IRD Sub-Compact Reviews/Info?
Old 09-06-19, 03:26 AM
nomadmax
Quoted: 443 Post(s)
Liked 308 Times in 167 Posts
I did an internal and external search for info regarding the IRD Sub-Compact 30/46 crankset. Specifically, I'm looking to hear reviews re the quality or any "gotchas" that may have popped up after you installed it. I have two freewheel, 126mm, friction shift bikes left in the fleet; I'm looking at the IRD to get the gearing down to something manageable for the hills and the numbers seem like they'll be perfect.
From my research I know they're JIS and the recommended BB spindle length is 118mm; that seems a little long, maybe even triple territory? The bikes are an 86 Spec Allez SE and an 84 Guerciotti SL. I'm kinda stuck on the IRD for the way they look and that they come in 172.5mm unlike the Velo Orange.
So I guess my questions are:
Anybody using the IRD and how do you like it?
Was a 118mm BB spindle indeed what was needed?
Thanks
nomadmax is offline
Old 09-06-19, 03:40 AM
horatio
Hump, what hump?
horatio's Avatar
Bikes: See signature
Quoted: 254 Post(s)
Liked 61 Times in 47 Posts
I was unaware of the IRD set. I’ve been debating whether to try the FSA crankset, also JIS. For some reason I just don’t want to go with a triple.
horatio is offline
Likes For horatio:
Old 09-06-19, 04:10 AM
SJX426
SJX426's Avatar
Quoted: 495 Post(s)
Liked 11 Times in 11 Posts
Ird crank
Don't have one but the old Stronglight 93 double uses a 118 spindle.
SJX426 is offline
Likes For SJX426:
Old 09-06-19, 05:15 AM
bikemig
bikemig's Avatar
Quoted: 3892 Post(s)
Liked 225 Times in 183 Posts
Stronglight 99s make a good compact for vintage bikes as well and chainrings are still available.
I have an IRD 46/30 compact as well but I haven't set mine up yet. I'm planning on using it on my 1978 Trek TX 900. I'm running mainly campy gear on that bike and like you I want some decent climbing gear. I figure with a super record RD I can run 46/30, 13-28 7 speed. I wish I could find a 12-28 though.
bikemig is offline
Likes For bikemig:
Old 09-06-19, 06:03 AM
revcp
Bikes: 2015 Borealis Yampa, 1988 Miyata Twelve Hundred, 1985 Trek 720
Quoted: 232 Post(s)
Liked 26 Times in 22 Posts
I have an IRD triple
on my 1985 Trek 720. I can't speak to the double, but my assessment of the triple (48-36-24t) is that it is a fine crankset. Also, my bike requires a 127.5mm spindle. Some bikes require only a 122.5mm, so 118 for a double doesn't sound outrageous.
revcp is offline
Likes For revcp:
Old 09-06-19, 08:10 AM
mpetry912
experienced
Quoted: 123 Post(s)
Liked 66 Times in 49 Posts
I've got an IRD "defiant" crank (with some custom milling and anodize by Jon "Drillium" Williams, RIP) and I'm very happy with this part, it's excellent quality.
Mine is a 110 BCD but it looks like the same forging as the sub-compact. If I correctly recall I used a Phil 108mm spindle with a +3 mm offset.
These are really nice parts, readily available and easy to install. The Stronglight mentioned above is a good vintage item but has the limitation of a minimum 38T inner ring, requires a unique and hard to find removal tool, and is made of very soft aluminum so requires great care during installation and removal,
Mark Petry
Bainbridge Island, WA USA
mpetry912 is offline
Likes For mpetry912:
Old 09-06-19, 08:32 AM
bwilli88
bwilli88's Avatar
Quoted: 467 Post(s)
Liked 30 Times in 23 Posts
Just get a mid level Shimano 110 bcd crankset and a 46t chainring from the bay and a 34 from a compact crankset and it works.
My Cambodia bikes; ?? Zunow, 81 Centurion Pro Tour, 85 Gazelle Mens Market bike, ?? Maxwell Allroad, 12 Fuji Stratos.
bwilli88 is offline
Old 09-06-19, 12:13 PM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2302 Post(s)
Liked 263 Times in 198 Posts
Thanks
I'm not using one, but kudos on them for choosing a smaller BCD that makes a 46/30 easy. There are some pretty ridiculous contortions going on in the "gravel" world to get rings smaller than 34T onto 110mm BCD cranks.
118mm is what my old Sugino GT needs to be set up as a compact double, so it sounds right to me. Older-style cranks with straight arms tend to need longer BBs than modern ones with the arms curving inward to meet the BB spindle.
