Chain replacement
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
Chain replacement
Hi all
Do you think chains should be changed regularly as a precaution before they stretch too much and start wearing out the rear cogs or should you just keep riding the chain until both the casette and the chain needs changing together.
I took my bike to the LBS to service the hubs recently and asked them to change the chain since I have just over 2k miles on it. There seems to be no noticeable wear on the cassette and the chain isn't obviously stretched but I did notice the chain skipped a couple of times when on the smaller cogs at the back. The shop said he wouldn't replace the chain without changing the cassette, but my cassette is fine (no sharp teeth all square still). He said I should just keep riding with the same chain until the cassette also needs changing. But if I change the chain wouldn't I keep the cassette in good shape for longer?
Thanks for your thoughts
POWERCRANK addict
It depends on chain wear. If the chain is particularly worn then he may be right and you've left it too long between changes. Get a second opinion and/or buy a chain wear checker (a steel rule will do).
https://www.google.com/search?num=100...hain+wear+tool
https://www.google.com/search?num=100...ain+wear+guide
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
Solo Rider, always DFL
Bikes: Cannondale T800, Schwinn Voyageur
Measure the chain. You can do a quick google search to see the acceptable tolerances, but I believe that with 1/16" or less of "stretch"/wear you can get by with just changing the chain. This should make it easier to avoid changing chainrings as often...
I don't think you have to replace the chain and cassette at the same time, I usually replace the cassette every other chain. Don't replace the chain based on miles, do the measurement and replace it when it stretches.
Sensible shoes.
Bikes: A few.
^^ Pretty much my plan. Oddly, I wear cassettes in about 2k and the chain is fine. That's on three different bikes.
Are we having fun yet?
Bikes: Fuji Roubaix, Trek 7200
If you check the chain regularly for stretch and replace it before it's too bad, your cassette ought to last a long time. Park makes a chain checker that lets you see the amount of stretch.
You're east of East St. Louis
And the wind is making speeches.
Sensible shoes.
Bikes: A few.
^^ Sorry, not for me. NEW chains I blow the cassette in 2k miles or so. Proper maintenance and everything.
Quoted: 768 Post(s)
Liked 1,744 Times
Jeez, are you using Dura Ace??? I've been using 105 or Ultegra cassettes and I can usually go 2 chains before I have to change the cassette.
Sensible shoes.
Bikes: A few.
2x 10sp Campy and 1x 9sp Deore XT. No body can explain it, other than to say I really--really--like torque. Whole LBS mechanic shops have puzzled over it. I've changed everything but my riding style. It is what it is (expensive).
Bikes: Waterford 2200
I'm using Campy 10sp and usually get 3-4 chains before I have to change cassettes, but there are times when it maybe 2-3 and you're right about the cost.
Make mine a double!
Make mine a double!
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
I had heard that if you change chains every thousand miles or so, the cassette will last a lot longer. They said 7 or 8 thousand miles, but I don't have any proof yet. I have about 3,000 miles on mine so far, and the cassette is still good. I am still running the stock Tiagra parts that came on my Cross Check.
I run my chains around 1500 miles.
Make mine a double!
Make mine a double!
Gorntastic!
Bikes: Firefly custom Road, Ira Ryan custom road bike, Ira Ryan custom fixed gear
Quoted: 9 Post(s)
first time, I waited to change the chain until 1500 miles. Casette was shot (105).
Then I got an Ultegra casette and started cleaning the drivetrain more and measuring the chain. sweet spot for me is to change the chain every 700-800 miles. I'm to the point now where I can feel when it needs changing. I've had 2 chains on the Ultegra cassette and it's good for at least another 2.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
Sounds like more people change chains regularly before wearing out the cassette rather than just keep the same chain and casstte until the the cassette is worn out. The difference seems to be how long it takes before the chain needs changing.
