Chain doesn't wrap around lower pulley when it's on the lowest gear on the
Bikes: Gunnar Sports, Mikkelsen, Paul Taylor, Soma Smoothie, Bianchi Vigorelli, Lemond Sarthe, Surly Bridge Club, Marin Muirwoods 29er, Jamis Dragon Sports, Cannondale Quick, Dahon Helios, Giant Yukon, Custom Triban RC520 with Shimano Alfine 8 Groupset
Quoted: 7 Post(s)
For some reason, when I am on the biggest chainring and cog, the chain doesn't wrap around the lower pully/jockey wheel. It's shifting fine on all chainring/cog combination except for big-big. I've tried:
1. Cleaned/lubed chain and cassette
2. Replaced the upper and lower pulley's on my derailleur
3. Aligned derailleur hanger
4. reverse the direction of the chain (I have 10 speed sram pc 1071)
It seemed like I don't have this problem when I pedaled backward. I made a short showing the problem: www.youtube.com/shorts/C2DgANS34nY
Thanks for helping.
Thanks for helping.
Quoted: 3514 Post(s)
Liked 2,927 Times
Don't cross-chain your bike. There's simply no reason to be in the easiest gear in back, and the hardest gear in front.
Likes For smd4:
Quoted: 6196 Post(s)
Liked 4,811 Times
How long has it been doing this and what happened or what did you change just before it started?
Maybe the cage holding the jockey and pully wheels is slightly bent in toward the wheel or twisted from some prior hit it took.
And does it do this while you are on the bike riding it? I've seen things happen with the chain while the bike is in the stand with no force on the wheel that I haven't seen when riding and it weight on the wheel.
Even if you don't x-chain, you still want it to work correctly. So thumb your nose at the anti-X chainers!
Nothing wrong with cross chaining for a moment or two when you need to get past the sudden but brief increase in grade.
Liked 2,927 Times
Liked 4,811 Times
X-chaining isn't going to do anything but cause a few less miles on the chain.
Likes For Iride01:
Liked 4,811 Times
Liked 2,927 Times
Liked 4,811 Times
Liked 2,927 Times
Liked 4,811 Times
Liked 2,927 Times
So..."Don't do the thing you're not supposed to be doing in the first place that's causing the problem" isn't a valid solution? Even the OP says it only happens in this particular gear combination. How can it not be a permanent solution, then?
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I cross chain all the time no issues 34-50. It does not hurt the drive train and much easier than dropping to the small ring if you can manage to only need one more cog for a bit.
Likes For deacon mark:
Quoted: 7 Post(s)
I’ll try not to x-chain especially when this is happening. I don’t have this problem before with other bikes so I really want to know why.
I noticed the sound coming from the back the first time when I biked ~40 miles on mostly flat so don’t think I used biggest chainring and cog, at least not for a long period of time. I did dropped the chain once during the ride when shift from big to small chainring… not sure if it affected the rear derailleur. Don’t recall changing any parts prior to this problem.
Again thanks for helping… always learning from you guys.
Liked 4,811 Times
Perhaps your low limit needs to be brought in and it's just the angle of the chain on the pulley wheel. But if it wasn't doing this before, then why would the low limit have changed. And certainly if moving the low limit in causes issues getting into the big rear cog then between poor shifting and the noise, I'd take the noise.
Might need to get a bike shop to look at it. Maybe the pulley wheel is worn out.
Nothing wrong with x-chaining for a short time. Shimano doesn't say to not x-chain. They do have a caution not to do so for long periods. And there were some groupsets long ago in the Shimano line that they advised strongly not to run in the small/small combo. If your stuff is SRAM, then I don't know what they say about it.
Liked 2,927 Times
Shimano doesn't say that you shouldn't ride with your seat on backwards, either.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
I'm not sure what issue you think is happening. Of course the chain won't wrap around the lower pulley the same way as it does in other gears because the derailleur cage is extended almost to it's maximum limit. The chain will run in straight lines from tangent point to tangent point between pulleys, cogs, and chainrings. That's exactly what's happening here.
The additional noise is because your chainline is at it's most extreme angle, and it's not happy about it. It also looks like the upper pulley may be a little too close to the cog, which will also add some noise. An adjustment of the B-tension might help a little.
Likes For Eric F:
Quoted: 7 Post(s)
I agree, but the chain is sitting between the gap touching the side of the cage and the lower pulley (not on the pulley) instead of running at an angle on the lower pulley. I will create another video when I have a chance.
Habitual User
Liked 8,099 Times
I don't know. It's not my bike. I just watched the video posted by the OP.
Quoted: 7 Post(s)
Supposed to be the right/genuine replacement to replace 10 speed SRAM Rival. Double check... upper/lower and rotation are correct.
Habitual User
Liked 8,099 Times
The extreme lateral chainline angle of being big-big is the likely issue. The simple solution here is to try to avoid cross-chaining when you ride.
Likes For Eric F:
Liked 2,927 Times
Habitual User
Liked 8,099 Times
Liked 2,927 Times
