Show Off Your Townies
#976
Bikes: 2010 Windsor The Hour, 1982 Fuji Supreme
I mean, I know you're not trying to get the most efficient pedal stroke out of a townie build, but that's just gotta be uncomfortable.
#978
Moved from jackass by popular request (thanks, guys!):
New shop bike now complete.
Wald basket, double kickstand. Desperately needs spring fork stabilizer; in the meantime, there's a tube wrapped around the tt at points of contact.
Drivetrain: 4sp custom cass 16-21-26-32; 44/36/26 chainrings; Shimano Ultegra adjustable chain tensioner
1 into 2 brake lever; PDW coffee holder; custom fork crown to basket bracket.
This was my son's bike, a beater to replace the awesome new bike his mom ran over. Then he outgrew it. Was set up with a Chinese motor until a co-worker stole a ride and blew it up. Now this. Shop, lunch, erand, etc. bike.
Single speed, but rear barrel adjuster means I have one gear range out back, three up front, moving the chain by hand at a stop. Wingnut on set screw at derailler cable clamp means I can adjust to other gears if need be. In practice, I pick a gear and ride it, SS style.
Bontrager H2 Hardcase bomb-proof tires @ 26 x 2.0, Velocity Synergy rims, custom 3x lace to Shimano Silent Clutch hub off ex-popo bike rear, front Miche Prinato hub from the parts bin. Topline SL cranks.
Thing is too much fun to ride and about the quietest bike I have.
#980
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2632 Post(s)
Liked 3,147 Times
post-modern industrial
"Your beauty is an aeroplane;
#983
Pennylane Splitter
Bikes: Yes
Quoted: 1789 Post(s)
Liked 1,439 Times
This bike's smokin' hot. Hand-changing gears seems like a real P-I-the-A. I'd keep lookout for a friction thumb shifter to solve that issue. Otherwize, that's nice work.
#985
Sheriff of Nottingham
it's a tough job being a mountain bike, a cyclocross bike, and a cruiser bike
redline monocog with some origin 8 cruisers, 29er big apples tires, and avid cable disc brakes.
#986
Quoted: 4232 Post(s)
Liked 2,947 Times
Those giant baby heads outside the mfa really freak my wife out.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
#987
I've been meaning to post these for about a year now.
Its a huge Motobecane Jury frame with 27" wheels. This frame would be way too large for me as a road bike, but set up like this its perfect, and also looks better without a mile of seatpost and a ton of stem spacers. It started out as conventional townie with the bars upright, but it works for me better with the bars flipped down...like a grass racer. Its basically done, but one of these days, I'm going to build new wheels with a drum-dyno from hub. I also need a chainguard, but having a hard time finding one that works with the Phil BB.
#989
one life on two wheels
Liked 18 Times
Needs something to look finished. Maybe a fender mounted tail light? I agree a front dynamo hub/light would be cool too. I'd tilt the saddle nose down a *bit* and swap the h-bars for something else, like a VO Porteur bar...or if I wanted a little more reach a VO Postino. The grips look cheap to me, I always liked some cork wrap as "grips"...in a different color than brown to mix it up a bit, dark green would be nice IMO
I'd be tempted to have a second h-bar setup too, some Rando drops for longer rides. With the threadless stem it would be an easy swap.
#990
Bikes: Nothing amazing... cheap old 21 speed mtb
https://www.bikeforums.net/attachment...7&d=1355577871
https://www.bikeforums.net/attachment...6&d=1355577860
Either of those two are my ride around town bikes. Depends on the weather/situation. If I want to haul kids/stuff or just ride through the snow and rain my snow tire equipped kid carrier is the go. If I want speed and a bit of fun the hybrid gets called out. If I want to ride for a long time or on varied terrain I'll ride this..
but parking something that cost me 6 months and a lot of money to build isn't easy so I usually stick with the cheaper ones in town.
#992
#993
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
No matter how much you add to the bike, it will always be too big.
#994
Fresh Garbage
It looks fine. If the reach is good and he is comfortable then I don't see a problem. Someone was saying the same thing to me because I dont have an "ideal" amount of seat post showing.
#995
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
There was a thread a while back I believe over in C&V that discussed different ways of doing fitting, and Wrk101 mentioned he had short legs and a long torso/arms (same problem I have), and that he stopped worrying about stand over and focused more on top tube length ironically enough, I ended up buying a frame set from him that fit the bill for fitting that way, and I haven't looked back since and I tend to get a lot of comments about my bike looking too big for my britches!
#996
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Because people, this is where fit matters the most.
On townies, when getting coffee and going to the grocery store. Can't be losing watts to an ill fitting bike.
#997
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
