PSA, Inflate tire to 80% psi
#76
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 461 Times
The low-tire-pressure minions never like to miss an opportunity to push their agenda.
I may not inflate my road tires to 140psi like SMD4, but no way will I bring mine down to 60-80psi.
Seen more than a few fellow group ride cyclists suffer punctures or, worse, destroy a rim.
Some of my roads get slightly rough, but I estimate that happens less than 3% of an entire 40-miler.
Thank you, but my 25 or 28 tire widths and 105psi suit me just fine.
#77
Quoted: 4409 Post(s)
Liked 1,566 Times
I just don't understand why you want to make your 28c tires ride worse than your 25s. Wouldn't you want them to be close to the same?
#78
Quoted: 3513 Post(s)
Liked 2,927 Times
#79
Liked 2,927 Times
#80
Quoted: 5224 Post(s)
Liked 3,585 Times
#81
This article explains it pretty well
https://silca.cc/blogs/silca/part-4b...-and-impedance
In short: the drum doesn't simulate the rider and so the drum will keep showing lower rolling resistance at higher pressures even with an uneven drum surface.
#82
Liked 2,927 Times
40??!! On tires with a 100 psi MINIMUM, that would feel like crap, and likely lead to instant pinch flats front and rear. We'll put that suggestion in the round file.
Likes For smd4:
#83
Thanks for the lead.
#84
Thread derailleur
Quoted: 367 Post(s)
Liked 461 Times
So far I haven't seen anyone recommend "low" pressures. 118psi for 19c tires is not low. 60psi in a 28c tire isn't low if you weigh 100lbs either.
#85
Liked 1,566 Times
Riding 25s and 28s at the same pressure is like riding 25s at 105 and 120psi on two different bikes. That's all I was getting at.
#87
Quoted: 980 Post(s)
Liked 582 Times
I've experimented with tire sizes and tire pressures over the last 20 years. I started out (on the AIrborne) with 700-23 tires at 115 psi. These were OK on a titanium frame with a steel fork. I went to 32s after a few years and ran these at 100 (rear) and 90 (front) at first. Over the last few years I've been persuaded to the "lower-pressure" side, and now find that 80 (rear) and 70 (front) works well* for me. I weigh about 215, am pushing 73 and usually average 13-15 MPH. I have a standard 35-mile loop I've been riding for years. The lower tire pressure doesn't seem to slow me down, and I do notice a more supple ride.
It seems to me that tire pressure is a personal choice unless one is a professional racer with serious competitive goals. Live and let live!
(* According to the Silca tire pressure calculator, these are still a bit too high!)
#88
Quoted: 1088 Post(s)
Liked 1,026 Times
If you're running your tires at 140psi, the only place they're not going to be slow, is at a parquet velodrome. The tires at 140psi are likely slower than if they were pumped to 60psi. And that's on a brand spanking new baby bottom smooth tarmac. If the road surface gets any rougher, well, you'd probably be better off at 40psi. Of course that's all conjecture as only you know how much your bike + rider combination weighs, what's the weight distribution etc.
All that being said, you'd likely be much faster below 100psi. But as you prefer to be slow, I'm sure that doesn't matter to you.
#89
Really Old Senior Member
I think when one gets into their 70's, you "turn the wick down" a bit so you're not so "stressed" at the end of the ride.
Since we are no longer trying to complete the circuit in the least time, we also soften the tires a bit and maybe give up another minute or 2 for the comfort aspect.
Less racy and more smell the roses.
Likes For Bill Kapaun:
#90
Boy, you weren't kidding! It took me 10 minutes to roll out of the 25-foot driveway today, and that's down hill and with a tail wind! The bike rode so slow that I lapped myself!
Go read on low pressure some more. He's discussed 18c-23c tires at 140psi, run those at 40psi and you'll be walking, especially the 18c. When I ran 18c tires I kept them at 130psi and at 225lbs was pinch flatting those, its why I stopped running them and went to 20c at the time. But, unless you're running a wide internal width rim, like 19-20mm I wouldn't run a 23c tire below 60psi, really I still wouldn't run it below 90psi, but with the wider rim you won't pinch flat as much. 40psi is looking to pinch flat and break something. Even my kids at 100lbs run 80psi in their 23c tires.
