Carbon fiber frame spliter
So being the curious kind, I wanted to try a belt conversion for my bike. Since we have an engineer on hand and a carbon fiber 3D printer we elected to design our own. So here goes ...
This set of carbon fiber frame splitter that require nothing but cutting the upper rear wheel support 1.5 inches. The part are epoxied in place and we used off the shelf JB Weld with great results. So this mod can be performed with minimal tools and costs.
We are still in the final testing phase but will releasing these to the general population and bike shops. With this post we are looking for general feedback on the whole thing.
Thank you to all the community.
Pat
Pat
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 762 Times
Well, it’s called the “seatstay” for starters, but beyond that it assumes that all seatstays are the same, which they are not, so you would have to produce dozens of different designs. Then, the seatstay is tapered, so the locations of the two cut points would have to be very precise to avoid too loose or tight fit. Frankly, I think your market size is one, namely yourself.
Not to worry ...
The frame was a donor bike that we can do destructive testing on ... LOL
As for the tapered factor the parts can be sanded down to accommodate the different sizes without altering the structural integrity, we can even provide custom made ones for square tubing and all.
I do understand that this is not for your 6k$ bike frame but to allow for those with lesser quality frames to get the benefits of running a belt drive without buying a dedicated new frame.
Thanks for the constructive criticism ... As always.
On a side note, please understand that for many of us it doesn't make sens having a high quality ,pricy and blinggy commuter bike that gets stolen the minute you chain it outside your workplace or school.
I think it's an interesting design. Looks like a fine way to do it IMO. That said, I'm just meh about belt drives. Seems like more trouble than it's worth.
Well then, what's the point of cutting up and installing a belt drive on a beater?
Again really appreciate the criticism.
Thanks !
Pat
Bikes: stinner cx, paramount track
Quoted: 262 Post(s)
Liked 9 Times
with so much bicycle infrastructure out there compared to america, why do european art students insist on overdoing EVERYTHING when it comes to the bicycle?
Quoted: 1422 Post(s)
Liked 7 Times
Serious question if you are going to sell these...
Who going to pay when they break and cause bodily injury of some kind? What is your liability? No, a waiver is not going to hold up in court.
But thanks for asking
Pat
Master Sarcaster
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
Here's where my concerns would be:
1. Impact on handling and stability.
Seat stay is a load bearing component both vertically, and to a lesser extent torsionally under pedaling load. How does the asymmetrical construction material affect the rear triangle? As you have a full tube of one component on one side, and a cut tube with a different material on the other, will this cause any twisting or deflection of the rear wheel under loads? Additionally, if this is an end user installation, how do you ensure that the end user makes their cuts the proper length, changing the length of the stay and thus rear wheel alignment?
2. Frame warranty.
This obviously voids any warranty on the frame. Will you accept liability for any other frame issues that would have otherwise been covered by the manufacturer?
3. Questions I'd ask if I were an investor... What is the market?
Given 1 and 2, what is the marketability of the product? I can see that it does serve a purpose, and I would maybe entertain doing it on an old beater fixie, but will it be priced low enough to be a viable product? I'm not going to spend $100 to perform this upgrade on a frame thats worth < $400, and I'm not going to cut an inch or two of seat stay out of one that's more than $700. So can you produce it and make money off of it selling it for $25?
Additionally, will shops actually stock it? I think you might have a problem getting it in a bike shop with them knowing they (or the customer) will have to destroy the frame to install it.
I don't mean to be negative. I think it's a good idea and I do think that there is a market for it in some areas, but I think it's extremely limited.
2. Frame warranty.
2. Frame warranty.
2. Frame warranty.
Question 2 : Obviously void and no.
Question 3 : This is not a startup by any means and we do not rely on any of this as sustainable incomes ... There are far better ways to make a buck in this world. This I made for myself to begin with but had a lot of request to make more ...
We are going to offer it to the community should they be interested but otherwise it will only for special orders and friends.
Always nice to get feedback !
Thanks
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I'd be interested to see if the technique could be used to create a breakaway travel frame.
There was someone on here recently with photos of a bike he cut up and clamped together and was touring Japan with it. Think he might have been an Aussie.
-Tim-
-Tim-
Bikes: Windsor the Hour, Cannondale Capo, Cannondale Synapse Carbon, Cannondale Super X
Quoted: 14 Post(s)
C'mon guys. Speedbird is being innovative. I give him credit. Maybe Speedbird's next brainchild will have us all wondering why no one thought of that before. Without dreamers like Speedchild, we might all be stuck riding bikes with only one gear!
Again and alway thank you to all for the comments good or bad.
Pat
Quoted: 1332 Post(s)
Liked 398 Times
Personally, I'm just not a fan of people who try to crowdsource market research for free.
The biggest problem is getting good chainline which is more critical with belt drive. With a cheaper frame, and with a destroyed seatstay, it's going to be really hard to keep the belt in line and on the front ring. And what's the cost of components? Who is going to spend 3-400 (guessing) to install on a beater that will have trouble working properly.
Think about how much the back end of a bike flexes when a commuter takes off from a set of lights in the ring gear.
