Need some help building a friction drive.
Old 07-11-19, 09:14 AM
linberl
linberl's Avatar
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times in 288 Posts
Originally Posted by MikeyMK
Friction drive on wet/muddy tyres and you're doing maths?! Lol
And the reason we use 54v on a 48v system is because of voltage drop. A half-full 54v battery is around 48v, and it's 42v by the time it needs charging.
Use a 48v battery on a 48v system and it'll cut out at the first steep hill.
Who said they are riding wet muddy paths? I live where the weather is GOOD, lol. But, in any case, the system I bought has user replaceable belts designed specifically for dry/normal or wet (more grip). Friction drives have come a long way as better materials have developed. And some, like the 1M, even have sophisticated software actuated engagement adjustment. Did you read about how it works, or were you just making a comment based on the old reputation of friction drives?
linberl is offline
Old 07-11-19, 11:09 PM
evbkzzzz
Originally Posted by linberl
I'm hardly an expert, but I think it depends on what you want and how you want to use it. I know mid-drives are great for folks who climbs lots of hills. Hub motors aren't as good on hills but are great on flatter terrain. Both are fine for someone who wants to run the motor all the time on their rides. I've never had a mid-drive but I had a 350w front hub bike at one time, and it suffered on really big hills (Bay Area) and got super hot. Friction drives are, I think, for someone who wants to just have some assist maybe on hills and in winds or to keep up with others on rides, but wants to preserve the human powered nature of their bike...especially if they have a lightweight bike. What do you want? Or are you just looking to build what seems interesting?
I will do hills occasionally. Yeah, I want to build the ones that are interesting. I wouldn't mind if had to build both mid-drive and a friction drive to serve different purposes. I have a lot of free time which I want to dedicate towards building things like these....
Originally Posted by chas58
When engineering my build of a hub motor, I had to balance the motor windings, noload speed, human input, hill climbing, motor torque, motor speed, motor power. Its purpose built for me, rather unlike anything else, and does 25mph for 25 miles with 25lb weight (+3lb battery, lol).
Of course you can just build a 50+ lb bike that goes 15-20mph without any design effort.
yup, what linberl has is a good alternative too (if you want low torque, fair weather, light weight low powered build). So many Choices!
Oh thanks, You designed the motor yourself? It is too much for me atm.
evbkzzzz is offline
Old 07-12-19, 07:39 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
I used off the shelf motors. Its not harder than what you are doing. Typically there are 3-4 varieties of a motor (different motor windings). These are for different voltage levels and different wheel sizes.
If you are climbing hills, you may want lower voltage (speed) and higher current (amps). In my case, my commute is flat, so I can over volt my motor and get more speed out of it while keeping the weight down. I could backtrack from the no load speed to a reasonable road speed, but that ebike.ca calculator really takes a lot of the guesswork out. If going outside of the conservative “out of the box” design configuration, I can understand how changing motor winding, Voltage, Current will impact speed, acceleration, climbing, and critically – overheating.
chas58 is offline
Old 07-12-19, 10:59 PM
evbkzzzz
Thanks.. Should read up on that. Do you have any resources that you can share?
evbkzzzz is offline
Old 07-14-19, 10:25 AM
MikeyMK
Cycleway town
MikeyMK's Avatar
Bikes: 2.6kw GT LTS e-tandem, 250w Voodoo, 250w solar recumbent trike, 3-speed shopper, Merlin ol/skl mtb, 80cc Ellswick
Quoted: 569 Post(s)
Liked 169 Times in 117 Posts
The topic starter in their opening post...
Be able to use on wet and muddy weathers
MikeyMK is offline
evbkzzzz
Electric Bikes
2
07-11-19 07:19 AM
Faddy Daddy
Electric Bikes
21
09-07-16 02:03 PM
HeyPhil
Electric Bikes
2
08-10-14 09:20 PM
Shahmatt
Electric Bikes
34
12-21-13 01:48 PM
likebike23
Electric Bikes
10
12-10-13 02:53 PM
