Perhaps bike weight means nothing!
Aluminium Crusader :-)
*Mountain climbing excluded, of course.
A special thread for all the weight weenies out there
A fast bike on flat roads is about rigidity and aerodynamics, not weight.
All the "bollockle" talk about rotational weight, and accelerating a certain mass from x speed to y speed requires 'this' much energy, etc, etc...blah, blah.....check out the heavy weights of some the track bikes at the recent World Championships. And being track bikes, they obviously don't have cassettes, brakes, etc.
Plenty of people on this forum wouldn't go near a road bike unless it was under 17.5lbs (8kg)! Theo Bos got his 17.5lb 'clyde' up to 44.3mph without a tailwind!
Damian Zielinski's Isaac.............16.3 lbs
Clara Sanchez' Look...................17 lb
Roberto Chiappa's Pinarello.......17.3 lb
Maximilian Levy's FES.................17.4 lb
Theo Bos' Koga/BT.....................17.5 lb
Dutch team pursuit Koga/BT.......17.8 lb
Stefan Nimke's FES.....................17.9 lb
Tuen Mulder's Koga/BT...............18.5 lb
Dutch team pursuit Koga/BT.......19.2 lb
Dutch team pursuit Koga/BT.......19.4 lb
Dutch team pursuit Koga/BT.......20.7 lb
https://www.cyclingnews.com/track/200...k_worlds_bikes[/QUOTE]
Accelerating a mass from 0kmh to 60kmh+ is more important in track events than anywhere else, but some of these bikes are close to, and over, 18lbs!!! And if anyone says that the big guys need big bikes, the pursuit guys aren't big, and look at the weight of the Dutch-owned BTs
100% USDA certified
Liked 6 Times
I need more threads like this. My '05 steel Bianchi weighs around 24 pounds and I constantly think I should've gone with a lighter Alu frame or something..
"Great One"
Location: Might as well be underwater because I make less drag than a torpedoE (no aero bars here though)
Haha. I keep telling noobs the same thing. LOL@ rotational inertia is the most important aspect of wheel acceleration.
wtf is "rotational inertia" I did senior physics (last year) and came 3rd, but Ive never heard the term.
Ca-na-da?
Bikes: none at the moment
Maybe just slow adoptor's? I'd imagine they'd want stiffness over weightsavings anyday. They also don't do 10 minutes of climbing on a track. And in track wouldn't a heavier bike help carry more momentum around a turn, aswell as pick up speed faster when attacking from the top of the track?
mythbuster
He means rotational weight: more weight at the wheel rim, ergo, slower wheel acceleration.
It takes a bit more energy to get heavier wheels going, but they hold their speed better than light wheels. Thus, rotational weight has minimal effect on overall bike performance, unless you're in a riding situation that requires repeated braking. In that case, you repeatedly waste the energy you put into accelerating the wheels.
In climbing, heavy wheels don't slow you down anymore than extra weight would elsewhere on the bike (or on your body).
JOCP Lives!
Bikes: 2005 Felt F90 (my pride and joy)
I thought we already established this fact from hip's knave threads.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
The heavier weights you give are for pursuit bikes (presumably with disc wheels) Only have to be accelerated once on a smooth surface. Obviously aerodynamics are going to be more important than weight on a pursuit bike. It would be interesting to contrast the weight of the the srpinters bikes with the pursuit bikes.
Also, this really is an apples to oranges comparison. Track racing at least sprinting is about big guys producing incredible power. Marty Nothstein had to lose at least 40 pounds when he went from track sprinting to doing criterium races. I bet you Marty's crit bike weighs somewhere close to the UCI limit.
impressive member
Bikes: c'dale supersix, jamis trilogy, spec. tricross
i've never been on a track, but i've climbed plenty of 10K foot multi hour climbs, and both simple math and my experience suggest that in that context weight matters a bit. which is the only context (outside of vanity) i've ever heard it seriously suggested that weight matters much anyway.
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
By the way, I tried a LW Giant today and the difference was incredible! I took off like I would to sprint my steelframed bike andf the Giant literally felt like I had a JATO rocket attached! Not kidding!
