Classic and Vintage use in trainers?
Bikes: Masi Gran Crit, Bianchi Campione D' Italia 84, Eddy Merckx Corsa Extra, Ibis Ripley, Co Motion Tandem, Merlin Agilis, Ritchey Breakaway, Bianchi Infinito CV, Colnago Master
Quoted: 68 Post(s)
Liked 129 Times
In light of the need to now train indoors due to the virus, I was debating whether to use one of my older steel bikes in a trainer. However I've gotten conflicting advice - from sure no issues to it will lead to stress and damage to the frame. What are others opinion on this and do any of you have pics of their indoor set ups if they are using a C&V bike in their trainers.
Likes For Thalia949:
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 224 Post(s)
Liked 162 Times
I ride my 80's classics on roller all the time. Not so much my turbo trainers. But since steel does flex, clamping it down shouldn't be a problem. Your older steel skewers should easily handle the load.
I did have a spoke break on my Fuji while on rollers, but that wheel had one break previously. So that wheel was shot and was tossed into the garbage
Likes For friday1970:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,005 Times
I think a lot depends on how you are riding. If you are staying in the seat and smoothly spinning, the stress should be minimal. If you are training for racing and getting out of the seat for sprints, you are flexing the frame against the rear axle where it isn't designed for that.
Quoted: 68 Post(s)
Liked 129 Times
I've always hated riding on the trainer but in order to avoid the quarantine 15, it is looking better every day.
Quoted: 1607 Post(s)
Liked 2,216 Times
I am thinking the same. I have a Bottecchia that is a candidate for the trainer.
One thing to watch out for is sweat. It will remove paint over time.
Bikes: 1968 Raleigh Sports, 1970 Raleigh Twenty
Quoted: 9 Post(s)
Great minds think alike
https://www.bikeforums.net/classic-v...-3-speeds.html
Modern (non roller) trainer stands are designed to fit Quik Release skewers. If I knew the inside diameter of the metal "cups" I could figure out if they will fit my vintage bikes with Sturmey Archer hubs, or what mods need to happen.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
The day someone shows bona fide pics of the frame they broke on their wind/mag/roller trainer is the day you have to worry.
Still, I never use my best bikes out of principle.
Quoted: 1199 Post(s)
Liked 1,355 Times
I dont see what the risk is putting a steel frame on an indoor trainer. I've been riding my Torelli on a wind trainer lately and its been great.
i keep a towel in my back pocket to wipe off sweat and frame when needed.
I was recommended getting a trainer specific rear tire cuz the trainer can chew up the normal ones.
Quoted: 656 Post(s)
Liked 469 Times
I recall there being another post on this recently. No worries here with using my 1985 Peugeot. I regularly stand up to grind out some high gear intervals.
Likes For plonz:
Randomhead
Liked 3,698 Times
I have a centurion semi-pro in my kickr. I sometimes think about switching it out for a different bike, but it's working for now.
Quoted: 1949 Post(s)
Liked 2,010 Times
A shop owner I trust has replaced steel forks that broke due to trainer use.
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
I doubt that unless it was on the old type with the fork clamp. The stresses IRL are FAR more severe than being static, that is unless he is dealing with a bunch of moneys swinging off the bars, which was probably more the case here.
Liked 2,010 Times
Some time ago. Old shop. Old bike shop owner. U.S.A. Olympic wrench bitd. Broken forks likely from using what would now be a C&V trainer.
Quoted: 68 Post(s)
Liked 129 Times
I've been riding outside as much as possible, however work and wet weather has me evaluating other options. The trainer is sitting there unused and I figured between conf calls and webex's it would be a good diversion.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
It isn't like I'm racing pros on Zwift or anything - just pounding out cadence to some tunes, or while watching TV.
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
I could DEF see that, similar to the one further up. I would probably be fine but anyone with real power likely do this. ie team riders.
Quoted: 604 Post(s)
Liked 1,064 Times
Took one of my Trek 400s, and put it on a trainer, approaching 1000mi, no issues so far.
Tim
Tim
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I ride a vintage bike on a Cyclops trainer quite often when I can't ride outside because of weather, work commitments, pandemics, alien invasions, that sort of stuff.
Most of the time lately it has been my Bianchi. My biggest concern is how well the support cups fit the QR skewer ends. Some skewers fit better than others.
Real cyclists use toe clips.
jimmuller
jimmuller
Likes For jimmuller:
Quoted: 4560 Post(s)
Liked 2,802 Times
I've put a lot of hours on the Cycelops trainer with my '89 Ironman. No problems. I use the same Continental Ultra Sport II tires on the trainer and outdoor rides, also no problems -- no premature wear, etc.
As other folks mentioned, the only tricky bit is having the right skewer and quick releases to fit the cups securely on the Cycleops and similar wheel-on trainers. And getting the right tension both to support the wheel and resistance against the tire.
Occasionally I use the trainer for high intensity interval training but I'm avoiding high stress training for now. Even before the coronavirus pandemic my immune system was acting up -- I have an auto-immune disorder that overreacts to ordinary stuff, including everyday pollen and allergens. My monocytes have been elevated for months. So for now I'm only doing easy recovery rides on the trainer, while watching movies or TV.
I do my workout rides outdoors, mostly steady tempo, hills, etc. I've never found a Cycleops trainer to properly simulate actual hill climbs. I have to get outside to do that. Fortunately there's a 5-6 mile loop nearby with some decent climbs, on an access road with little traffic.
Liked 2,216 Times
Liked 645 Times
The thing I miss on the trainer is how the upper body and breathing and the mind have to keep working while riding downhill. You stop pedaling on a trainer and the whole physical exertion thing stops. On the other hand, just shifting up a gear or two loads the legs like a hill. I usually do a lot of shifting.
jimmuller
jimmuller
Quoted: 358 Post(s)
Liked 136 Times
Careful using older bikes in a trainer. I had a problem with the tire getting hot and blowing out.(Ok, I'm a hammer head at times.) Wider tires help. Right now I'm using 700+23. I wish the bike could take a larger tire.
