BT/ANT+ chest strap
Old 07-23-19, 11:15 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 8821 Post(s)
Liked 582 Times in 352 Posts
BT/ANT+ chest strap
Assuming you have a Garmin that can read either, is there any reason to prefer one over the other?
I'm asking because I killed mine, bought a dual band replacement, and every time I used it, it prefers to connect over BT.
Seattle Forrest is offline
Old 07-23-19, 11:29 PM
caloso
caloso's Avatar
Quoted: 1951 Post(s)
Liked 349 Times in 193 Posts
I got one to act as a bridge transmitter for Zwift, but if your device can read either I guess it doesn’t matter?
caloso is offline
Old 07-24-19, 12:24 AM
Seattle Forrest
I would think they're both data transport protocols, and should be identical. (I only care about the quality of the data.) But every time I assume anything, I wind up wrong. So I'm hoping nobody replies with a horror story.
Old 07-24-19, 04:43 AM
jadocs
jadocs's Avatar
Bikes: Litespeed T2 Disc, Fondirest P4 Carbon, Fuji Cross 2.0, Specialized Fatboy
Quoted: 379 Post(s)
Liked 102 Times in 79 Posts
So I donít know the answer, but ANT allows multiple connections at the same time. BT only allows you to have a single connection. As far as connection reliability, I donít think there is a difference, but I could be wrong.
jadocs is offline
Old 07-24-19, 06:45 AM
John_V
John_V's Avatar
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 324 Post(s)
Liked 7 Times in 7 Posts
I had the same issue with my Bolt. I solved the problem by pairing the sensors to my phone, using BT, before pairing the sensors to the Bolt, using Ant+. I've had the Bolt for a little over two years now and the connections haven't changed. I know you use a Fenix so I'm not sure how or if that will work for you.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
John_V is offline
Old 07-24-19, 11:53 AM
Metaluna
Bikes: Niner RLT 9 RDO, Gunnar Sport, Soma Saga, Workswell WCBR-146
Quoted: 111 Post(s)
Liked 16 Times in 16 Posts
Another area where there might be a reason to prefer one over the other would be power consumption, however I don't know if there's a significant difference between BTLE and ANT+ (probably depends on the specific chips used on each end of the connection).
Metaluna is offline
Old 07-24-19, 12:03 PM
caloso
caloso's Avatar
Yes, because I've been running Zwift through the Apple TV app (BT) I couldn't simultaneously use the Kinetic app (also BT). However, I could connect to my Garmin. But as far as reliability, I have not noticed any difference.
caloso is offline
Old 07-24-19, 01:39 PM
ksryder
Bikes: yes
Quoted: 954 Post(s)
Liked 243 Times in 144 Posts
I think ANT allegedly uses less power than BT but in real world applications the difference is de minimus.
ksryder is offline
Old 07-24-19, 02:08 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6822 Post(s)
Liked 649 Times in 407 Posts
And BT is supposed to have better bandwidth and bigger payload but I wonder how much data a heart rate sensor really pushes.
Its all seems like marketecture.
TimothyH is offline
Old 07-24-19, 04:27 PM
Seattle Forrest
What a simple, elegant solution. Thanks!
Interesting that your Bolt also prefers BT.
Old 08-02-19, 09:12 PM
RGMN
Quoted: 91 Post(s)
Liked 18 Times in 17 Posts
One advantage of BLE over ANT+ is you can get low battery warnings with BLE if your head unit supports it. Both my Wahoo Speed/Cadence sensor and the TICKR have given me low battery warns on the Garmin 130. It won't do that with ANT+.
RGMN is offline
dvai
Road Cycling
12
10-21-18 04:56 AM
Ironump
General Cycling Discussion
8
12-31-17 07:38 AM
DaveLeeNC
2
01-16-16 08:37 AM
BigC_82
7
11-17-15 10:46 AM
DaveLeeNC
8
11-13-15 12:54 PM
