figure out where I put my electrical tape.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Interesting. Kapton tape does come in 5/8” width which is approximately the 16mm width of Velox tape that I’ve used on my old road rims. Probably worth trying. I have quite a challenge mounting Continental tires on these old Ambrosio Elite rims, so thinner rim tape might help out.
Otto
Otto
Quoted: 968 Post(s)
Liked 1,631 Times
Likes For zandoval:
I just googled it and learned what I suspected.
They say wrap two layers of tubeless rim tape if you’re going over 45 psi.
which is what I expected, so I’m glad I used two layers.
Liked 2,927 Times
I like velox fine for non-tubeless-profile rims because it's frankly easier to apply. Also works great on single walled rims.
Legit tubeless tape on all rims that are tubeless compatible, tube or not. The tight bead seat tolerance will make tire mounting torturous without it.
