How do I remove the freewheel from a 1973 Schwinn Collegiate wheel?
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
i wanted to save a nearly pristine normandy hub.. the spokes were shot and the rim was more rust than steel.
https://www.eastwood.com/eastwood-1-...ce=google&wv=4
hey,,, you asked.
mine's a Mac tool model...
you don't know how to open links, huh?... ok then.
i don't post pics, just links... personal choice.
Quoted: 1083 Post(s)
Liked 687 Times
I'm sorry, I'm just not understanding why, if you're replacing the entire wheelset, you are even bothering with that rusty old freewheel.
That has nothing to do with whether the wheel is centered in the frame, at all. The rear wheel should sit centered between the dropouts either with or without any freewheel installed. In fact, you should take the one off the donor wheel and see how the wheel fits in the Collegiate then. It sounds like something's off.
What is the rear spacing? Is it 120mm? Unless the frame is bent, any properly dished 120mm wheel, with just about any 5 speed freewheel should fit. That old freewheel should be recycled along with the wheels, and zero dollars should be spent removing it.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
FWIW, I've successfully used the FR-4 to remove those freewheels many times, most recently, just yesterday.
Liked 739 Times
FWIW.. is it a "hammer time!" fit or loose fit?
and i'd still advise that the OP gets the correct tool, since he doesn't have one at all right now... or that he/she goes to a local shop, and has them cuss and sweat that french freewheel, with 50 years of gunk holding it in place, loose.... OR recenter the new wheel with aluminum rim and 6 speeds to fit the frame that will most likely need coldset to 126mm or greater anyway.
Likes For maddog34:
Time Traveler
Bikes: 1983 Ross Paragon
Quoted: 204 Post(s)
Liked 98 Times
well let's see... last time i removed one of those was 7 or 8 years ago... and i used this with an arbor and a cutoff wheel attached to it.
hey,,, you asked.
hey,,, you asked.
Time Traveler
Quoted: 204 Post(s)
Liked 98 Times
i guess i prefer to use the correct tool.... and avoid trying to recenter a wheel by merely swapping freewheels....
Time Traveler
Quoted: 204 Post(s)
Liked 98 Times
I have an FR-4 in front of me right now.. it WILL NOT WORK on your Rusty French freewheel... not the SQUARE Spline profile of the FR-4.. and then note the PYRAMID profiles of the spline notches in your French Freewheel. They are Very different.
Why are you wanting to remove that old thing anyway? That entire wheel is a great candidate to be made into part of a Hyundai Fender, or a toaster oven, IMO.
VeloBase.com - Component: Atom (5 speed, silver cogs)
Old fart
Liked 3,401 Times
It fits properly.
That's the same freewheel, sans the Schwinn branding.
what do you think of this?
Liked 739 Times
and FWIW.. John is advising you to use square splines in Triangle holes... and those triangle holes are in a rusted-in-place freewheel on a 50 year old hub, so that you can try to do what won't work.
Good luck.
Quoted: 3514 Post(s)
Liked 2,927 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likes For dedhed:
Time Traveler
Quoted: 204 Post(s)
Liked 98 Times
yes Im trying to determine what the right tool is. I have two high ranking members telling me the FR-4 is the right tool and another member telling me it is the $40 tool. and one member telling me they both are right. Then I have another member telling me the right tool is a die grinder. So, im getting there.
Liked 2,927 Times
Likes For smd4:
Time Traveler
Quoted: 204 Post(s)
Liked 98 Times
I did not get a good photo of the tool from above but yes I noticed that the FR-4 is not sharply triangular from what I can see in the stock photo. In the stock photo from the side it does look somewhat square. Thats why I asked John to send me a photo of the tool he used and had success with and said it fits properly. If John is saying that the FR4 with square teeth fits the sharply triangular splines properly and has just yesterday used said tool to remove said freewheel, I must pause to contemplate this seeming discrepancy.
I also watched a park tool video where they use the FR-4 tool on the triangular shaped splines on an old freewheel. I also saw a youtube video of a guy using the FR-4 on an old schwinn 20 spline freewheel and it came right off. So maybe park made the FR-4 to be somewhat universal for the 20 spline variety. I dont know.
So yes I see your point empirically and you are demonstrably correct geometrically however anecdotally men are reporting success with the FR-4 on ancient schwinn 20 spline sharply triangular shaped freewheel splines. Considering the cost difference and reports of success, i am inclined to try the $8 park tool despite the obvious visual incompatibility in geometry.
Likes For BikePower:
Time Traveler
Quoted: 204 Post(s)
Liked 98 Times
Liked 2,927 Times
Likes For smd4:
Liked 687 Times
He says it's to put it on a different wheel - one that he already said doesn't fit the bike. He mistakenly believes this old freewheel will magically re-dish the new wheel to fit the Collegiate. It's kind of funny to see the debate over which tool to use, for a project that isn't going to work anyway. People should be advising him to start with a properly fitting wheel, and then worry about whether to use a rusty old freewheel or just buy a new one.
Time Traveler
Quoted: 204 Post(s)
Liked 98 Times
Liked 687 Times
Observe that most people here are telling you that freewheel is toast and should be thrown away, so you should have learned that also.
Likes For Jeff Neese:
Liked 2,927 Times
There was no need for this thread to get to two pages. Removing freewheels isn't rocket science, and yet you are making it into one of the most difficult bike repairs imaginable. Why?
What more information do you need to remove the freewheel?
Old fart
Liked 3,401 Times
Likes For JohnDThompson:
Old fart
Liked 3,401 Times
FWIW, here's Sutherland's freewheel tool compatibility chart:
