Complaint about replaceable Presta Valves
I’ve had bikes with Presta valves for at least 30 years. In the last year, two bikes (one new, one just with new tubes), started getting flats, sometimes slow, sometimes fast. I was never able to find any holes. After a few wasted tubes, I figured out I was loosening (or completely removing) the valve while opening or taking off the cap. I didn’t even know this was possible. Have Presta valves always been removable or is this a new thing? Why would I want to replace a Presta valve? Anyway, I’m loctiting them when I think about it. I’ll let you know how that goes.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Do NOT LocTite them. They're replaceable because people damage/break them or they get clogged w/ sealant. Don't overthink this, just check them every now and then. If it were that big of a problem there would be tons of people complaining about it.
Likes For cxwrench:
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,599 Times
I had a removable presta valve shoot passed my head when I went to pump up my tire. That'll jump start your morning.
Quoted: 1438 Post(s)
Liked 1,092 Times
When I worked as a car mechanic learned to turn my face away from the tire while seating or inflating it, and to keep clear when removing valve caps, after such wake-ups.
Habitual User
Quoted: 4946 Post(s)
Liked 8,087 Times
Don't tighten the top cap down so much. Just get it snug. The air pressure in the tire keeps it closed, the screw is redundancy. If you really tighten the top cap down, you're more likely to loosen the valve stem when you go to open it. Also, screw on pump heads are garbage for a similar reason.
Likes For Eric F:
Likes For trailangel:
Quoted: 194 Post(s)
Liked 204 Times
Some of the plastic caps I have had recently for my Woods/Dunlop valves have tended to undo the retainer as I have attempted to just remove the cap.
Of course I would never loctite my Woods valves in because that would prevent me from easily releasing the air, and I keep the caps on to keep the crud from blocking the valves - but if you use Presta valves and never have to remove them then why not loctite them in, but I do worry that it might not solve your problem.
Quoted: 94 Post(s)
Liked 151 Times
While some may think the plastic caps are not needed I think a bicycle that goes in for a tune up or flat repair should come out with caps as this shows the mechanic pays attention to such details. Some customers would be upset if their bike came back from service without caps.
I've had a few tubes that leaked around the replaceable presta valve and no matter how tight I made it they would still leak very slowly. So, one small dot of blue Loctite on the threads to seal it and all was good.
Liked 2,971 Times
A dab of liquid electrical tape works well too & will allow for the valve to be easily removed in the event that the tube needs to be serviced.
-Oh Hey!
-Oh Hey!
Quoted: 837 Post(s)
Liked 1,061 Times
Sr Member on Sr bikes
I’ve kind of wondered why the Presta valve core is removable to begin with (although not all Presta valve cores are removable). And of course some Schrader cores are removable too. Why? Price-wise, and the trouble...it seems like just replacing the tube would be more prudent if there is a valve problem. On a big car or truck tire...I can see that replacing the valve core would be easier than dismounting and remounting the tire. But with a bicycle tire/tube...what’s the purpose?
Dan
Dan
Quoted: 2026 Post(s)
Liked 1,096 Times
+1 I had Lezyne "Road Drive" mini-pumps on two bikes for a while. They were small, light, efficient and had a separate hose to protect the valve stem. However, they also had screw on valve heads and efficiently removed the valve core from some tubes when the head was removed. After a couple of frustrating roadside flat repair attempts I gave up on them.
Quoted: 837 Post(s)
Liked 1,061 Times
Dan
Dan
Habitual User
Liked 8,087 Times
Bikes: lots
Liked 2,932 Times
Dan
Dan
Hint: #2
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
Get some michelin airstop or aircomps.. none of that worthless threading all down the valve stem, nor removable valves.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I buy only tubes with replaceable valves so that I do not need to toss a tube because of a bad valve. The rubber in the gasket that seals the valve is actually thin and fragile and go bad before the tube goes. Unfortunately the replaceable cores in Schwalbe tubes, made in Vietnam, tended to be recently bad right out of the package - that could be an alternative explanation, instead of the unscrewed cores, for the leaking in the original post. I have better quality cores in standby as a matter of principle, just like spare tubes or bolts .
Likes For RGMN:
Quoted: 2338 Post(s)
Liked 2,822 Times
I learned to deflate the tire before removing the presta valve like most of us the hard way....in this case it shot the valve and my nice new indulgent park valve tool flying, lucky I did not take and eye out. and I had to completely clean the shop to find the tool
though the little plastic jobbies wrenches that come with sealant work, the metal park valve tools is so nice
Likes For Geepig:
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
I search for Continental tubes BECAUSE they have the replaceable Presta valves and I can inject sealant. My Michelin and Vittoria tubes do not have replaceable valves. Most of my mid-range sewups also have replaceable valves, useful to me for the same reason, to add sealant.
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 338 Post(s)
Liked 314 Times
Never try to teach a pig to sing...
