Would you buy this frame?
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
If it was otherwise to your liking and offered at a good price? Pics otherwise suggest a good solid frame and I can’t see any signs of crash. My thoughts are that this is likely just a paint anomaly.
Quoted: 18378 Post(s)
Liked 4,512 Times
I'd buy it if I got a good price for it. But, it depends on what you're planning to do with the frame, and whether you would be able to repair it if it went bad.
I'm not sure I'd wish to ride a bike that I wasn't 100% sure the brake bridge was good.
Is the frame local?
Can you feel any movement in either the bridge or the the seat stay?
Was the frame re-sized from 126mm to 130mm? Are the seat stays straight?
Is the frame local?
Quoted: 3241 Post(s)
Liked 2,512 Times
Is it uniform? Looks uniform. What does the other side of the bridge look like?
If at all possible, I'd want to ride it first or subject the frame to a bit of load on the DT (i.e. stand on the DS pedal with a bit of weight while braking and observe the area of the crack) to attempt to determine whether 'paint anomaly' or 'brazed joint failure' best describes the situation.
Could easily be just paint, but failure of the joint is a possibility.
I'm pretty sure I've broken my Raleigh Pro in exactly that location, 40 year old brass joint has given way; on a ride, I had a perplexing 'click' make a sudden appearance under heavy load in certain circumstance, and noticed a not dissimilar pattern of cracking following the brake bridge/seat stay joint. The cracking was not there prior to the ride, and the noise cannot be traced back to any of the usual DT suspects. I still need to blast some paint off to inspect closely (and perhaps have inspected by a frame builder if I remain unconfident)...
In any case, it's not like it's a difficult repair if the joint is suspect. But repair is going to take a good chunk of paint off, of course.
If I were purchasing, I would either want to know more, or be confident that I was comfortable with the gamble of not knowing for sure at the price being paid.
Bikes: Numerous
Liked 3,098 Times
It’s on eBay. 100% high feedback seller. The other side of the bridge looks pristine, a couple of normal looking little scrapes on the outside of the seat stay but everything looks straight and in general nothing tells me the bike has been abused. The exposed metal on the bike, like the shifter bosses and rear dropouts have the dark colored oxidation like the bike has sat unbuilt and unused for a while. Also the seat stay cap on that side looks normal.
if I get it at the price I think I can, it would be worth a gamble. Comes with a Dura Ace headset, bottom bracket, and a nice seat clamp bolt. I figure there’s maybe a 10% chance that’s a serious issue and if unusaeable I would probably be out about $100 after factoring in value of parts and fork.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
SL,
It is not the best way to start out with a build..If the paint on the right side of the BB is cracked all around it would seem as though there has been some stress put on that joint and there may be a compromise going on in that area. If you do decide to purchase it as others have said put it through its paces...I would put a dab (spot) of nail polish on opposite sides of the bridge that are easy to see and look for any cracks.
GL, Ben
GL, Ben
Voltaire
Voltaire
Liked 4,512 Times
You might as well toss up at least the higher res photo supplied by the seller.
The seller answers a couple of questons in the ad:
I was initially concerned about marks just below the seat lug on both sides, but I think that is caused by pump wear.
Back to the joint above. To me, it looks like a focal stress to that joint, probably due to an outward pulling of the stays at the bottom (thus affecting the bottom paint without affecting the top paint).
Hard to say, my tolerance is pretty high, but I don't think I would ride that bike without peeling off more paint and carefully inspecting the joint. I presume a repair would be easy, although rust could be an issue necessitating more prep than I would otherwise expect.
Click on the little red "report" button, and ask this thread to be moved to the Framebuilders subforum for more eyes on it.
Edit:
There also appear to be some outward stress cracks in the paint on the seatstay emanating from the bridge. I really think that joint has undergone some extreme stress.
- Frame set to 125mm (probably not cold-set, although the previous owner could still have been using 130 or even 135mm wheels in it).
- Cracking is only on 2 sides of the bridge joint (Lower res view of other sides are visible on seat lug photos) showing good paint).
Edit:
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
My guess would be it's the result if the dropout widening, too. I bet it stressed the bridge causing the crack. Can't tell if it's just the paint. Personally I'm not big believer in cold setting frames - aka 'bending' the frame. But as you pointed out OP, not a big loss if you get it at the price you want. I say go for it!
I would also be careful about assuming ebay will automatically side with you considering it seems like you've been warned adequately by the seller. Just something to think about
Liked 4,512 Times
Diagnosis likely will require stripping at least all the cracked paint and inspecting the joint under it.
The ultimate price should reflect the expectation of possible damage and repairs.
Liked 4,512 Times
I suppose, the question would be whether you would pay $260 for the fork, bottom bracket, headset, seatpost bolt, and dropout adjuster screws..
If you aren't doing the repair on the main frame, you might be able to toss it on local Craigslist for $50, although I'm not sure how I feel with selling broken and potentially dangerous parts. Full disclosure?
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
What Brand/type tubing is the frame? If its a notable frame its worth a shot buying it and fixing.
Luckily its painted solid white, so any repair wouldnt be too hard to touch up paint.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
If that's the only worry on the frame, git it. If need be, that's fixable at l'atelier for beer money. White paint should be easy to match at an automotive paint shop.
Quoted: 4722 Post(s)
Liked 3,038 Times
I'd assume that is a crack in the braze due to spreading the rear triangle. It is an easy and relatively inexpensive repair. Also, the repaint of the stays is not a big issue. However, it's $200 plus $90 shipping for a mid-1980s Rossin SL. I'd pass, unless it's one of your grail frames.
Bikes: Numerous
Liked 3,098 Times
Thanks all. It’s $30 shipping to my locale. Still thinking about it. Rossin is one of those builders I’ve been after a long time and it seems like they’ve been getting harder to find at a decent price. I could let Gugie apply the torch to fix it, apply fender mounts, bell holder ....
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Liked 5,802 Times
Bikes: '74 Raleigh Professional, '73 Raleigh Grand Prix, '84 Nishiki Medalist, '85 Gazelle Champion Mondial AB, '81 Peugeot Course, '79 Univega Gran Rally, '85 Torpado Super Strada
Quoted: 67 Post(s)
Liked 10 Times
If the seller has pointed it out and already factored it into their asking price, I would probably pass unless you just “have to have it”.
If it can be used to negotiate the price down a bit to account for the cost of potential repairs, then it would sound like a safer buy to me.
Liked 2,512 Times
Anyone bought it yet?
Quoted: 2363 Post(s)
Liked 1,749 Times
Since the paint is cracked anyway, maybe the seller should remove some of the paint on the stay and the brace, and get some closer shots of the braze itself. The paint in that area is gonna have to come off anyway, esp. given the relative ease of a match later as said.
Quoted: 1104 Post(s)
Liked 1,825 Times
That would be like opening the box that contained Schrodinger's cat He's better off leaving the idea that it's 50/50 than remove all doubt.
Liked 4,512 Times
The repair should be pretty straight forward, but you'll likely be spending $100 to ship the frame across the country and back.
I suppose that might be one advantage of trying to get better info from the seller. Try to determine the status before shipping.
Shipping direct to a 3rd party might be complex, but you could save a little shipping that way.
Liked 1,825 Times
Oh, man, @gugie has been salivating about the idea of bending the fork and installing Cantis on a Colnago for me. It is all I can do to keep his torch away from the bike... Well... I HOPE