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Shoebomber
Bikes: 2008 Canyon CF Pro w/ Chorus, 2005 Moots Vamoots w/ Ultegra, 1988 Cannondale commuter
I don't think that that weight matters as much as some people think (ie: the endless pursuit of that 15 kg lighter stem) but there is a significant difference between climbing on my old 28 pound touring bike and my 17.5 pound road bike. On flat roads they would cuise at about the same speed, although acceleration and climbing on the old bike is a different story.
"A fast bike on flat roads is about rigidity and aerodynamics, not weight." The key word here is flat.
Bikes: highly modified specialized crossroads and GT hybrid (really a [formerly] 12-speed bmx cruiser, made before 'hybrid' took on its current meaning), as yet unmodified redline 925, couple of other projects
Feed me your soul!
Bikes: Torelli 20th Anniversary, Trek 2000, Kona NuNu
Bicycling magazine did a study a while back... the conclusion was given the same effort, for every pound you shave, you gain 6 seconds on a 20 minute climb. My bike weighs about 18 seconds slower than the pros ride.... The comfortable ride I have is more than worth the few seconds I might gain....especially since I don't race.
Originally Posted by merlinextraligh
The heavier weights you give are for pursuit bikes which only have to be accelerated once on a smooth surface. .
It would be interesting to contrast the weight of the srpinters bikes with the pursuit bikes.
I bet Nothstein's criterium bike was NOT 15lbs!!!
Used to be a climber..
Bikes: 2016 Ridley Fenix SL, 2020 Trek Emonda ALR (rim brake)
Quoted: 7 Post(s)
My 5200 in "riding form" (2 full waterbottles, seat pack) weighs in at around 24 pounds.....
Quoted: 9 Post(s)
Liked 22 Times
Originally Posted by ZachS
did you measure how much your speed/time actually changed?
Bikes: 2012 Trek Madone 6.2
Originally Posted by 531Aussie
really? Every third thread on this forum about someone looking for the lightest wheels on the plant, and every fifth thread is about someone wanting to get their bike uner 16lbs. You KNOW these people think this will make them faster
Bikes: Yeti ASRc, Focus Raven 29er, Flyxii FR316
Quoted: 17 Post(s)
Those guys are also riding full disc front/rear wheels in a lot of cases. Particularly the last couple of guys, who are members of the 4k Team Pursuit. They're concerned about aerodynamics and stiffness, not weight. If these guys were climbing the Galibier, Alpe d'Huez, or the Izoard, you better believe they'd want sub-16lb bikes. Horses for courses, my man. Don't be naive enough to think that they haven't carefully considered the pros and cons of their bikes, and wouldn't change them if the situation called for it.
Riding a bitsa
Interesting for me a noob all the wisdom here. The folks on this thread saying that mass is irrelevent in a bike are clearly way ahead of the guys who make the bikes for the G d Italia or the TdF riders. Those fools think mass really does matter. Maybe they need to learn a bit from the guys here on those 28 lb bikes.
i don't think anybody's saying that mass is irrelevant. what people are saying is that the difference in mass between a 15 pound bike and a 23 pound bike is irrelevant for most riders in most circumstances. which it is.
most people in most circumstances ≠ folks who are paid to ride up hills faster than other people
Dirt-riding heretic
Bikes: Lynskey R230/Red, Blue Triad SL/Red, Cannondale Scalpel 3/X9
Quoted: 5 Post(s)
Liked 8 Times
1. They're trying to shave MINUTES off of races that last WEEKS.
2. They have unlimited cash (and that's an important one).
3. Their bikes are being ridden by athletes who produce consistently huge amounts of power so a tiny weight difference is actually noticeable.
4. Those riders also have NOTHING extra on their bodies that would negate a weight savings on the bike.
So, for you or me, the normal human riders of the world, is it worth it to spend $7000 to shave 2 pounds off my frame when the motor has 10 extra pounds sitting on it?
I'm just glad it doesn't cost that much for ME to lose weight-- $1500 for my Flyte, a few hundred for my OCP helmet and clothes, and any excuse to go out and ride.
DrPete
