Centering Campagnolo Record brakes
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 642 Times
I have a few sets of these and I find one thing irritating. They included narrow wrench flats (13mm?) on the base of the center bolt, so that implies you can hold the brake centered while tightening it down. Fine on the back (as I have some offset cone wrenches) but, in the front, how do you get at it? From above, invariably the headset is in the way and, below, the wheel. I was trying to visualize some convolutedly-bent wrench to get in there but . Alternatively, I imagine some gauge to attach to the fork blades to act as an indicator of where "centered" is while the wheel is out. Or is there something I am missing?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 2326 Post(s)
Liked 5,012 Times
I can normally get one of my thin hub wrenches in there from up top to hold it. The thin wrenches I use on the cones of the hubs.
Steel is real...and comfy.
Quoted: 1106 Post(s)
Liked 1,328 Times
Method a: Park brake spanner; flats are at 90 degrees to the length of the stamping.
Method b: loosen fixing bolt, squeeze brake HARD, tighten fixing nut enough to hold that position but not so much that the inner arm moves; release the brake and hold inner arm so it does not move while you fully tighten the nut.
Likes For oneclick:
Bikes: A few
Quoted: 289 Post(s)
Liked 198 Times
This might help for centering once the brakes are installed:
Dave Moulton's Blog - Dave Moulton's Bike Blog - Centering side-pull brakes
Quoted: 1079 Post(s)
Liked 1,900 Times
You can throw a couple of spacers between the fork crown and caliper to get access to the flats as long as you have enough thread to engage the nut.
Quoted: 3464 Post(s)
Liked 2,831 Times
‘it is a bit of extra effort to center the brake, I am assuming you are using the Campagnolo “star” washer, I forget the original Italian name, rotoden…
a gauge could be devised, I just did not wish to spend the time to design and fabricate one, might start with a unloved front hub.
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
Velo-Retro: Campagnolo Timeline
/markp
Likes For mpetry912:
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
Quoted: 192 Post(s)
Liked 566 Times
The front brake should *usually* have two rondella dentatas. That usually gives enough space to fit in a cone wrench, admittedly at a bit of an angle….which is fine. You should loosen the bolt when centering so that the teeth from the washers…er…um…rondellas don’t chew up themselves and the mounting surface as the whole assembly is moved in centering. Hold the wrench and tighten the mounting bolt. It’s not unusual for the washers to wear and everything will benefit from replacement at that point.
Likes For El Chaba:
If this is really a problem, try accessing the wrench flats from below. The front wheel comes off so easily.
Last time I did it, I lined it up loose and held it in place while tightening the bolt.
Quoted: 1304 Post(s)
Liked 1,913 Times
I have used this wrench for 30+ years to center the brakes. You may need to deflate the tires but the post can be accessed from the bottom when you deflate.
Offset brake wrench from Park inexpensive and the part is OBW-1. You can also remove some of the material from the wrench, so that it just fits into the post flats from the bottom with the tire still inflated.
HTH, Smiles, MH
HTH, Smiles, MH
Likes For Mad Honk:
Liked 2,831 Times
HTH, Smiles, MH
HTH, Smiles, MH
Liked 2,831 Times
Likes For repechage:
Liked 2,831 Times
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 280 Post(s)
Liked 956 Times
Likes For SwimmerMike:
Super Moderator
Liked 929 Times
Yeah, but they're still just bike parts. The concave recess in the punch prevented marring the spring.
Quoted: 987 Post(s)
Liked 642 Times
Wow, lots of responses, too many to cite all of them!
After posting Post #1, I went for a club ride. At one stop I looked down and the NDS front pad was lightly agains the rim! Fortunately I could loosen the adjusting barrel on-the-fly and continue, and I'll convince myself that the slight drag was why I was struggling a bit in the pace line. This was on my Palo Alto, full Suntour Superbe and, again, with the brakes being somewhat Campy Copies, there are those wrench flats again.
OK, heading to finding the correct wrench, meanwhile "b" might help.
I did the tiptop thing countless times in the 1970's, working in bike shops -- but wrench flats are taunting me.
Hmm, I wonder if that would negate the benefits of the Campy Magic Washers.
Deflate! Brilliant! Anyway, apparently OWB-1 is no longer offered but I found one just now on eBay, so I bought it.
I found OBW-3, and apparently the wrench end is 14mm. I just checked and both the Campy and the Suntour are 13mm. There's an OBW-4 with four ends and I could get one and cut off the parts not needed to get more clearance.
This might help for centering once the brakes are installed: Dave Moulton's Blog - Dave Moulton's Bike Blog - Centering side-pull brakes
I have used this wrench for 30+ years to center the brakes. You may need to deflate the tires but the post can be accessed from the bottom when you deflate. Offset brake wrench from Park inexpensive and the part is OBW-1. You can also remove some of the material from the wrench, so that it just fits into the post flats from the bottom with the tire still inflated.
HTH, Smiles, MH
HTH, Smiles, MH
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Likes For JohnDThompson:
Quoted: 1858 Post(s)
Liked 664 Times
Rondella Dentata according the to the Velo-Retro timeline, introduced in 1971
/markp
/markp
Likes For Road Fan:
Quoted: 878 Post(s)
Liked 2,296 Times
I use a cone wrench and that works. I don’t have one of the 90 degree offset type , just the regular Campagnolo ones. Make sure the wrench is held firmly when tightening the nut on the other end . Work the brakes with the lever a few times firmly before taking the bike off the stand to make sure they modulate evenly.
Liked 2,831 Times
‘Colnago used a crown that presents a flat face, good, but the forward face of the crown is too close to the steering axis.
Liked 2,831 Times
The Colnago Super condition
full disclosure, a Super Record Headset- slightly bigger max diameter.
no top access.
