Huret Speedometer/ODO making a buzzing sound
Old 06-16-20, 08:20 PM
jackbombay
Quoted: 446 Post(s)
Liked 422 Times in 254 Posts
I pulled this off the Schwinn Continental that I was riding around out east so I could put it on my Raleigh Sprite 5 speed townie, but its making a buzzing noise, at ~15+ MPH, the cable from the driver on the front tire is not totally straight, is that the issue? Or is it maybe something inside the speedo unit itself? I imagine these aren't very popular due to the noise from the driver on the tire, but I'm sure some of you used them in the past, here is a pic of the cable, and a video of the noise,
jackbombay is offline
Old 06-16-20, 09:24 PM
Salamandrine
Quoted: 2310 Post(s)
Liked 559 Times in 402 Posts
It shouldn't be that loud. Can you pull the main cable out and grease it? Sounds like it just needs maintenance. May need additional lubrication elsewhere. The head unit of a speedo normally just has a spinning magnet and a spring inside, but there may be some clockwork for the odometer that's acting up.
I hear the high pitched whine of the wheel, but that's the least of your noises. IKU were a lot quieter because the wheel was smooth. You could sand your wheel smooth, but it would throw off the accuracy a bit. Or try moving it to contact a different part of the tire.
Maybe this blog will help?
https://hughsbicycle.blogspot.com/201...eter-look.html
Salamandrine is offline
Likes For Salamandrine:
Old 06-16-20, 10:00 PM
jackbombay
Quoted: 446 Post(s)
Cable/housing and drive unit on the wheel have been disassembled cleaned and greased where appropriate, the drive unit on the side of the tire specifies no lubrication as its just rubber bands on little plastic wheels inside there. Any oil on the cable will run down into the drive unit and make it stop working correctly, ask me how I know, D'oh!
Ahhh, I was wondering how that was set up, thats where I think the noise is coming from, I'll see about prying the little tabs back that hold the head on the unit and see what I can do, thanks!
It is running on a smooth part of the tire, I did run this on a bike out east for a bit and the ODO reads a bit low, so sanding the bumps off the driver wheel is the plan as it will make it more accurate, but I want to get rid of the blatant noise first before I spend time sanding the bumps off.
I'll check it out, thanks!
Old 06-16-20, 10:03 PM
armaan
Where did you purchase that bike from?
armaan is offline
Old 06-16-20, 10:22 PM
jackbombay
Quoted: 446 Post(s)
I built it up myself during quarantine.
