Shimano recalls cranksets
I found this in Google News feed today. Yep, my set is on that list. And of course I am riding both days this weekend. Apparently there have been 4500 incidents and 6 injuries do to fractures.
The specific models affected are the 11-speed compatible Ultegra FC-6800, Dura-Ace FC-9000, Ultegra FC-R8000 and Dura-Ace FC-R9100 chainsets, as well as the FC-R9100P power meter variant. It affects products manufactured prior to 2019, with one of the following two-letter production codes on the rear of the crank arm.
KF, KG, KH, KI, KJ, KK, KL, LA, LB, LC, LD, LE, LF, LG, LH, LI, LJ, LK, LL, MA, MB, MC, MD, ME, MF, MG, MH, MI, MJ, MK, ML, NA, NB, NC, ND, NE, NF, NG, NH, NI, NJ, NK, NL, OA, OB, OC, OD, OE, OF, OG, OH, OI, OJ, OK, OL, PA, PB, PC, PD, PE, PF, PG, PH, PI, PJ, PK, PL, QA, QB, QC, QD, QE, QF, QG, QH, QI, QJ, QK, QL, RA, RB, RC, RD, RE, and RF.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
oooo, that's a Biggy!.. thanks for the Info!
I don't see any problem on my bike, but that obviously does not mean there is not one. I am unclear if the crank set automatically gets replaced or just if a problem is seen. I'll have my LBS check it out next week.
Quoted: 682 Post(s)
Liked 453 Times
edit: ok, so no, it's completely half-arsed instead - "If you are in North America and believe you have an affected crank, you are advised to immediately stop using it and contact a Shimano dealer or an authorised inspection centre (essentially any store that is familiar with Shimano components and has passed Shimano's maintenance course). The dealer will then perform an inspection, and where signs of delamination or separation are found, a free replacement will be issued. Replacements will comprise a hybrid component that mixes a 12-speed chainset fitted with 11-speed-compatible chainrings."
So at what frequency do you go back to the Bike shop to check for signs of delamination or separation??
But what does concern me is what happens if I am 50 miles from home, with no cell coverage and the thing explodes. Naturally, I just installed new chainrings or I'd be tempted to just get a whole new set.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I have a 6800 crankset from my bike in 2017. I have close to 50,000 miles on it should I be concerned or worried? I am a mechanic but what do I need to do to see if the crankset will fail?
Quoted: 682 Post(s)
Liked 453 Times
That doesn't bother me because I go back for annual checkup anyway.
Quoted: 399 Post(s)
Liked 185 Times
So I check mine and it is in the recall batch and I watched the Shimano video on what to inspect. Things seem to look good and as other say maybe we don't know till it all simply comes apart when bearing down in a huge output of power? One thing for sure this crankset and infact the whole groupset 6800 has been great I have as I say almost 50,000 miles on it not kilometers.
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Here is the CPSC link: https://www.cpsc.gov/Recalls/2023/Sh...o-Crash-Hazard
I wonder if Hambini is gloating yet?
cf: https://www.hambini.com/shimano-cran...ring-analysis/
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,996 Times
I mean I would bring it in yearly at least for a tune up and check over so if you do that you should be set obviously check your bike with some frequency anyway as you should do and you are less likely to have issues. It is possible it could fail at some point but I think if they thought it was a definite failure possibility across the board they would be recalling everything regardless.
Quoted: 399 Post(s)
Liked 185 Times
It is for 2019 onwards so you should be set, mine is from 2016 and it is not part of the recall so not worried.
No the exact opposite those made before 2019 from 2012-2019z
Likes For deacon mark:
Clark W. Griswold
Liked 3,996 Times
Oh crap I cannot read, my bad!! Yes, then I would keep an eye on it but after 50k miles if it hasn't failed you are probably going to be OK. I think my brain has melted into a puddle of goo it has been a long week and a long day today.
Quoted: 682 Post(s)
Liked 453 Times
Real if unusual scenario: I’ve got a 9100 FC on the shelf I was planning to install in the next month. If I were to take that in, I think it’ll quite possibly get the OK since it’s never been used. Might it fail 500km later? Don’t think they’ve given us any clue … or have they?
and ah yeah, that Hambini video was where I’d seen it before - thanks. And of course he’s gloating
Liked 2,979 Times
deja vu
-Oh Hey!
-Oh Hey!
Quoted: 4409 Post(s)
Liked 1,566 Times
The bike industry is SO STUPID about galvanic corrosion.
Quoted: 839 Post(s)
Liked 1,063 Times
Good info in this article as well. Shimano crank recall | Details of global 'inspection and replacement' process issued - BikeRadar
Likes For Crankycrank:
Likes For Vintage_Cyclist:
Not so sure. This seems to me to stem from the fact the total cranks impacted is 2.4 million worldwide. Ignoring the financial impact there is no way they can ramp up production to replace all cranks for full replacement without basically halting all new sales for several years, which would be a death blow.
They are trying to stave off massive lawsuits by trying to identify those cranks that are at the highest current risk of delamination…
But as other have noted, the fact a crank looks fine today is no guarantee it’s not going to break in 6 months. Shimano should basically tell everyone not to ride these cranks, and then work on a long-term replacement program….but of course they are being coy and hoping they can save money by putting its customer at continued risk.
This is going to make the used bike market also insane given how many bikes have these model cranksets.
From the OP article link
My 2016 Raleigh Tamland 2 has FC 6800 46/36 175 NE cranks that are on the list.
Also, have two new(still in the box) Ultegra hollow tech cranks that I bought many years ago when parts were much cheaper in price. Not sure if these are on the list, still need to check the numbers when I find the box they are stored in.
My 2016 Raleigh Tamland has only about 500 to 800 miles on it, As I own many bicycles and do not see any separation. Plan to let the LBS inspect them next time I go to the bike shop. But if they look okay, who is to say others and I will not have problems in the future? Will be following this recall, hopefully, Shimano
does bicycle riders right to avoid as many future injuries that still could happen.
hmm, some other forums posting are saying this recall is way overdue.
If you have an affected crank, you are advised to immediately stop using it and contact a Shimano dealer or an authorized inspection centre (essentially any store that is familiar with Shimano components and has passed Shimano's maintenance course). The dealer will then perform an inspection, and where signs of delamination or separation are found, a free replacement will be issued
This is LONG past due. There's a "Thanks Shimano" Instagram account loaded with these failing.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Note this issue is only on Ultegra and Dura-Ace. Replace it with a 105 and don't look back:
https://www.backcountry.com/b/shiman...B&gclsrc=aw.ds
Liked 3,443 Times
My kid who is doing a mechanical engineering degree had a 1-term chemistry requirement. It wasn't the term that would cover oxidative potentials and redox reactions.
They used to teach this in high school chemistry. Probably not anymore.
Liked 3,443 Times
Well, they’re not telling people to check them every X miles/months/sprints. They thought they were fine when they made them too. And it was kind of a rhetorical question.
Liked 1,566 Times
Water doesn't have to get inside, it just needs to run across steel and aluminum anywhere to form the circuit.
