Front Fork Clearance?
The Freewheeler
Bikes: '37 Iver Johnson Racer, '44 BSA Airborne, '45 Swiss Militarvelo, '92 Fat City Slim Chance, '97 Pinarello Monviso, '03 Giant TCR Composite, '12 Bianchi Super Pista, '15 Humble CX
Quoted: 8 Post(s)
I just had a custom frame built and the clearance on the front fork seems unreasonably huge. I have 32mm tires, and have 1.5" clear vertically and .75" clear to the left and right. Thoughts?
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
How much clearance at at the seatstays and chainstays?
Non omnino gravis
I'm running tires that measure just over 1.25" wide when mounted, and have almost exactly 1/2" clearance on each side, and 1" above the tire. This measurement is almost exactly the same in the rear, 1/2" between the chainstays, and 1" from the seattube. So you have 50% more clearance, which I wouldn't mind on mine, really. Just means you can throw some 2.25" tires on there and go mash.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
As a point of comparison, this is a pic of my fork with 700x33 tires:
I think you're good.
My Bikes
My Bikes
The Freewheeler
Quoted: 8 Post(s)
fork: 3/4"
seatstays: 7/8"
chainstays: 1/4"
That chainstay clearance seems to throw off the theory of throwing on some wide tires and mashing, no?
I will add that this is my first non-road or track bike, so any "unnecessary" clearances look incredibly strange to me.
seatstays: 7/8"
chainstays: 1/4"
The Freewheeler
Quoted: 8 Post(s)
Chases Dogs for Sport
After this year's Dirty Kanza 200, I don't think you can have too much tire+mud clearance. And my bike is a disc brake bike.
I rode 38mm tires on a fork with 50mm between the fork legs. The mud was so sticky that it would jam the front wheel in the time it took the contact patch to rotate around to the fork legs -- about 1/3 of a wheel revolution.
Bikes: Yes
Liked 3,868 Times
You clearly have a very generous amount of clearance, but that's probably not a bad thing. The main downside would seem to be the appearance with skinnier tires. The upside is mud clearance and the ability to use wider tires.
My Bikes
My Bikes
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Looks like plenty of room for a 40mm tire in front. Too bad the builder didn't give you similar clearance at the chainstays. Did you discuss tire clearance with the builder before the build and did he deliver what you asked for?
The Freewheeler
Quoted: 8 Post(s)
Yep, I said I'd be using 32mm tires, so he could set that as the max for clearance. Doesn't seem like he paid any attention to that.
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
There's an appearance thing going on with the pic. The shot. with bottom bracket resting on the ground, doesn't really give the visual reference that the bike would were both wheels mounted and you shot the image again standing in the front.
The Freewheeler
Quoted: 8 Post(s)
not sure what you're asking for, but the shot was taken with both wheels installed. there's some kind of optical illusion going on.
The Freewheeler
Quoted: 8 Post(s)
you can see the shiny freehub at the top of the frame
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
What he gave you was versitility and you will thank him later when you want to put some 43mm Rock&Roads in there (and you will). The only cost for the additional clearance is asthetics.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
You see a freehub, I see a bright spot, could be a freehub, bikes is in the midst of a build... didn't see any tire. I was just pointing out that the perspective, appearance of abnormally large gap can change depending on how close you stand to the bike. I couldn't get a reference to go by from your shot. That's all.
Quoted: 175 Post(s)
Front clearance appears to be dictated by the decision to use a lugged crown on the fork. Builder used on the of the commercially available crowns (because casting a custom one would be prohibitively expensive) The vertical clearance could be related to having an axle-to-crown that works with the rest of the geometry. Or to have the same axle-to-crown as "common" cyclocross forks so the owner can replace it if they want to.
As a side note, 32mm max strikes me as a rather odd size limitation. 33mm I could understand if the OP wants to stick to cyclocross tires -which mostly come in 33mm or less because UCI. Not that a millimeter will make a huge difference, is just an odd tire size limit to me.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Also, when building forks for cross, there are not that many fork crowns to choose from. Currently, most have around 50mm between the blades. Looks like he used this crown for straight blade. NOVA CYCLO-X FORK CROWN FULL SLOPE 28.6 7° OFFSET :: FORK CROWNS :: Nova Cycles Supply Inc.
hopefully he used the right blades for disk brakes.
Since the frame is unpainted a simple crimping of the chainstays will correct that.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I meant the actual fork blades. Blades for disk brakes are thicker to fight the forces the brakes put on the forks. You won't be able to see that in the photo.
Quoted: 83 Post(s)
Less than 33c is essentially CX racing spec. Very few race bikes run steel forks, so demand for lugged crowns in those sizes is pretty near zero. My builder does unicrown forks to keep control of the spacing for people like me that still want a steel fork, but most buyers just opt for carbon forks even on steel frames.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Standard fork blades taper from around .9mm to .6mm where the disk blades are around 1.1mm wall thickness. Disk brakes shift the forces from the top of the crown to the blades so the thicker blades compensate for this.
