Trek 1400 with Cracked Frame
Not sure the year on this one. 18 speed. Shimano 105 Brakes, derailleurs, Shimano Ultegra shifter/brake levers. Front wheel Mavic Open 4, front tire Maxxis RC-Fuse 23mm, rear wheel Giant S-R2, rear tire Continental 25mm.
There is a crack in the frame at the top of the seat tube, see photo. Anyone know how this affects value?
Was thinking $180
See images here: imgur (dot) com/a/5cRvXCP
Located in Denver CO
Was thinking $180
Humongous crack across the side of the seat tube. Some here will say it can be welded, others will say don't bother, frame is toast. I'm in the latter category. Worth only whatever parts are on there.
Quoted: 1324 Post(s)
Liked 927 Times
Probably cost as much to fix as to buy one in good condition. IMHO, that's a parts donor bike only.
Cheers
Cheers
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 203 Times
1991 I have one; ouch!
Last new bike 1991
Last new bike 1991
Quoted: 786 Post(s)
Liked 1,706 Times
Quoted: 1629 Post(s)
Liked 814 Times
You can't sell it but you can give the frame away to a cyclist that has access to aluminum welding equipment and the skill to weld that crack close. Which would keep the otherwise good bike on the road,..........instead of being turned into soda pop cans.......
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
I had a cracked Trek Aluminum frame like this years ago, I inquired around and consensus was that it couldn't be welded reliably since the frame was heat treated.
Quoted: 1370 Post(s)
Liked 1,743 Times
how the hell did the upper seat lug get broke.
Quoted: 2350 Post(s)
Liked 1,727 Times
If the owner is the original owner, Trek might replace it on warranty.
Thanks everyone. I purchased it for $130. Since the crack doesn't affect functionality, I'll ride it around for a while until I find time to sell the components or look more into welding.
Liked 1,727 Times
Looks like the crack extends all the way to the non-drive-side seatstay. The seat tube could collapse with added stress, i.e., riding. I'll second what madpogue said. Riding in this condition is not recommended, but hey, do whatever you want, and let us know what happens.
Quoted: 4194 Post(s)
Liked 2,911 Times
Quoted: 786 Post(s)
Liked 1,706 Times
This very possible that at some point a previous owner put the seat up to high then just a little too much tightening on the seat stay bolt is a good way to break a hardened alloy frame.
