Anybody around 6'2"
Anybody around 6'2"
Old 05-09-06, 07:44 PM
Trev Doyle
Hamburger Pimp
Bikes: BMC SLT O1 Team Full Record, Kuips SuperNova Ultegra & DuraAce, Rocky Mountain Team Scandium full XTR w sids & dope parts, Guerciotti Khaybar Full Record.
Anybody around 6'2"
I need to direct a friend whocould possibly buy his first road bike tonight or tomorrow off of ebay on approximately what size frame to get. Without getting into a huge discussion about specifics, can anyone who is 6'2" tell me what size top tube they ride? Thanks
Trev Doyle is offline
Old 05-09-06, 07:53 PM
PedalMasher
214/13
PedalMasher's Avatar
umm... I'm 6'2" with a 32" inseam. I'm all torso, so I ride a 60cm with the seat way low. The 60 cm felt I currently ride has a 23 cm top tube. My trek is 22.5" (It think)
PedalMasher is offline
Old 05-09-06, 07:59 PM
dr_cantalope
dr_cantalope's Avatar
Bikes: Fuji Sagres
I'm a shave under 6'2" and ride a 58 cm Cannondale R700 but with a 90mm stem instead of the stock 110mm one (because I have proportionally longer arms). I think your friend would be safe between 58 and 60 cm.
dr_cantalope is offline
Old 05-09-06, 08:00 PM
Az B
Fattest Thin Man
Az B's Avatar
Bikes: Miyata 610, Vinco V, Rocky Mountain Element
I'm a little different from PedalMasher. I'm 6'1.5" with a 34" inseam and ride a 58cm frame.
A 59cm is really ideal for me, but I can make a 58 or 60 work. I have a 61cm frame and it's too far to the bars.
Az
Az B is offline
Old 05-09-06, 08:04 PM
big john
big john's Avatar
Quoted: 357 Post(s)
Liked 83 Times in 63 Posts
I'm 6'2" and I have a 35" inseam and I ride 63 0r 64 frames and I prefer a 60 cm top tube with a 100mm stem. I could probably ride some 61 frames but I like the bars up pretty high.
big john is offline
Old 05-09-06, 08:05 PM
Dalai
Quoted: 86 Post(s)
So dependant on the individuals dimensions...
Better to get your friend to use a fit calculator such as http://www.competitivecyclist.com/za...LCULATOR_INTRO to get a more reasonable idea of what to look for.
I am 6' 1" and all my road bikes have been 56cm (preferable) or 57cm frames with a similar length top tube.
Dalai is offline
Old 05-09-06, 08:07 PM
Talewinds
Talewinds's Avatar
Bikes: (2) 2004 Trek 1500, Team Colors:2004 Cannondale Ironman w/ Renn and Zipp: 2005 Kestrel Talon SL: 2001 GT Agressor: 2001 Schwinn Moab: 2001 Specialized S-Works M4 Festina Team Bike: 2002 Pinarello Prince: 1980 Schwinn Voyageur 11.8
Without getting into a huge discussion, 58cm frame.
Talewinds is offline
Old 05-09-06, 08:11 PM
Thylacine
Industry Maven
Thylacine's Avatar
Bikes: Thylacines...only Thylacines.
I'm 6ft 3andabit, and ride a 605mm top tube with a 120mm stem. Roughly your friend would need something in the vicinity of a 58-60cm, but it's hard to say exactly.
I wish I could believe some of those online calculators, but the numbers I get out of them are quite frankly, wrong.
My current bike is a result of years of experimenting and multiple fits by various systems, culminating in getting fitted up by a renound cycling physiologist. My top tube is 605mm TT, stem 120mm, and saddle setback 90mm. Something like the Competitive Cyclist pumps out figures like 570mm TT, 120mm stem, and 70mm saddle setback.
Thylacine is offline
Old 05-09-06, 08:14 PM
mollusk
Elite Fred
mollusk's Avatar
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 44 Post(s)
6' 2" with shortish legs. I ride a 57 cm Lemond, but I've had 58 cm Cannondales and a 59 cm Bianchi. Top tube length is more important than seat tube length. You can make BIG adjustments with the seat post but much smaller adjustments through saddle position and stem lengths. Just make sure the standover isn't too close to the "valuables".
mollusk is offline
Old 05-09-06, 08:45 PM
shawneebiker
Bikes: Whatever I want
I'm 6'2" 34.5" inseam. Have a 58 cm t.t. with a 100mm stem.
shawneebiker is offline
Old 05-09-06, 08:47 PM
Portis
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
Yeah, me too. Not all 6'2" riders are built alike. Not all 58 cm bikes are either.
Portis is offline
Old 05-09-06, 09:00 PM
Dalai
Quoted: 86 Post(s)
I didn't say they are the definitive answer. But a better starting point then basing the framesize only on peoples height.
