2015 Post Your Singlespeed/Fixed Gear Megathread
#1726
Bikes: Windsor The Hour Plus, 2014 Novara Verita, Windsor Oxford
New wheelset and tires for the commuter. I think I'll be a bit more visible at night
#1728
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
I'm still figuring out what the ideal pads will be so that I can remove the wheels with the tires inflated when the cables are released (it is possible), and need to install the CB90 cable releases when they arrive, but you get the idea
#1731
Quoted: 481 Post(s)
Liked 131 Times
It is. I love this bike.
Thanks! It does not, at least not without taking a Dremel with a cut-off wheel to the caliper (which I've considered), but I've opted for this more expensive and elegant solution.
Tires are Maxxis Raze 33's.
#1732
Quoted: 8 Post(s)
I did some upgrades so I'm re-posting.(cranks, pedals, stem, bars)
#1733
Bikes: KHS Flite 100 Road Track Fissie Biek
Quoted: 8 Post(s)
Bikes: 1995 Specialized Stumpjumper M2 / 2013 Caloi Carbon Elite 29er / 2015 Cannondale CAADX 105 / 2017 Specialized Roubaix Elite
Quoted: 39 Post(s)
The bike looks smoking hot, but that fork, paraphrasing my 8yo, looks "I-dunno"...
From what I understood, it's not stock?
#1736
Quoted: 8 Post(s)
Quoted: 8 Post(s)
Aventon Ultimate 1.0 fork | Retrogression
#1739
Quoted: 39 Post(s)
That fork looks awesome!
#1740
Probably going to go with this one as it will match well and the rake is the same. RG is out of them but I may have found another elsewhere...
This would be a good option
#1741
Quoted: 8 Post(s)
A Celeste fork would a nice option too, and you could get away with gloss
Maybe I'll post in the "should I" thread.
#1743
Bikes: Civilian Le Roi Le Veut, Kazane Track, Ciocc Designer '84, Serotta Colorado AL 25th anniversary, '85 Guerciotti Pista, '84 Trek 660, Volume Credence
Thanks. The thomson post has been cut down to a nub and the ISP is sleeved at the junction for strength. Its also relatively thick tubing to prevent any issues. Its been rolling as a work bike for years as well so I am pretty confident in it. It makes the ride super smooth sturdy feeling.
#1748
Quoted: 8 Post(s)
Amazing looking bike, man.
#1749
Redline Monocog Build
Just finished rebuilding my old Redline monocog. New powdercoat/decals on the frame and all new parts except crankset, stem, and wheelset.
Build Specs:
Frame: Fresh powdercoated 17" Redline Monocog (2008 i believe)
Fork: Stock
Graphics: 1980 Redline Proline
Bottom Bracket: New Shimano UN-55
Headset: New FSA The Pig
Crankset: Redline SS (hand polished)
Stem: Redline 80mm (hand polished)
Bars: Ritchey Riser Comp
Grips: New Targus Rubber/Leather
Brakes: Avid Juicy Seven (Freshly Bled)
Seatpost: New Kallot 400mm
Seatpost clamp: New Salsa chrome
Cog: New 16t Shimano
Chainring: New FSA 34t
Wheelset: Stock Alex DH19/Redline Hubs (serviced and trued)
Tires: New CST Camber 29x2.00
Tubes: New Qtubes 29x2.00
Chain: New KMC X9
Saddle: New Freedom Econoline
Pedals: New Stolen Alloy
Build Specs:
Fork: Stock
Chain: New KMC X9
