How many shoes you have?
Just a fun question? how pairs of road shoes you have? and tell us why you have that many? or tell why you have more then one.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Primary road shoes, previous road shoes, winter shoes.
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
1 pair. I rinse the insoles after a sweaty ride, and wear booties when it is cold.
Bikes: Condor,Tarmac, Trance
Started with cheap Lakes,still going strong.Afflicted with upgrade-itis so I moved on to DMT Prismas,fantastic fit,but poor quality of cover and the Boa Ratchet won't ratchet,a shame.So now I am rocking a pair of Diadora Jet Racers but am keen on a a pair of S Works to match the Tarmac.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1251 Post(s)
Liked 1,276 Times
4: Primary, previous, previous to that because it turned out the replacements weren't so hot after all, and winter.
Falls Downalot
Bikes: Now I Got Two
Quoted: 5 Post(s)
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
Primary 3-hole, Previous 2-hole touring pair the sole of which has lost its stiffness thus precipitating the purchase of current primary (and switch to Keos), and old primaries which had to be replaced because they were actually mismatched in size.
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
Primary and a back-up set that I picked up for $10 used. Also have separate shoes for MTB riding.
Roccobike BF Official Thread Terminator
Bikes: are better than yours.
Lots. Even after throwing away worn out shoes and selling non-fitting ones. I may be the Imelda Marcos of cycling. I can ride pretty much any damn saddle, but shoe fit is a PITA.
Telemachus has, indeed, sneezed.
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
2, summer and winter
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
four - newest carbon sole, previous plastic sole that the LBS had on sale 50% off, older same plastics sole, and an even older pair I keep in case the others fall apart at the same time.
Bikes: 1975 Albert Eisentraut, 1992 Bill Davidson, 2006 Moots Compact, 2007 KHS Solo-One, 2010 Van Dessel Drag Strip Courage, 2013 Alchemy Xanthus, 2016 Breadwinner Lolo, 2018 Moots VaMoots RSL, 2019 Chapter2 Tere Disc, 2020 Chapter2 Ao Limited Edition
Quoted: 31 Post(s)
Liked 32 Times
5 pairs: 3 Giro Factor (newest 2014 Factor ACC, one used for spin class), Sidi 5.5 and Bont A-One.
Why? I'm Filipino..................
Bikes: BMC SLR02
3...1 winter trainer, and 2 roads...should be one but bad advice at the LBS when i started out lead to me buying a pair that doesn't fit well
Bikes: custom caad9
2, SIDI's and Specialized Expert's which I have yet to get a good ride in on. Shoes are a pain because you don't really know how they will feel until you take them on a 25+ mile ride...climbing in my SIDI's tends to make my pinky toe sneak under my other toes (hence the Specialized shoes)...how the hell would I know that by just trying them on!!!???
Bikes: Crumpton SL Crumpton Type 5 Berk on order
2 pairs at the moment. I buy 2 pairs at a time because of my birth defect and its a pain in the butt to get lasts of my feet.
2 pairs-shimano R170s which are my comfortable and reliable go tos; Giro Empires I wear occasionally and were great in the colder weather this past winter/spring. I actually have 2 pairs of the R170s because I first bought 44s, which started feeling a little too roomy after the first couple rides so I picked up a second pair of 43.5s which seem to be better. I'll sell the other pair once I'm totally sure about sizing.
Bikes: Domane 4.3 and Trek Crockett 5 disc
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
3 pairs of sidis because they just won't die! Ergo 2's, ergo 3's, and wire. ~Who doesn't like *new* shoes every now and then?
It's good to know you have a back up for your back up shoes anyhow.
Provided you don't crash, higher end models that have many replaceable parts can be repaired as things break or start to wear out.
For the record, I have had my cobbler replace the velcro on my ergo 2's & 3's. It's possible with a competent shop! They even reuse the original stitching pattern so it's good as new.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
Primary and a previous pair.
I only use the previous pair if the primary is wet from a rain ride.
Quoted: 696 Post(s)
Liked 910 Times
1 SPD-SL giro carbon sole road shoes
1 SPD touring shoes
1 SPD mountain bike shoes
1 SPD touring shoes
Bikes: 2012 Cannondale Flash Alloy 2 (mountain bike), 2010 Schwinn Paramount Series 7 (road bike)
None. Sneakers and toe-clips for me!
Quoted: 686 Post(s)
Liked 5 Times
Blue Giro Empires for everyday.
Blue Shimano R320 for the nice rides
Black Shimano something or other (for sale!)
Camo Giro Empires (for spd pedals, use them on the fixed gear)
and then a pair of five tens for the mtb/platform pedals.