Then it takes time to fine tune the fit to how you prefer to ride...
Dalai is offline
Old 05-09-06, 09:03 PM
Flippin Sweet
oh, snap.
Flippin Sweet's Avatar
6'1", 35cm inseam. 60cm. But beware, I'm female, we have slightly different dimensions with regards to fit.
Hi. I don't think we've been introduced. I'm awesome.
Flippin Sweet is offline
Old 05-09-06, 11:08 PM
belowzero
belowzero's Avatar
6'2" riding an L frame at 58cm, handlebars 44cm. Wouldn't go higher myself as I'm very flexible used to riding a short top tube mountain bikes. I have ridden a 56cm road frame also very quickly with a higher seatpost.
belowzero is offline
Old 05-09-06, 11:28 PM
marqueemoon
or tarckeemoon, depending
marqueemoon's Avatar
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
I have a 34 inseam and I ride from from a 56 to a 58 top tube. I rode a 60 for a while (2 different bikes) and it felt huge.
marqueemoon is offline
Old 05-09-06, 11:47 PM
nobrainer440
I play in the street.
nobrainer440's Avatar
Bikes: 2005 Allez Triple, 1971 Schwinn Varsity Fixed Gear Conversion
I'm 6'1" and a bit. I ride 58 cm frame, don't know how long the top tube is.
nobrainer440 is offline
Old 05-09-06, 11:54 PM
53-11_alltheway
"Great One"
53-11_alltheway's Avatar
Location: Might as well be underwater because I make less drag than a torpedoE (no aero bars here though)
The top tube is somewhat irrelevant due the impact of seat tube angle on things.
A steeper seat tube angle allows more set-back on the seat relative to the top tube thus neccessitating a shorter stem all things being equal.
I'm 6'2" and ride a 58cm cannondale, but I could ride up to a 60cm if I wanted a more upright position.
53-11_alltheway is offline
Old 05-09-06, 11:58 PM
jimx200
I am 6-2, ride a Bianchi Eros in 59cm.
jimx200 is offline
Old 05-10-06, 03:03 AM
socalrider
socalrider's Avatar
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Surly Crosscheck Cyclocross bike, Fisher Supercaliber Mtn. Bike
6'3 and ride a 60cm Merckx and 61cm Litespeed.. The Litesspeed is measure C-T, so actually it is more like a 59.5 C to C..
socalrider is offline
Old 05-10-06, 05:04 AM
adam w
6'2 ish. I ride a 56 specialised allez comp. I have 58 cm allez for the wet and it is too big. If i were to ride a trek i would have a 60cm, a bianchi the 59cm fits me.
adam w is offline
Old 05-10-06, 06:58 AM
NomadVW
部門ニ/自転車オタク
NomadVW's Avatar
Bikes: 2008 Blue T16, 2009 Blue RC8, 2012 Blue Norcross CX, 2016 Blue Axino SL, 2016 Scott Scale, Fixie, Fetish Cycles Road Bike (on the trainer)
6'1"-6'2" depending on the humidity, I ride a 61cm Roubaix, 130mm stem.
Envision, Energize, Enable
NomadVW is offline
Old 05-10-06, 07:05 AM
jfmckenna
Tiocfáidh ár Lá
jfmckenna's Avatar
Bikes: A whole bunch-a bikes.
Quoted: 281 Post(s)
I was always under the impression that the TT is the most important measurement. If it is a compact frame you are talking about then you measure the virtual TT length.
I am 6'3'' and I ride a 58.5cm TT with a 12cm stem
jfmckenna is offline
Old 05-10-06, 07:51 AM
MKahrl
Bikes: Rivendell A.Homer Hilsen, Paramount P13, (4) Falcon bicycles, Mondia Special, Rodriguez Tandem
Quoted: 38 Post(s)
Liked 3 Times in 2 Posts
I am 6' 1 5/8" with 35" inseam and rode a 58.4cm frame back when I was a fickle follower of undersize frame fashion but since then I've returned to more properly sized 61cm frames and one slightly large but very comfortable 63.5cm frame. So besides height and inseam, frame size also depends on how far along you are on the lifetime of cycling experience.
MKahrl is offline
Old 05-10-06, 09:47 AM
jotconnor
6'3" with a 36" actual inseem barefoot. I ride a 62 (C-T if it makes a diff) with the seat actually pretty high and about a 120 stem. honestly I don't know the TT length. I think its kinda short though
jotconnor is offline
Old 05-10-06, 10:01 AM
noisebeam
Al
noisebeam's Avatar
Quoted: 3512 Post(s)
Liked 88 Times in 61 Posts
6'2"
57cm Lemond with 58cm TT
61cm Centurion with 57cm TT
58cm TT is what fits me best
Al
noisebeam is offline