All that out of the way, as was stated in the link I posted earlier (here it is again https://silca.cc/blogs/silca/part-4b...-and-impedance ) it all boils down to the break point. A tire will get faster with increasing pressure up until the tire gets too hard to conform to the surface and starts bouncing instead. That moment the tire starts bouncing is called the break point and after that point the tire will start get slower rapidly because all that bouncing is the transmitted through the bike to the rider. All that bouncing is then transmitted to the tissues of the rider which is dissipated as heat and is thus wasted energy.
If you can't get around the word bouncing, call it vibration instead.
If we look at the most important chart of the earlier mentioned article
We notice that with a 25mm Continental GP4000S the break point for smooth asphalt is at 110psi after which the tire will start getting slower rapidly. At 140psi on new asphalt the rolling resistance is as high as it would be when the tire was inflated to under 60psi.
On coarse asphalt the break point is at 100psi and at 140psi the tire will be slower than if you ran the tire under 50psi.
On machine roughened concrete there's just no point in going above 90 psi and you'd just be better off riding something a lot wider. That red graph is actually really interesting, because it does kinda show that a 25mm tire can never get fast on rough surfaces.
Since we're discussing 23mm tires you can use higher pressures than with 25mm tires on smooth roads. However the narrower tires are going to perform still worse on rough surfaces. Your casing losses never get a chance to get low when you already reach the break point and impendance losses set in.
The data seems to show that the only reasons one should use narrow tires in terms of speed is because of aerodynamics and weight.
However to fullfill the 105 % rule with aerodynamic rims one can get rims that are in the region of 32mm wide, allowing the use of 28mm tires.
If it's lower weight one is after, well that only helps on the uphills where rolling resistance is less important anyway.
In order to reduce the risk of pinch flats one should, according to the data, use wider tires. If the bike in question can't take wider tires, well that's a bummer.
Likes For elcruxio:
#91
Liked 2,927 Times
A bummer? Um...no. If I want wider tires, I'll buy a hybrid.
#92
Liked 1,566 Times
A narrow tire is going to have the same breakpoint and performance curve because it is doing the same thing as the larger tire. So for standard roads there isn't necessarily a loss - the best 23c tires have the lowest rolling resistance. But you may get to impedance sooner on large chipseal with a narrow tire.
#93
Quoted: 6972 Post(s)
Liked 10,968 Times
Enjoying the way a bike feels is as good a reason as any to choose a pressure. We don't all need optimal speed, grip, tire life or whatever factors the mavens consider when coming up with charts. It's smart to start with the expert advice, then run with the subjective as far as you like.
#94
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
if less is good, even less must be better, right ? I've been riding 20 PSI, now I want to get down to 5 PSI so I can be cool like the big boys
/markp
Likes For mpetry912:
#95
Liked 2,927 Times
Likes For smd4:
#96
BS. Quite simply. What does that mean..."slower?" If I'm riding at a certain speed, what am I slower than?
What does this even mean? "Get fast?" When I'm riding, my cadence is at a certain level, I'm in certain gear combinations, and I'm going the speed I like. So you're telling me that it's just an illusionthat I'm rolling along at a certain speed? I'm just imagining the breeze in my face? But really I'm barely above walking speed? It's a wonder I can even keep the bike upright! Unless you're racing, this is just a whole lot of hogwash and word salad.
You are provided with articles and charts which explain hysteresis and impendance and which even a ten year old could easily understand. However you act stupid and fall back on semantics and make a big stink about a single word you choose to use the incorrect meaning for. Classic SMD4
Anyways, what the charts and articles clearly state is that the coefficient of rolling resistance is higher for a 25mm tire that's pumped to 140psi than it would be for the same tire that's pumped to 60psi.
That means that you need to use more energy to achieve the same speed with the 140psi tire than with the 60psi tire. Mind you, both have terribly high coefficients of rolling resistance but the 140psi tire has it higher, ie. is slower.
Likes For elcruxio:
#97
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
#98
Liked 2,927 Times
Hey I know this one!
Likes For smd4:
#99
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Finally, pinch flats are a symptom, not a problem. If your bike can accommodate wide tires…and even it if can’t…a pinch flat tells you that you have too little air in the tire for the conditions. A pinch flat should tell a rider that they are about to incur an expensive repair because their rim is bottoming out and is at risk of being bent. A pinch flat is a low cost repair and a warning. A bent rim is an expensive repair caused by an ignored warning.
Stuart Black
Stuart Black
Likes For cyccommute:
#100
Liked 2,927 Times
^^What he said!
