My new bicycle pulls to left and right
Hello,
I'm a complete newbie, with only one other gravel bike as a frame of reference, so I don't even know how to accurately describe what I'm experiencing with my new gravel bike (Moots Routt RSL) that I received couple days ago.
While riding, when the handle bar is in center position, the bike is very stable and it just glides; however, if I turn handlebar to the left or right just a few degrees, I feel a slight pull in that direction. The pull isn't strong enough for me to lose control, but it is strong enough for it to be noticeable. Since I don't experience this with my older gravel bike, I'm trying to understand if this is normal? If I pick up the bike and turn the handlebar in either direction, it feels very smooth with no resistance whatsoever. So I'm guessing it's got something to do with the geometry?
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Is the fork turned 180 degrees (so it’s backwards) ?
Barry
Barry
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Captain Obvious reporting in.
But not “insulting” to a self proclaimed newbie.
it had to be asked given the description.
Barry
Barry
Likes For Barry2:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
you have purchased a rather short, fast handling Race Bike. Moots makes another model, the "45"... it might be a better choice for you. To put it in another frame.. You wanted a new Corvette and bought a supercharged Shelby Cobra.
Have you checked the steering head adjustment? if the bearings are a bit tight, the bike will tend to tuck into a corner and want to stay tucked in...
PS.. there are friendlier, better handling, Gravel bikes out there that cost far less.. like, about 1/2 what you paid.... just a heads-up.
oh, and two reviews say that they wanted a lower gearing... i'd drop two on the big ring and three on the small ring.... just my opinions.
check those head bearings first... and try sliding the seat back a touch too.....
As far as I can tell, the fork looks right. I'll post a photo once I can.
I've only had it for couple days, but I've already found several issues with it.
P.S.
Yes, I've put plenty of air in the tires (about 65 PSI to be exact).
- The front brake was making noise, and today I noticed, by accident, that the screw and the safety pin was missing. That could have been dangerous.
- the valve stem caps are missing as well.
- the chains was slipping and rubbing against the sprocket. It took me couple hours to learn and make all the adjustments. I think it's still not 100%.
P.S.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
If you read the thread, that’s already been mentioned.
SO WHAT, I ASKED.
I wasn’t mean, nasty, or pointy fingered.
Just trying to help, given there was no photo.
Never even seen or heard of this brand.
GET OVER IT
Barry
Quoted: 514 Post(s)
Liked 451 Times
Seriously, I'd have to ride and examine the bike personally. Have an experienced rider/mechanic have a look.
I actually don't know how I'm supposed to "check those head bearing". As I mentioned, If I pick up the bike and turn the handlebar in either direction, it feels very smooth with no resistance or any kind of pull whatsoever.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Likes For Eric F:
Liked 739 Times
I did consider the Routt 45, but I wanted a gravel bike that was "quicker" and little more suitable for the road, and I think that's the RSL. I do have another gravel bike, Fairlight Faran with 50mm tires, that costs far less, but it's HEAVY compared to the Moots.
I wasn't insulted, not one bit. And yes, I'm a complete newbie; i did my very first rear derailleur adjustment today, and I rather not have to do it again .
Yes probably, but then why does it not happen with my other gravel bike (i.e., the Faran)? The angles of the fork and all are very similar between the two bikes, so I'm trying to understands what's causing it exactly.
Ok.. then it might be a fit issue.. if you're too far forward, the bike falls harder into a corner... i'd suggest you locate a shop capable of setting up a correct fit.. search BikeForums to see what comes back regarding fit to improve handling, and there are any number of Vids online..Owner reviews that aren't just flowery sales pitches might be helpful too... one mentioned a shorter steering stem.The gearing may be fine for Predominately road work.. Not sure what terrain you ride.
Habitual User
Liked 8,099 Times
If you bought the Moots from a bike shop, take it back and have them address any quality/assembly concerns (missing valve caps is not a concern).
Quoted: 427 Post(s)
Liked 700 Times
Except at very low speed, a bike is "steered" by leaning, not by using the handlebar to "steer". Your fork is not backwards. It is possible that what you are experiencing on one bike and not the other could be due to differences in the geometry between the two, if it is happening at lower speeds. Seems like you aren't confident in the prep by the mechanic. If for nothing but peace of mind, you might want to have a different shop with a reputable mechanic go over the bike.
Likes For freeranger:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Quoted: 569 Post(s)
Liked 588 Times
^^^ I could not agree more, new to cycling with many 1,000 invested to enjoy that bike and need a mechanic you can trust now and in the future.
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
the front wheel thru-axle is tightened properly?
Likes For alcjphil:
Oh crap, Max 75psi is for Tubed, and for Tubeless the max psi is 60. I have tubeless, so I brought it down to about 50pis, thanks! The tires are Panaracer GravelKing Slick 700 x 38.
