Cleaning rim braking surfaces
BEHOLD! THE MANTICORE!
I know this has been discussed in depth but I must not be searching using the right terms and Im impatient and its bugging me sooooo...what should I use to clean the brake residue off of the braking surfaces? I need to know for both steel and alloy rims.
Bikes: 07 Vanilla, 98 IRD road frame built up with 25th Ann DA, Surly cross check with 105 comp, 78 Raleigh Comp GS, 85 Centurionelli
Quoted: 87 Post(s)
Liked 923 Times
If it's REALLY funked up and the scotchbrite doesn't get the surface smooth I have used the fine grit sandpaper covered foam blocks like they sell at auto parts stores. I go very lightly with the 600 grit and remove as little material as possible. This does take some life out of the rim, so be sure the scotch brite and elbow grease won't do the trick first.
That's for alloy rims, I don't have any steel rims so no idea on those.
Ill try those, any other ideas? I dont want to take sand paper to my rims! I thought I remembered someone saying use simple green, but I always thought that stuff was bad for alloy parts
"Purgatory Central"
I still have some of that Blue Magic metal polish thats also a pretty strong cleaner with the ammonia content. I apply the stuff with #0000 steel wool and it does an excellent job of cleaning braking surfaces on rims.
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
Goo gone has worked for me in the past.
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I had some alloy rims that were really gunked up, I used some mothers aluminum polish and a old t-shirt to clean them.
I use some chrome polish or something similar and a t-shirt on my steel rims.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
Paint stripper? It breaks down everything.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
mineral spirits with the scotch brite - if it's not too bad
I have never tried this, but - how about trying that stuff you use to clean aluminum car wheels? You spray it on, let it sit for a minute or too, take it off with a rag or cleaning pad?
Quoted: 87 Post(s)
Liked 923 Times
I wouldn't sweat the sanding thing if done lightly. Every time you use your brakes with even a small amount of road grime you're doing the same thing, but much harder. Think about it. If you sand it on the bench then you're just doing it as much as needed to bring the brake track back to a good surface. I did this last year to set of very, very gunked up Weinmann concaves that are not known for wall thickness, and they cleaned up very nicely. I had tried everything from the green scrubbee and windex through a brillo pad and auto brake cleaner, nothing but the sandpaper would even touched the 30 year old brake residue. They work like brand new and with the salmon cool stops they bite like a pit bull.
Bikes: dawes, schwinn, kona
I have used acetone (nail polish remover --- get some with no scent or additives) and also lighter fluid with success to clean residue off rims. Do not ask why I had lighter fluid around...that was years ago. Just be careful to avoid getting either on your tire sidewalls.
Pete
Pete
Latvietis
Bikes: '86 Serotta Nova, '77 Schwinn SLT 12.2, '73 Fuji SSR
...that's what Mothers chrome polish is. Works like a charm for shining things up, but for me it didn't clean up braking surface. So I'm stumped.
Latvietis
Pete
Pete
Señor Member
Liked 1,090 Times
I'd try copper wool, or 300+ grit sandpaper before steel wool. If you do use it, go very lightly.
Pete
Pete
Bikes: Fuji S-12s, Trek Navigator 200, Dahon Vitesse D7, Raleigh Sprite Touring ('70's)
The solvent cotton wad product Cotton Cleanser works fairly well on rims (alloy & chrome steel).
Will normal household cleaners: Simple Green, Formula 409, Clorox, et al., break down alloy rims a lot quicker than the aforementioned cleaners? Just curious.
The "cleaners" mentioned are mostly pure solvents. The ones mentioned (acetone, alcohol, etc) evaporate and leave no residue. The "normal household cleaners" you mentioned tend to leave junk behind - beware.
