digital caliper recommendations
#51
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
I got my Mitutoyo vernier caliper while on patrol in the city of Fallujah, Iraq two days after we began "the Push", and the day after my unit entered the city behind the Marines. I had just taken this photo of the most surreal scene I could think of.
The caliper was sitting on the ground, amidst a bunch of other metal junk, just outside the wall of Jolan Park. I picked it up, looked to see if it was straight, stuck them in my camera bag (I was a combat photographer with the Seabees) and went back to work.
Likes For PhilFo:
#52
Bikes: nothing to brag about
Quoted: 130 Post(s)
Liked 206 Times
I use calipers daily at work. Be warned that if you buy a cheap electronic caliper you might be replacing the battery every time you use it. I was getting about 30 days per battery on a $15 electronic caliper, which means a lot of people will be putting in a new one every time they take it out. Before that I had a Mitotoyo and the battery lasted forever, but it wasn't cheap and the plastic face got messed up just as easily as a cheap one (maybe they use gorilla glass now?--they should). I went back to a Mitotoyo plain vernier, though a GOOD dial caliper is always a temptation.
For brakes, the mentioned C-frame micrometer is probably the best tool. https://www.amazon.com/General-Tools.../dp/B00004T7UD
#53
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 122 Times
#54
Quoted: 1279 Post(s)
Liked 1,393 Times
so this definitely seems like the right tool for the job - very easy to position the point of measurement on any one section or the perforated / patterned rotor. also about $30 delivered.
assuming the thing isn’t total junk (doesn’t seem to be, although i have nothing of absolutely definitive thickness other than some valve feeler gauges) my rear rotor has a lot of variance, with many “spokes” at 1.60-1.65 but then a few at 1.48-1.51. can’t really imagine why that would be on a spinning disc, I guess wear subsequent to mild warping would thin out spots?
braking performance is still excellent, smooth, quiet, powerful, so I’m not going to replace them until the majority of the surface is at 1.50.
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 57 Times
I have an old Swiss-made vernier scale caliper that was a hand-me-down from my dad that I have no idea where it came from. I also have a cheap $10 digital caliper from China that I believe came from Lidl. Between the two of them I should have the accuracy and convenience sides covered.
#56
Advocatus Diaboli
Quoted: 4738 Post(s)
Liked 1,533 Times
https://www.amazon.com/Neoteck-Digit.../dp/B07D1JCPWM
#57
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
somebody sent me this measurement one time. What's wrong with this picture?
/markp
/markp
#60
Quoted: 6196 Post(s)
Liked 4,811 Times
#61
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
had prolly been used as a crescent wrench previously
/markp
/markp
#62
Liked 1,393 Times
any thoughts on whether a .1mm variation in thickness across the rotor (at the same distance from edge) is particularly unusual?
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
the swept area of the rotor probably has a shoulder at the periphery of the wear area
so, hard to say
/markp
#64
Liked 1,393 Times
these are the rotors (when they were newer)
#65
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
so is there any pulsing or odd behavior under braking ? or noted in lever pressure ?
if your measurements are correct there should be !
if not I would not worry
/markp
/markp
#66
Liked 1,393 Times
maybe i’ll make a little video measuring, i suppose it’s possible i’m doing something wrong.
Liked 1,393 Times
i think i can say that when used properly the tool is accurate. tried a few different feeler gauges and all within .001
the range on one quarter of the rotor seems to be about 1.42 to 1.57. i guess i do in fact need a new rotor. distressingly short life - 2400 miles!! the .15mm variance doesn’t seem to affect the actual braking.
boring video - which does illustrate how much the measurement varies if the 1/8” diameter (approx) flat head of the micrometer isn’t completely true and flush on both sides. the tool has a very soft clutch, so cranking it with the dial doesn’t exert enough force to square it up.
https://imgur.com/a/X2KJHNk
#68
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
The other name brand calipers all have similar battery life to the Mitutoyos. The cheap imports use cheaper batteries when new, and have substantially higher power consumption when turned off. There’s a write up online somewhere about what’s different in the circuit of the imports that makes it cheaper to produce but uses more power. The result is way shorter battery life. That’s actually the easiest way I’ve found to separate real digital Mitutoyo calipers from the massive number of fakes for sale.
Likes For jccaclimber:
#70
Quoted: 1109 Post(s)
Liked 1,200 Times
I just bought a couple of cheap ones at IIRC, Home Depot or Lowes, maybe eBay. Before that I had a Verneer, and an analog dial type. I think the dial type would work fine, if it were in mm, but it's in inches.
Both of my very cheap ones (I'm thinking <$25) work fine. I really wish the dial type was in mm because I think it's cool.
I also have a micrometer I inherited from my grandpa in the 80s, probably from the 40s or so. I have used it and enjoy every time I do. But never on a bike so far. I might use it when I measure my disc rotors to get past the edge and compare to what I get from the digital caliper.
Too bad. I've had my cheapos for many years and never changed a battery.
#71
Quoted: 69 Post(s)
Liked 122 Times
This is true.
#72
Tinker-er
Quoted: 165 Post(s)
Liked 267 Times
Anyway, the simple vernier calipers survived heavy urban combat, the trip home in 2005, and very frequent use ever since.
#73
Quoted: 69 Post(s)
Liked 122 Times
Naa, it was in a heap which used to be an old handyman’s repair shop, from what I gathered. Not every shiny is booby trapped; they had other less savory tactics. There was a LOT of UXO there, which is one of the things we were taking care of. I have a photo somewhere of an uncapped RPG HEAT round not too far from my foot.
#74
Liked 1,393 Times
i replaced that rotor, and just for kicks weighed it compared to the new one. perhaps the weight isn't precise enough, or there is a few grams of variation in new rotors, but theoretically, on average, it should only be .14mm thinner than new, but was reading more like .25 with all available methods of measuring thickness!
I would go with a mechanical micrometer, preferably Mitutoyo or Starrett. One thing to know is that with digital calipers, even the good ones, the tolerance of those "could" exceed the variance on disc rotor thickness. That results in variable readings. With analog (mechanical) calipers you can typically get a closer reading because you can read in-between hashes.
The other thing to know is that the slight variance in the flatness of the rotor "may" give weird readings with a caliper versus a micrometer because the caliper reads across a long distance.
I'm not a machinist but I have another hobby that requires absolute precision with measurements (or bad things can happen) and there are two camps in that hobby as well: mechanical versus digital, for the reasons I stated above. The cool thing about digital, and I own two actually, is the quickness of the reading and the no "interpretation" of incremental (in-between) measurements on a mechanical tool make a digital much easier to use for the average joe. That's one of the reasons digitals are so popular. My wife uses my digital tools for her hobby and loves them.
If all you're going to do is measure bike rotors or other bike parts, a digital micrometer may be your best choice. If you plan to use it on other precision measuring, a mechanical micrometer would be the better choice, in my opinion.
