Totally Tubular
#1026
Quoted: 1858 Post(s)
Liked 606 Times
I just picked up my very first set of tubular tires for a bike I'm building. The rims are Mavic GP 7 and the tires are Continental Gatorskin 700x25. I have them on the rims now pumped up to 125 to stretch. I'll take them off this weekend and glue them on. I'm debating trying my first glue job myself or going to my LBS.
The only ones that seem to think it's difficult are people that ride Clinchers...
Get yourself a small brush about 5/16" wide and some quality Glue. After stretching the tires wipe the inner portion of the rim with Acetone. Put a liberal layer of glue on both the rim and tire let dry for at least 24 hours. Then put another layer on the rims let dry for about 30 miniites then mount your tires and inflate them to 40 lbs. Then position the tires so they are straight on the rim. Once you are satisfied with the positioning pump them up to 125psi and let them cure for 48 hours.
#1027
Quoted: 2432 Post(s)
Liked 638 Times
#1028
Quoted: 1949 Post(s)
Liked 2,010 Times
I used to use a brush for applying glue and it works. BUT now I use a sandwich baggie and put my finger in the corner of the bag to smooth out the glue after I put a dab between spoke holes. (I use tubes and not the can of glue.)
#1029
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
Long time listener first time poster, just mounted my first set of tubulars yesterday at @RobbieTunes suggestion a while back I went with tufo's with tufo tape.. holy crud was that a pain to get them onto the rim's. But with the information in this thread everything turned out well for my rebuild.
#1031
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
Don't give up on tubulars if the Tufos seem no better than clinchers.
You'll just need a better tubular.
As for difficulty mounting, did you pre-stretch them?
#1032
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
The Tufo's seemed fine on the shake down ride, I slightly under inflated them knowing that they would probably stiff. And yes, pre stretched manually and then onto rim's, they were still tight tight tight though.
#1033
Veteran, Pacifist
Liked 4,836 Times
Tight is what you want (), but I've never taped tubulars so not one to offer advice (tho I might try on next new pair - Veloflex 28s). My experience is with Vittoria Rally, Conti Sprinters&Competition, Schwalbe (various), Veloflex (various), Challenge Grifo, Specialized 24mm. The tightest to mount during an initial pressure test gets pre-stretched on a rim longer, or with arm pressure (rare).
Interested in knowing the rim.
My hands are no longer so strong, but can still mount them, at home, without tools - something I cannot say about my clincher experience. I haven't had an on-road flat in ages, removing some of my glue jobs requires a special knife-like tool.
I probably need to find the place in this thread where mounting with tape is discussed more fully. With tape, I wonder about making minor adjustments on the tire/rim during the first 5 minutes after mounting.
#1034
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
#1036
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
I've got a friend who wanted to change his tire so I got to try it out.. apparently I have very strong thumbs and he was grateful, tbh it didn't seem to bad at all to roll it off.. and the tape pulled up relatively easily, I was also grateful because I too was worried about roadside tire changes
#1037
Liked 638 Times
I just came across these Specialized Espoir's that only cost $40. They're like my Vredsteins. 220tpi, butyl tubes and the tread has a harder compound in the center. I'm going to go with them next.
https://www.specialized.com/us/en/es...=228183-131790
#1038
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
I have done this a couple of times using Miyata rim tape. Some tape stayed with the tire, some on the rim. I carry a small bit of tape just in case. To facilitate removal, I do not put tape on the rim between the two spokes directly across from the valve. It gives you a starting point for removal.
#1039
Quoted: 591 Post(s)
Liked 663 Times
Adjustments are made before you remove the protective tape. You leave a bit of the tape hanging out to the side and once you are satisfied with the placement, you pull it out. Once it's out, it is not recommended that you readjust the tire.
#1040
Quoted: 140 Post(s)
Liked 13 Times
But stll, for $40....... not much downside risk
#1041
Quoted: 1361 Post(s)
Liked 423 Times
-Info:
https://www.tufo.com/en/tubular/
Still I think the budget end Tufo tubular are worth it for everyday use or if you have a fleet of bikes on tubular. True they are less supple but for the trade off of puncture resistance (never ever a pinch flat), very consistent on quality and roundness -superior to any other budget class tubular.
I've recently switched and ready to try the budget Panaracer Practice. Have two bikes ready with them but have yet myself ready to roll. Priced less than any other, so far look good.
Personally I'm not into the taping. Tried Tufo but with a Vittoria tubular. On removal it was so strong it pulled the base tape off. Admit the tubular was older but never had this kind of an issue.
Tufo tubulars are good for the budget minded. But if really want the 'tubular experience' you must upgrade. Keep a watch for big discounts on the premium tires, grab em for stock. Often those are only $10 or $15 more than the low price Tufo.
Cheers
Edit to add:
Noticed you have those Tufo's on a steel framed. That's good. Not the same if you had those Tufo's on a stiff aluminum frame. Then again, all depends where one rides, some have the best of roads and not much any of this talk matters.
#1042
Liked 638 Times
This is what they look like.
#1043
You know when Taiwan Vittoria has gone down the tubes when they still label as 28" and the sidewall molding state 'clincher'. LOL
These pair are brand new, out of the wrapper. A portion of the top tread layer is separating and I need to syringe glue to repair. Still usable rubber but jeez.... [img]
DSC_2511 by carrera247, on Flickr[/img][img]
DSC_2510 by carrera247, on Flickr[/img]
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
#1044
Quoted: 140 Post(s)
Liked 13 Times
I’ve been down the Tufo road and i really like the durability.
However, I ended up with a pair of Corsa Speeds and took them for a spin, and am now rethinking my whole tubular approach.
#1045
I cleaned some thick glue off a set of rims last night with what I had on hand. Steel wool and Goo Gone. It went pretty fast and cleaned the rims like new. It worked great. I would do it again.
#1046
Bikes: 1987 Waterford Paramount; 1986 Pinarello Montello; 2003 Lyonsport; 1986 Bridgestone Mile 112; 1981 Univega Viva Sport; 1984 Raleigh Gran Tour
Quoted: 16 Post(s)
I'll just toss out there that for anyone in goat head country, Tufos are fantastic. I rarely flat for any reason other than a goat head, but since switching to Tufos + sealant, I now rarely flat on my tubulars at all, and certainly have fewer flats than I get on my clinchers. You won't get the same kind of sealant performance in a traditional tubular. I can't speak to road tubeless clinchers.
And I don't think the Tufo ride quality is poor. Not the best, but a perfectly acceptable trade off.
#1047
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I wish I could claim such success. Maybe this Goo Gone stuff is the answer.
Real cyclists use toe clips.
jimmuller
jimmuller
#1049
It worked way better than acetone. No toxic fumes or burning skin and it cleans up easily with dish soap and water. I just put it on liberally and rubbed the steel wool fast back and forth a section at a time until no more glue.
#1050
Liked 645 Times
