My 5-6 mm wrenches don’t work to unscrew bike saddle
I’m trying to put in a new saddle but the Alan wrench doesn’t take it off.
Non omnino gravis
Likes For DrIsotope:
Non omnino gravis
Quoted: 174 Post(s)
Liked 177 Times
It's probably standard rather than metric. If it's not that there's a good chance it's striped.
Very rarely, it's actually the tool itself because the tolerances are incorrect. This only happens with extremely cheap equipment though, and even then it's unlikely.
*Edit - Or are you saying the bolt is seized? Because if that's the case, liquid wrench (or any decent penetrator, really) will make light work of it.
Likes For Ross520:
Quoted: 18415 Post(s)
Liked 15,545 Times
Hit the weights.
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Squeeze it
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
SE Wis
Liked 3,395 Times
Small combination wrench cheater
Likes For dedhed:
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
If you have a Guerrcotti, the Alan wrench may not work. You could try a Basso wrench but I know for a fact the De Rosa wrench won't work. Should gone with Campagnolo, he invented the quick release would have made it way easier.
Expired Member
Liked 5,431 Times
Clearly a spare wench is necessary.
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
... and if it's not a torx head bolt, you can use a torx bit, bashed in with a hammer, to bite onto a stripped-out allen head bolt.
SE Wis
Liked 3,395 Times
If you knew the poster's history that issue isn't the problem.
Clark W. Griswold
Liked 3,994 Times
I know I know but I wanted to make an Italian bike joke. I briefly owned a Guerrcotti but ended up stripping what I needed and give the frame to my service manager at the time because he was an excellent employee who rose to the challenge quite quickly and he really wanted it. He still has it last I talked with him but he left a little after I was needed at another shop in the company.
Quoted: 1581 Post(s)
Liked 1,189 Times
Likes For badger1:
Duke Ulysses
Bikes: An old orange one for dirt, and for the other stuff: a white one, a kinda mint green one, and a black one.
Quoted: 165 Post(s)
Liked 175 Times
this needs to be moved to the mechanics forum