Originally Posted by noglider
RUSA #7498
ThermionicScott is online now
Likes For ThermionicScott:
Old 09-06-19, 12:18 PM
nomadmax
Quoted: 443 Post(s)
I'm stuck on the 30T small ring.
nomadmax is offline
Old 09-06-19, 12:22 PM
ryansu
Ride.Smile.Repeat
ryansu's Avatar
Quoted: 565 Post(s)
Liked 146 Times in 116 Posts
I used an IRD 50/34 compact once upon a time and liked it FWIW
ryansu is offline
Likes For ryansu:
Old 09-06-19, 11:53 PM
bwilli88
bwilli88's Avatar
Quoted: 467 Post(s)
The difference between 30 and 34 is 3gear inches
Bicycle gear calc
bwilli88 is offline
Old 09-07-19, 03:52 AM
bark_eater
Quoted: 186 Post(s)
Liked 9 Times in 4 Posts
Got any more info on the specific crank model? I 've seen a bunch of crank arms like that listed as BMX cranks but wasn't sure if they where set up or fully machined to take a larger outer ring.
bark_eater is offline
Old 09-07-19, 04:05 AM
nomadmax
Quoted: 443 Post(s)
Bicycle gear calc
In my experience, the difference between a 30T chainring and a 34T on a climb like Alpe d' Huez is more significant than a gear chart will reflect. I'm stuck on the the 30T as I have Mt Evans/Pike's Peak in my sights for next year.
nomadmax is offline
Likes For nomadmax:
Old 09-07-19, 05:37 AM
jlaw
Bikes: 2015 Spec. AWOL Elite, 2007 Spec. Roubaix Elite, 2003 Spec. Big Hit 2, 1998 VooDoo Zobop, 1985 Trek 410, 1984 Trek 620 1985 Trek 620
Quoted: 277 Post(s)
Liked 61 Times in 41 Posts
If the IRD doesn't work out and you want to try 2x10 there is also the new Shimano GRX 2x10 46/30 crankset with 172.5mm cranks.
You'll need a new threaded BB to make it work. About $150 for the whole package.
Perhaps not as much of a looker as the IRD, but a nice product at an affordable price.
One possible place among many to find it is:
https://www.modernbike.com/shimano-g...nterface-black
jlaw is offline
Likes For jlaw:
Old 09-07-19, 05:49 AM
Marcus_Ti
Frozen Solid.
Marcus_Ti's Avatar
Quoted: 2037 Post(s)
Liked 101 Times in 72 Posts
Thanks
Perfectly serviceable part. 118mm UN55 BB does the trick. Unlike most all the other sub-compacts out there it has a C&V vibe, although it isn't that much of a looker....and doesn't cost an arm and a leg doing so.
What size are you looking for, 172.5? I have a crankset and BB lying around in the parts bin I'm no longer using (175mm)
Marcus_Ti is offline
Likes For Marcus_Ti:
Old 09-07-19, 06:31 AM
nomadmax
Quoted: 443 Post(s)
I appreciate the offer, I'm looking for a 172.5, 30/46.
I'll have to go with an Italian thread version of the 118mm x 70mm UN55 for the Guerciotti. The IRD does have the look I'm after. Is yours a 30/46?
nomadmax is offline
Old 09-07-19, 07:08 AM
52telecaster
ambulatory senior
52telecaster's Avatar
Bikes: Bob Jackson World Tour, Falcon and 98 Bianchi Volpe
Quoted: 849 Post(s)
Liked 64 Times in 39 Posts
The ird does look cool. I have an old sugino mountain crank that has the triple version of that and discovered that t.a. makes a 29 for the 94mm bcd. Pretty cool really. They also make a 33 for the 110. These are tiny differences but the placebo effect shouldnt be discounted. Not to mention the differences that are important are the percentage of change. Hence 34 to 30 may only be 3 gear inches, but its also over 10%. At least another gear on a road bike. Might be the gear you need.
52telecaster is offline
Likes For 52telecaster:
Old 09-07-19, 08:00 AM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 1132 Post(s)
Liked 120 Times in 85 Posts
Another option for building a vintage sub-compact: the SR Apex-5 Touring. Effectively a Stronglight 99 copy, but without the need for the proprietary removal tool. I just put a 50/32 on mrs non-fixie's new bike. The 86mm BCD will take a low as 28T rings.
"I spent half my money on bikes and women. The other half I wasted."
non-fixie is online now
Likes For non-fixie:
Old 09-07-19, 08:06 AM
bwilli88
bwilli88's Avatar
Quoted: 467 Post(s)
Upon further checking it is a Fuji crank on my Fuji Stratos, a Japanese market bike.
Here are the markings on the inside of the Crank arms
bwilli88 is offline
Likes For bwilli88:
Rocky Gravol
Classic & Vintage
25
12-10-14 01:18 PM
Odin99
Classic & Vintage
26
08-18-14 10:36 PM
instructions
Classic & Vintage
3
04-15-11 11:27 AM
jim_pridx
Tandem Cycling
6
02-12-10 10:46 AM
Scooter123
Classic & Vintage
7
01-23-10 10:24 PM
